Old 08-21-2013, 01:15 PM   #406
Originally Posted by ewippler View Post
I just looked up the manual for the awesomatix car (it is the most insain chassis design I have seen since the preditor came out back in the mid 90s). does it work well? Very durable?
Looking at the manual, I could make a carbon fiber center shaft for this car. It should work very well. It just needs to have a little front-to-back float to keep the shaft from going into compresion (CF tube doesn't like that).
If interested in a CF shaft for the awesomatix, I would just need a donor shaft sent and I can do the conversion. Send me a PM or email for payment/shipping details for the donor part.
Erik
the car has float built in..it snaps in front diff, but has float built into rear..car is ridiculous..probably the best stock class tc on market right now..results are amazing..i will order a spare shaft and get it to you asap
team az is offline   Reply With Quote
Old 08-21-2013, 01:17 PM   #407
The old carbon tc3 driveshafts needed tc3 cups to fit the tc4.....If your tc4 driveshafts need no mods to fit the tc4 cups, then I will take four of them... If you can make an Awesomatix carbon shaft ,I will take two of them too...
bertrandsv87 is offline   Reply With Quote
Old 08-21-2013, 01:21 PM   #408
Trader Rating: 107 (100%+)
I have TC3 shafts in stock. The TC4s I would need to order donor shafts or have them sent to me. For the awesomatix parts, I would need donor shafts sent to me.
Send me a PM or email for the details.
Erik
http://store01.prostores.com/servlet/whipracing_bluescrews/StoreFront
ewippler is offline   Reply With Quote
Old 08-21-2013, 01:31 PM   #409
I can send you a tc4 shaft no problem, but you'll have to keep it though... As far as the Awesomatix, I don't have a spare One to send you... The Awesomatix shaft is super thin and light already, and the carbon fiber shaft will only give it more strength.....
Pm me ASAP with your address so I can send you the tc4 shaft...
Old 08-21-2013, 03:32 PM   #410
Tc4 shafts sent to you Erik ! I sent you One shaft for you to keep, two shafts for you to retrofit($56), and funds for you to make me two more CF shafts($76).... Talk to you soon Erik...
Old 08-21-2013, 04:05 PM   #411
Trader Rating: 15 (100%+)
Default Shaft
Post a pic of a awesomatix shaft when done . I may want three.
AARON YOUNG is offline   Reply With Quote
Old 08-21-2013, 05:43 PM   #412
Posted pics of the 5 TC3 shafts I just completed (stock composite TC3 shafts shown at the bottom). 5 of them weigh in at 27.2g (approx. 5.5g each). The stock drive shafts are over 10g each.
The awesomatix shafts will look almost the same, except with silver tips instead of blue. At the moment, I don't have a good way to purchase donor awesomatix shafts, so for now I will need customers to supplier the donors. The conversion will cost $28/drive shaft shipped and conversion takes about 3days once I have them.
Thanks again for the interest.
Erik
Carbon Fiber Shafts for Touring cars-tc3-shafts-x5.jpg   Carbon Fiber Shafts for Touring cars-weight.jpg
Old 08-21-2013, 05:49 PM   #413
TeamCody's Avatar
I would be interested in a TC4 Shaft. Correct me if I am wrong but Isn't the TC3 different than the TC4? If I remember correctly it has larger ends or something no?
Thinking about that, isn't the TC4 and Pro4 shaft virtually identical?
"Its just a hobby!"... or so I'm told.
TeamCody is offline   Reply With Quote
Old 08-21-2013, 08:17 PM   #414
The TC4 tip ends are slightly smaller. I have some TC4 donor shafts coming so they should be available shortly (estimate is late next week).
Awesomatix CF Shaft Update
I have studied the Awesomatix shaft and chassis design more closely. the stock shaft is approx. 4mm OD. My CF tube is 5.5mm, but much stiffer. Without seeing an actual car, I cannot guarantee it will fit, especially with the ball bearing shaft brace installed. That said, if there is more than 2mm clearance between the stock shaft and the battery/servo, it probably will fit with a carbon conversion. The shaft support probably wouldn't be required as the cf tube is much stiffer than the 4mm aluminum shaft and will not wander or flex at high speeds (probably the reason Awesomatix added the support in the first place). If someone wants to take a gamble and send me one, I will convert it at cost for being the tester. PM or email if interested (first come, first serve).
FYI - HPI pro 4 and Tamiya EV0 V shafts were 4-4.5mm and I converted those cars without issue using 6.2mm tube. Neither had a shaft support with bearings.
Old 08-22-2013, 12:37 AM   #415
Understood Erik.... Parts for the Awesomatix are hard for me to get since I don't have Paypal or a credit card to order them straight from Russia... Most LHS hardly carry Awesomatix Parts, so it will be a while.....
Old 08-22-2013, 12:43 AM   #416
Also Erik, the battery can move away from the shaft when you adjust the holder screws, and it will accomodate the thicker CF shaft easily.
Old 08-22-2013, 01:09 AM   #417
It might even be possible to keep the Center support, but instead of using 4x8mm Bearings you could use 4x7mm Bearings... 5.5mm - 4mm = 1.5mm/2 = 0.75mm... The 4x7mm are 0.5mm further away from the shaft, but are at an angle that might be perfect enough to make the installation flawless... It can be done guys, I can feel it !!!
Old 08-22-2013, 01:14 AM   #418
The 4x7x2.5mm Bearings are also included in the A700 kit... Perfect if they fit....
Old 08-22-2013, 02:02 AM   #419
I think that 5-5,5 mm diameter CF tube can be a good decision for Awesomatix carbon shaft. But this shaft must have at least 20mm length 4mm diameter metal front tip to avoid the interference with the steering system.
At the 5,5mm good balanced CF shaft the central bearing support can be removed.
Oleg Babich is offline   Reply With Quote
Old 08-22-2013, 05:08 AM   #420
Personally... I used to do that for my old MR4-TC-SD.
But I find that I cannot use straight carbon fiber rod for this purpose.
At high torque, the carbon fiber rod will split easily. You will need woven carbon fiber rod.
You can see that the original TC3 carbon fiber rod used woven carbon fiber, not the straight carbon fiber type.
My blog: http://ongbenghui.blogspot.com
ongbenghui is offline   Reply With Quote
1/5th Fg Modellsport Touring Car Carbon Fiber Adj Rear Wing nytaurean R/C Items: For Sale/Trade 0 01-01-2008 08:38 PM
Racing MINI at the NA Finals? (tires and carbon shafts for sale) gibbous R/C Items: For Sale/Trade 5 08-20-2007 09:31 PM
carbon fiber shafts for tc4 speedybill Electric On-Road 2 07-13-2006 04:27 PM
Your take on 3 carbon fibre touring cars the dirt Electric On-Road 18 09-10-2005 01:23 PM
Carbon Fiber Drive Shafts Coming Soon Warren Weaver Electric On-Road 0 04-20-2005 09:25 AM
