Old 03-20-2013, 08:46 PM   #1171
Pit-racer's Avatar
Originally Posted by Tabushi View Post
MANUAL Box stock setup, and i layed down 1 hole on shock tower down the rear shocks and used 40wt associated oil on all 4 shocks, THATS ALL ! ...
O.K. everything going back to box stock and going from there. Are you using the sway bars?
www.igthobbies.com / Serpent Cobra GT / 748 TQ / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / Flo-Control
Pit-racer is offline   Reply With Quote
Old 03-20-2013, 11:41 PM   #1172
Pe4atnik's Avatar
Originally Posted by Bappe View Post
keep reading alot of the car breaking easy, for me this is like a tank. i rarely crash, but when i do its often at highspeed, only thing that has broken is a bodypost in the front, and when that happened i just touched a car after a lowspeed corner.
I didn't mean that it breaks easy, for our races - it's very durable. The thing is that most of the tracks here are made from steel and when you touch the border on high speed you usually break arm or something. My daughter was running HB before and it was very hard to finish for her, now the breaks are rear.
So I'm very happy with all of my s1. Now I will try R1.
Bears, Vodka, RC Racing
Pe4atnik is offline   Reply With Quote
Old 03-21-2013, 02:03 AM   #1173
miles514's Avatar
Hi Guys! im new here and I have a S1, just a question, What is the ideal spur pinion combi running a 17.5 motor on a large medium bite indoor tracks? BTW I prefer 48pitch gears. TIA!
miles514 is offline   Reply With Quote
Old 03-21-2013, 08:35 AM   #1174
tiago890's Avatar
Hey,
Anyone running the spec-r in Jersey.
tiago890 is offline   Reply With Quote
Old 03-21-2013, 11:46 AM   #1175
Pe4atnik's Avatar
If you have a blinky stock - 4,6 to 5,0 final ratio is OK. So it's 32t with stock spur.
It depends on what spur and pinion you have. I've seen 34t 48p pinion on it, but it looks not good.
Old 03-21-2013, 07:18 PM   #1176
Airflow's Avatar
What tool do you use to tighten the layshaft. I can only tighten the M3 flat alen screw on that side but I have no Idea what to use on the other side to fully secure the layshaft.
Airflow is offline   Reply With Quote
Old 03-21-2013, 07:20 PM   #1177
3mm hex
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Schumacher Cougar KF2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 03-21-2013, 07:39 PM   #1178
Airflow's Avatar
Ok, Ill try thanks.
For 3mm, I used my mountain bike's multi tool and it didnt fit.
I'll try RC 3mm driver later from my friend.
Old 03-22-2013, 02:43 AM   #1179
miles514's Avatar
Thanks Sir I really apreciate that. 1 more thing, when testing my s1 on a car stand, theres dragging on the front wheels when throttling and steering it to the left and right. Is this normal on a front spooled car? Do I need to replace the spool into a gear diff? (30usd) or will this hop up part solve the problem: (I dont know if this is for front or rear) Thanks!
http://www.rcmart.com/spec-spr020scx...cPath=595_1576
Old 03-22-2013, 09:30 AM   #1180
Pe4atnik's Avatar
The dragging depends not only on spool. Check the wheels and also the hexes on shafts. they are a little bit smaller then usual wheels and have additional movement.
The spool is not the best one, but you can recheck and fill it a little. Also you should check the tightening spacers, they are black and it's hard to see if they are all right.
that part seems to be for the front, I ordered one to try. will see.
Old 03-22-2013, 09:42 AM   #1181
I had teflon washers behind the metal pins in front of the bearings. I didn't like the slop.
It caused binding and drag. Bad move. I took them off and car rolls out great now.
.crispy is offline   Reply With Quote
Old 03-22-2013, 10:13 AM   #1182
The axles contributes greatly to the binding, or chattering, when turning. I got the double CVD's, CVA's, SSD's, SSK's, or whatever the hell the word of the day is for these things.
http://www.tqrcracing.com/shop/produ....asp?p_id=4865
or
http://www.tqrcracing.com/shop/produ....asp?p_id=2767
The video in the 2nd link shows the difference.
Andy
Subaru Brat - Sand Scorcher - Rising Storm - Wild Willy II - 1967 Beetle - F350 High Lift - Stampede - Rustler - XXX-SCT - Micro Baja - XX-CR - SC10RS - B4.1FT - S1
Drive what you want. Bash when you can, race to win , but do it all while having fun.
Jeckler is offline   Reply With Quote
Old 03-22-2013, 10:18 AM   #1183
or
I would order those except for the fact that they don't say if they're 50mm or 52mm. They SAY they're for the XRay or R1. I have the S1.
Can you compare overall length to the stock ones?
Old 03-22-2013, 10:39 AM   #1184
Carlos's Avatar
The 3Racing SSK's work very well in the front of my R1 (w/spool installed). Definitely worth the money and the fit well in my car.
Carlos Marcano a.k.a Sponge Bob
R.M.I. Racing
Xray NT-1
Spec-R R1
Carlos is offline   Reply With Quote
Old 03-22-2013, 10:39 AM   #1185
I too have the S1. The SSK's are 50mm, same as stock.
That's the Spec-R version. I don't know if the xray's are the same or not.
EDIT: Actually, looking close at that pic, that's to the end of the ball. Pin to pin, the SSK is 1mm longer
Andy
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13417 Today 12:31 AM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 04:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 12:44 PM
SEO by vBSEO 3.5.0
