Old 04-26-2013, 07:19 PM   #1396
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
just so you guys know , when using the tamiya ballcups you have to use the plastic bag trick. pretty much you take one side of the bag the parts were packaged in and you place it over the bsallcup then you snap the ball cup over that and it cuts out a perfect circle out of the bag which takes up the slop yet allows for free movement of the ballcup.
Serpent project 4x
jeff jenkins is offline   Reply With Quote
Old 04-27-2013, 07:11 AM   #1397
spunkysandoval's Avatar
Trader Rating: 124 (100%+)
I have to state a few things about this kit. I just built an S1 for my daughter's first car and I was pretty happy with the build overall. That the quality of some of the parts is not the best (excepcted for the price). The standard kit hardware had several problems.
- I had a ball stud that wasn't broached and so I wasn't able to use it.
- The top deck required quite a bit of sanding to drop in without preloading the bulkheads (would have caused chassis tweak)
- One of my shock bladders had a pin hole in it (not useable untill I filled hole with CA)
- Ball cups suck! They have a lot of play and they pop off everytime I hook up a turnbuckle wrench.
- One of the optional aluminum hexes I bought did not have a split cut in it to clamp down on the axle.
Other than those few minor things all was very good. I went ahead and picked up sways, aluminum shock bodies, and also the aluminum hexes and turnbuckles.
Cant wait to see how it does !
Tekno RC - VBC Racing D06 - Axial Rubicon and Wraith - SC10.2 - Hitec - Speed Passion - Werks - lrhhobbies.com
spunkysandoval is offline   Reply With Quote
Old 04-27-2013, 05:14 PM   #1398
Send a message via AIM to justxroro
I broke a pivot ball today during practice at Wcrc. Does anyone know if pivot balls from the other manufacturers fit our cars?
Other than that I'm really loving my s1. Im a totally rookie tho... I thought my centering issue was due to steering slop n a bad servo, when it was just bad building/setup on my behalf. As soon as I got my camber set and arms moving freely she goes pretty straight.
S1 = big grin on my face
justxroro is offline   Reply With Quote
Old 04-27-2013, 05:50 PM   #1399
I'm going to switch out all of the pivot balls and rod ends to VBC stuff. It is an improvement over the Spec R pivot balls and rod ends. I think they are 5.7mm, but the real advantage is that when I adjust my suspension the wont pop off like the spec r stuff.
Old 04-27-2013, 08:31 PM   #1400
Airwave's Avatar
bigger pivot balls means bigger plastic parts... Are you sure it won't rub the wheel?
Airwave is offline   Reply With Quote
Old 04-27-2013, 10:12 PM   #1401
They are open on the top. They have almost zero play in them
Old 04-27-2013, 10:21 PM   #1402
Suspended
I never have this trouble, I pretap everything, so when i go to put a wrench on the turnbuckles they move smooth as silk. As for slop, i do not know what everyone is whining about, i have less than 1mm movement in the steering left to right and that is with all the stock parts. 1mm movement is hardly a game breaker and not something that anyone is going to notice, especially if you are using a fast servo.
RogerDaShrubber is offline   Reply With Quote
Old 04-28-2013, 06:37 AM   #1403
bakoo's Avatar
With the exception of a big enough pinion and a servo saver, my R1 build is finished, and now I find myself wondering what the contents of this bag is meant for:
I guess they go under the suspension mounts to lift them, but why? For adjusting the rollcenter?
bakoo is offline   Reply With Quote
Old 04-28-2013, 11:09 AM   #1404
SS LS1's Avatar
Trader Rating: 23 (100%+)
Roger, where do you get left hand thread taps to properly pre tap the ball cups that need reverse threads? Thanks!
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 04-28-2013, 11:36 AM   #1405
Airwave's Avatar
Attachment 1061622
indeed!
Old 04-29-2013, 09:22 AM   #1406
rcdave1's Avatar
Trader Rating: 14 (100%+)
Finished building my R1 and have to say I'm very pleased with the performance of the car on the carpet yesterday. I incorporated a few changes during the build which made for a smooth car. Listed below are a few of the changes that came from this thread.
1- tamiya hinge pin balls (more consistent size. Several of the spec r were to tight.
2- flanged bearings on the lay shaft
3- shimmed the steering rack with .1,.2,.3 shims to reduce the slop.
Overall feel of the car was really good and lap times were only 3 tenths off the typical pace. Not to bad for the first run.
Dave Banks
rcdave1 is offline   Reply With Quote
Old 04-29-2013, 11:36 AM   #1407
AdrianM's Avatar
Google is your friend. Search for left hand M3 tap lead to this:
http://www.amazon.com/Metric-Left-Th.../dp/B009MN264Y
Adrian Martinez
Old 04-29-2013, 04:49 PM   #1408
Suspended
+1 also try http://www.tap-die.com they have full sets of left hand machine thread taps.
Old 04-29-2013, 11:21 PM   #1409
spencehotbodies's Avatar
Hello
If any body in the market for up graded r1, I'm selling mine. Pm me cheers
Xray T416- Xray X1-Spec-r-Sanwa-Orca-Ame-Arrowmax-Wild turbo fans
West London Race Club
spencehotbodies is offline   Reply With Quote
Old 04-30-2013, 06:11 AM   #1410
nrtv20's Avatar
Attachment 1061622
pro and anti squat
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13416 12-21-2016 06:45 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 04:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 12:44 PM
SEO by vBSEO 3.5.0
