Old 10-09-2006, 09:01 AM   #331
dr_hfuhuhurr's Avatar
Trader Rating: 69 (100%+)
Thanks again Erik.
These things are awesome!
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 10-21-2006, 07:07 PM   #332
Trader Rating: 104 (100%+)
Default Web site updates
I switched web site carriers and made a few updates to the web site. There is a new products page showing some of the new parts I have come up with. take a look and let me know what you think.
Erik
http://store01.prostores.com/servlet/whipracing_bluescrews/StoreFront
ewippler is offline   Reply With Quote
Old 10-21-2006, 08:26 PM   #333
Drew_Cat's Avatar
Exclamation /new.html/
Erik
You may want to change the URL to :: >>> http://home.comcast.net/~ewippler/
hope this helps !!
the ending with /new.html/ sometimes don't load.. comcast error..
Items for sale:
TURBO GFX>>>> http://www.rctech.net/forum/showthread.php?p=4329165#post4329165
Tekin Battery Nurse >>>> http://www.rctech.net/forum/showthread.php?p=4329173#post4329173
Thanks for looking
Drew_Cat is offline   Reply With Quote
Old 10-21-2006, 08:36 PM   #334
Drew_Cat's Avatar
I was looking for a way to improve my touring car's performance as well as create a one-of-kind part that would make it stand out a little. I came upon the idea of taking a solid delrin spur gear (ultra true and rigid) and adding spokes to it. The result was an ultra light spur gear that is extremely rigid amd very true, as it is machined from solid plastic instead of injection molded. The gear weighs in at 2.1-2.3 grams for a 100T gear. The lightest one I have found prior to this was molded, 3g and flexed considerablly, and wasn't true to the hub. If nothing else, I thought it looked pretty trick. Mot sure if there is any interest in such a gear, but I thought I would share it.
can you make these for 1/12 pan cars?
Items for sale:
Thanks for looking
Old 10-22-2006, 11:47 AM   #335
streetracer745's Avatar
Send a message via AIM to streetracer745
what about the yok mr4tc? could you make one for that. maybe with carbon ends. that would be awsome. i can get them for $25 now. but i have to ship them from japan because they dont have any in the USA store anymore. sounds like a great idea though. expecially if you can do it cheap. how about axles our something. could you make those carbon? that would be cool. and i would deffinitly buy them from you.
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 10-22-2006, 01:45 PM   #336
Nautilian's Avatar
Hi Erik,
Any chance of getting a Tamiya Evo V/5 shaft made up. If so, you have my order already!
Thanks a mil
Naut
Nautilian is offline   Reply With Quote
Old 10-22-2006, 03:53 PM   #337
I have made the drive shafts for the Yok before, but the stock aluminum doner shafts are no longer sold. If you have a spare, I can make you a carbon shaft for $25 plus $3 return shipping. Just PM or email me for details.
I am not sure if I can make one for the EVO 5 as I beleive Tamiya changed the ends. If someone can send me a pic of the EVO shaft out of the car, I can say for sure. However, I have them for the EVO 4 in stock.
I corrected the URL for my update web site. Hope it now works.
Erik
Old 10-22-2006, 05:30 PM   #338
I can make the gears for 1/12th scale. I have plans to make a few 100T to start with. The hole pattern I have for the current generation fits touring cars or pan cars using the stealth diff. I could also make one for the larger diff as well, although they will be slightly heavier. The gears will run $12 each, plus shipping. I know it is a little pricy, but it has to be worth my while to make them.
Erik
Old 10-25-2006, 08:37 PM   #339
Default Ultra light diff halves - Tamiya TA05
I just finished up a set of ultra light diff halves for a friend. They are pretty trick. If anyone is interested, I think I can make similar ones for the Tamiya 415, Tamiya EVO5, or HB. Not sure about the Xray cars, but I am sure something similar is possible. Take a look and let me know what you think.
