Like Tree2Likes
Old 08-22-2013, 06:26 AM   #421
Trader Rating: 118 (100%+)
Originally Posted by ongbenghui View Post
Personally... I used to do that for my old MR4-TC-SD.
But I find that I cannot use straight carbon fiber rod for this purpose.
At high torque, the carbon fiber rod will split easily. You will need woven carbon fiber rod.
You can see that the original TC3 carbon fiber rod used woven carbon fiber, not the straight carbon fiber type.
The original TC3 shafts were fiberglass, not Carbon fiber. Woven carbon is not required. 1/12th scall cars have used striaght pulled carbon shafts for years. Before going on hiatius, I made 150+ of these shafts for TC3, TC4, HPO pro4 Yokomo SD, and Tamiya shaft drive cars without hearing of one spliting. The key is to have a little bit of float in between the front and rear drive cups. With the upper/lower carbon fiber chassis cars, this was less of a concern.
ANwyay, A 4mm CF tube is probably too small to work properly as there may not be enough glue surface to hold the tips in place. I have 2 people that said they are willing to try out a conversion part so we can go from there and see what happens.
http://store01.prostores.com/servlet/whipracing_bluescrews/StoreFront
ewippler is offline   Reply With Quote
Old 08-22-2013, 10:36 AM   #422
G-rem's Avatar
What are the main advantages to replace the Awesomatix original alloy center shaft by a carbon one?
Thanks,
G-rem
G-rem is offline   Reply With Quote
Old 08-22-2013, 11:58 AM   #423
Thanks,
G-rem
From what I have been told, the Awesomatix original alloy center shaft is quite thin (approx 4mm) and rather heavy (approx 10g). A carbon part would be appox 5-6g finsihed. This would allow quicker acceleration as well as less flexing at high speed (carbon is stiffer than aluminum). I had customers years back find htat the 4.5mm TC3 shaft would flex so much at high speeds, that it would be ejected from the car. The carbon part fixed this. I plan to make a test part for a Awesomatix racer to check for fitting issues and report on the results.
Erik
Old 08-22-2013, 12:22 PM   #424
josecarlo1129's Avatar
^the only issue I see is the possible binding of the steering rack if the proposed drive shaft will be thicker than the stock. Clearance from the steering to the drive shaft is really close at the moment.
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 08-22-2013, 12:26 PM   #425
Awesomatix A700 center shaft weight is 7g.
Oleg Babich is offline   Reply With Quote
Old 08-22-2013, 01:00 PM   #426
The Awesomatix website claims the shaft weighed 10grams, but it felt a little lighter than that... I guess the conversion will be in the 4.5gram range....
bertrandsv87 is offline   Reply With Quote
Old 08-22-2013, 06:41 PM   #427
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
I double checked and it is 7gm just like Oleg said...
I still have my R2 I brought the hop up carbon fiber shaft .and it weight only 5gm
OVA is offline   Reply With Quote
Old 08-26-2013, 12:06 PM   #428
Fresh batch of TC4 shafts should finish up tonight. If interested, PM or email for details.
Erik
Old 08-26-2013, 12:15 PM   #429
Trader Rating: 20 (100%+)
Still have any pro4 shafts for sale?
goots is offline   Reply With Quote
Old 08-26-2013, 12:43 PM   #430
No problem Erik, and thanks again....
Old 08-26-2013, 12:58 PM   #431
I cannot order donor shafts for the pro4 any more. I can still do a conversion if you have a donor part (new or used but straight). PM or email if interested and I can provide details.
Erik
Old 08-27-2013, 11:43 PM   #432
Could you make a center drive shaft for the Tekno SCT410?
Bignose94015 is offline   Reply With Quote
Old 08-28-2013, 12:01 AM   #433
Smile
With a 4mm CF shaft it might be necessary to insert the shaft tips twice as far into the CF tube to get the glue to hold properly, and thereby solving all the clearance issues.......
Old 08-28-2013, 12:36 PM   #434
boudin4evr's Avatar
Trader Rating: 18 (100%+)
how much are the TC4 shafts?
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 08-28-2013, 07:13 PM   #435
$38 shipped for TC4 shafts
$28 shipped if you have a donor (new or used but straight) for me to convert.
Erik
1/5th Fg Modellsport Touring Car Carbon Fiber Adj Rear Wing nytaurean R/C Items: For Sale/Trade 0 01-01-2008 08:38 PM
Racing MINI at the NA Finals? (tires and carbon shafts for sale) gibbous R/C Items: For Sale/Trade 5 08-20-2007 09:31 PM
carbon fiber shafts for tc4 speedybill Electric On-Road 2 07-13-2006 04:27 PM
Your take on 3 carbon fibre touring cars the dirt Electric On-Road 18 09-10-2005 01:23 PM
Carbon Fiber Drive Shafts Coming Soon Warren Weaver Electric On-Road 0 04-20-2005 09:25 AM
