Old 03-24-2013, 07:44 AM   #1201
Trader Rating: 58 (100%+)
Originally Posted by PitNamedGordie View Post
Did you smooth out the diff/spool spacers? I found those had burrs on them and needed to be lightly sanded.
Good call. The car freed up after a 2 hr run on the bench. I then looked at those spacers. They weren't too burred up. Things still seemed tight, so I polished about .005 in off each spacer. That really made a nice difference.
So far very impressed with this sub-$300 car. Can't wait to wheel it.
MC112b is offline   Reply With Quote
Old 03-24-2013, 11:13 AM   #1202
I'm running my new second S1 in USGT. I can not get a handle on it with the HPI X-patterns, either belted or non-belted.
But since my VTA car handles great, I slapped four 26mm (front) vintage tires on it and it was right back to being the sweet handling S1 that I know and love.
Next week I'll try it with new vintage tires and see what happens.
.crispy is offline   Reply With Quote
Old 03-24-2013, 12:57 PM   #1203
R1 in action, im car no6 (all white body) finnished 3rd in that final (Fredrik)
https://www.youtube.com/watch?v=w1Fu...YrZ72H&index=7
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Schumacher Cougar KF2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 03-24-2013, 02:08 PM   #1204
BajaSkidmark's Avatar
In the middle of assembling my R1 now, and found the outdrive shaft of the diff has .4+ mm of play. Is this normal, or should it be shimmed up for less play?
BajaSkidmark is offline   Reply With Quote
Old 03-24-2013, 02:09 PM   #1205
i have run mine with the play all the time, havent had a problem, more than the leaking part (leaks where the diff halves goes togheter)
Old 03-24-2013, 02:21 PM   #1206
Did you sand down the male half to close the gap between the diff halves? It was one of the recommendations earlier in this thread. Along with using green slime on the o ring. I didn't want to button up my diff if I should get some spacers to get less end play.
Old 03-24-2013, 02:23 PM   #1207
yes i have sanded the diff, i have tried tamiya aw grease, green slime and black grease and its still leaking, not as much as before but still leaking... but its the only thing i dont like with the car, so i can live with it, might change it to a xraydiff later
Old 03-24-2013, 02:41 PM   #1208
I hope mine seals up okay!
Old 03-24-2013, 02:45 PM   #1209
I put 80wt shock oil in my rear diff. Not leaking. Don't know if that is because I sealed it well or it is dry in there!
Old 03-24-2013, 02:50 PM   #1210
A smidge under full is where you want to be on your diffs. I basically wet the rear diff with some 20k Losi fluid. Sticky enough for a little action, nothing crazy. Feels like shock oil, without all the fluid to potentially leak.
Old 03-24-2013, 03:51 PM   #1211
think im going to put a thin coat of 500k diffoil between the halves, worth a try
Old 03-24-2013, 05:21 PM   #1212
metalnut's Avatar
Trader Rating: 36 (100%+)
What handling issues are you having with the X-patterns?
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 03-25-2013, 03:06 PM   #1213
good starting setup for med/high grip carpet, the car is really easy to drive
http://www.scribd.com/doc/132318342/...-Mkeskil-Setup
Old 03-25-2013, 04:47 PM   #1214
I reamed the suspension arms, got them to feel real nice and drop with their own weight easily but without any slop. After tightening down the attach points to the chassis, they stay where you put them... Not hard to move them, but they won't drop under their own weight. Is this something that will wear in, or do I need to remove some material off the sides to free them up some? This is an R1, not an S1... thanks.
Old 03-25-2013, 04:57 PM   #1215
Not enough grip with the belted. Too much push.
With the non-belted, too much grip and traction rolling.
I could chase it but the car works well with the vintage tires D compound.
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13419 Yesterday 01:19 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 04:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 12:44 PM
SEO by vBSEO 3.5.0