"Whip Racing ultra light diff halves for the Tamiya TA05 series of cars, new in the package. These diff halves start life as original Tamiya option parts, Tamiya part #53919. They then receive the Whip Racing special CNC treatment, removing just the right amount of material to not sacrifice strength. They weight 5.7grams, or about 20% less than stock, and are extremely light and ultra true. They look like Swiss made precision watch parts. Please note the picture comparing the Ultra light Diff halves to their stock equivalents . Because they start life as Tamiya parts, they are direct replacements for the stock plastic or upgraded aluminum diff halves. "
Erik
Old 11-03-2006, 06:49 AM   #340
Default TA05 Diff Halves
The first batch of TA05 diff halves are already spoke for. The next batch will be available after Thanksgiving. If interested in preordering, let me know and I will put you on the list. I have lowered the price to $30 a pair. I can also make them for the Tamiya 415 series or Hot Bodies Cyclone (others will cost more). The Xray Diffs might also be possible, but I have yet to see one opened.
Retro Fitting also Available.
I can also retro fit the aluminum diff halves for the TA05, Tamiya 415 or Hot Bodies cars. $20 a pair for retrofitting.
Also, I hope to have the lightweight spur gears availble next week sometime.
Erik
Old 11-04-2006, 12:53 PM   #341
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Erik
What is the weight in comparison to the precision Plastic ones?
tamiyarcracer is offline   Reply With Quote
Old 11-04-2006, 03:55 PM   #342
I don't have a set of the plastics to compare. I would think they are nearly the same after the machining process, maybe 0.5g heavier. However, they will not flex or break like the plastic ones are prone to doing. Also, the diff rings will not slip like on the plastic diff halves.
Erik
Old 11-05-2006, 01:03 AM   #343
Trader Rating: 22 (100%+)
Can you rebuild other carbon fiber shafts. I have a CF shaft for my Yokomo SSG and it unfortunatly was rubbing something and splintered. So I have it but just need the carbon shaft replaced the ends are still good.
Thanks,
James
Speed Passion U.S.A. - Turtlemaster Racing
www.speedpasion.net
Anemic_SluG is offline   Reply With Quote
Old 11-05-2006, 06:33 AM   #344
James,
I can rebuild most stock aluminum shafts into a carbon shaft (TC3, TC4, SSG, HPI, etc). However, I beleive the Yokomo shaft has a small carbon center section that fits inside a hole in the aluminum tips. The carbon tube I use is larger in outside diameter and has a hole in its center for the tip to fit inside. I don't think I could rebuild the CF shaft you already have. That said, if you have a stock aluminum shaft laying around, I can retro fit it into a CF shaft. The retro fits run $25 plus return shipping. At this time, I can only do retro fits for the SSG as Yokomo stopped selling the stock aluminum part in the US.
Erik
Old 11-05-2006, 07:42 PM   #345
Default Tamiya EVO 5 CF drive shaft
Just finished the first Tamiya EVO V drive shaft for a fellow racer in South Africa. It turned out very nice and is the lightest one I have made for any car - 5grams. The stock part I beleive was between 9-10grams. Currently I am not stocking these parts because the car is so rare (I had to order the donor shaft from Hong Kong). However, if anyone is interested, I can custom make them (special pre-order) given a 2 week lead time.
Erik
1/5th Fg Modellsport Touring Car Carbon Fiber Adj Rear Wing nytaurean R/C Items: For Sale/Trade 0 01-01-2008 08:38 PM
Racing MINI at the NA Finals? (tires and carbon shafts for sale) gibbous R/C Items: For Sale/Trade 5 08-20-2007 09:31 PM
carbon fiber shafts for tc4 speedybill Electric On-Road 2 07-13-2006 04:27 PM
Your take on 3 carbon fibre touring cars the dirt Electric On-Road 18 09-10-2005 01:23 PM
Carbon Fiber Drive Shafts Coming Soon Warren Weaver Electric On-Road 0 04-20-2005 09:25 AM
SEO by vBSEO 3.5.0
