Old 04-13-2013, 09:54 AM   #1336
Pit-racer's Avatar
I used my old pro4 wheel hex's that were 6mm for wheel from ball end clearance
www.igthobbies.com / Serpent Cobra GT / 748 TQ / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / Flo-Control
Pit-racer is offline   Reply With Quote
Old 04-13-2013, 11:46 AM   #1337
32819toon's Avatar
Put my new gear diff in the front on Thursday with 300000 oil and it was great, much better and more predictable than the spool.
I'm thinking of fitting some sway bars to the S1, is this the correct part :-SPEC.R SPR024-RBXR
Which is the best thickness to run ?
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 04-13-2013, 12:15 PM   #1338
Airwave's Avatar
First day of real testing on our local track. The grip is very low, but we put a lot of soda on the track and the sun was helping, but neither tyres warmer nor tyres sauce...
By the way, I start with my carpet setup... Not so good with a cold track. Immediately change droop values, differential oil, shocks oil and spring, only keep the same ARB!
Despite the fact I'm running a very old tyres set, the car seems fine, the rear is planted, but the front is lazy... Change the front dampers angle is just fine, the car is fast and predictable. I complete a perfect run, but it was the only one, because my tyres are really out!
Time to order new ones and prepare the BBQ for next week-end!
Again, this car is precise and reacts very well to setup changes. Another good point for today, the DualSky 870 gives a huuuuuge boost! Impressive!
Airwave is offline   Reply With Quote
Old 04-13-2013, 12:15 PM   #1339
SteveM's Avatar
Trader Rating: 125 (100%+)
The S1 kit includes some of the hardware required for sway bars but you still need a few bits and pieces. I referred to the R1 manual and I used 1.4mm bar up front and 1.2mm in the rear. I had some left over sway bars from my Sakura and used those. I did have to trim the ends on the front sway bar if I remember to make them fit properly.
SteveM is online now   Reply With Quote
Old 04-13-2013, 02:04 PM   #1340
Pit-racer's Avatar
What did you do for the rear end to be planted? I have tons of steering.
Old 04-13-2013, 03:20 PM   #1341
Airwave's Avatar
I mainly change the springs and the shocks inclination, use a wide anti-roll bar and 3.5 toe-in.
As all cars the R1 needs a good front-rear balance, could you please specify your actual setup, front and rear? Maybe the problem is not you can't plant the rear, but you can't calm the front...
Old 04-13-2013, 03:47 PM   #1342
Pit-racer's Avatar
Sorry I thought you had the S1 , in which I have.
Old 04-14-2013, 12:10 PM   #1343
Airwave's Avatar
Actually I think the car is the same, you may have a lot of flex with the composite chassis... If I can help, don't hesitate...
Old 04-14-2013, 12:17 PM   #1344
i bought the s1 chassi to get more flex but its almost as stiff as the carbon chassi, cheap glass fibre
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Schumacher Cougar KF2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 04-14-2013, 03:31 PM   #1345
Airwave's Avatar
Ok nice to know. By the way I find the chassis flexible enough in the original configuration.
Old 04-14-2013, 04:49 PM   #1346
miles514's Avatar
3.5 deg rear toe in is worth a try, I already have a roll bar (from my FGX). Will be testing this next time.
AE SC10 FT, RC10 Worlds Car, 3Racing Cactus, HPI Rally, Tamiya MF01X Jimny, Tamiya M05 Pro V2, Tamiya group C, Wild Willy 2, CC-01 Bronco, F103 Le Mans, F104Wgp, Subaru Brat, Wild One, Sand Scorcher.
miles514 is offline   Reply With Quote
Old 04-15-2013, 04:25 AM   #1347
miles514's Avatar
While cleaning my s1 this morning I noticed a crack on the upper deck right on top of the hole. I remembered I had a bad crash last night. well this is my immediate fix until my new upper deck arrives. the pics doesnt do justice to the subject but its there.
Old 04-15-2013, 04:27 AM   #1348
Airwave's Avatar
Just a small detail about the toe... If you are running "high speed" configurations, as 10.5 boosted or mod, that's worth a try... But don't forget that high toe values are cornerspeed killers, especially on stock classes, as 17.5 or 21.5 blinky...
Old 04-15-2013, 07:02 AM   #1349
Send a message via AIM to justxroro
finally finished building my s1 and went to wcrc yesterday. im really liking the thing even with the kit recommended suspension setup but i can't seem to get the car to center consistently. im not sure if its the steering slop that i've been reading about, the savox 0254 servo im using, or something else?!?
thanks in advance
justxroro is offline   Reply With Quote
Old 04-15-2013, 06:04 PM   #1350
Pit-racer's Avatar
Ran the s1 on asphalt this weekend worked out better without the rear sway bars attached. Moved up a bit qual. 2nd. Now to work on more corner speed in VTA. gonna play with different diff fuilds.
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13416 12-21-2016 06:45 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 04:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 12:44 PM
SEO by vBSEO 3.5.0
