Old 03-07-2013, 11:57 AM   #1096
Originally Posted by pata View Post
One more thing I noticed, the sway bars installed as per manual dont move at all, tried both with and w/o shocks installed. I mean they have a little play in the supports on towers so they can roll but yet still I can go full up & down arm travel and the opposite arm never moves a milimeter, whats going on?
The arms are probably binding. If you disconnect the shocks and the swaybars, the arm should move up and down very freely. If you lift it up, it should very easily fall under its own weight. The bind is most likely coming from too much friction between the arm and the spacers on the inner hinge pin. Bind can also come from the outer hinge pin, and even the camber link ball cups if they're really tight.
-Mike
Old 03-07-2013, 01:10 PM   #1097
thank you grippgoat
though of shims first but found out later it was the outer hinge ping (wheel side) that was not totally free it moved but needed little more reaming to get free also slightly sanded the plastic holder that holds the center rod stopper so it roll better yet no slide sideways.
rebuilding half car again to get everything smooth.
yet another question on sway bars. where supposed to get the bar hold into the arms tie rod, all way in, half, just so the screw holds it? does it really matter?
pata is offline   Reply With Quote
Old 03-07-2013, 02:49 PM   #1098
has anyone compared the flex in the chassi between the r1 and s1? the s1 should be a bit softer?
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 03-07-2013, 03:24 PM   #1099
performula's Avatar
The S1 should be absolutely softer - probably better for lower traction tracks
performula is offline   Reply With Quote
Old 03-08-2013, 05:25 AM   #1100
Sway bars look like they work better now still they feel like being too soft or shock springs to hard cause there is little compensation. They tend to bend before even start moving the arm.
Got some lipos ordered today, if any european people want to get some, there is a discount code active to use and get around 6$ direct discount per batt from DE warehouse.
Turnigy nano-tech 6000mah 2S2P 65~130C Hardcase
Code:
hobbyking.com/buddy.asp?code=6DEDD262-5E6E-482C-A6DE-57C8AB8ABA1B
Old 03-08-2013, 11:38 AM   #1101
JayL's Avatar
Which top Deck is the STIFFEST?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 03-08-2013, 12:35 PM   #1102
AFAIK, there are only 2, so probably the CF one. With the tubes too.
Andy
Subaru Brat - Sand Scorcher - Rising Storm - Wild Willy II - 1967 Beetle - F350 High Lift - Stampede - Rustler - XXX-SCT - Micro Baja - XX-CR - SC10RS - B4.1FT - S1
Drive what you want. Bash when you can, race to win , but do it all while having fun.
Jeckler is offline   Reply With Quote
Old 03-08-2013, 12:46 PM   #1103
should be the one that comes std with the r1, the car is quite stiff if you use all screws in the topdeck
there are 4 different topdecks, the ones that comes with the r/s1, and the 2 option cf topdecks (softer than std r1)
i have ordered the softer versions, will also try the glassfibre chassi and topdeck (will buy a s1 just to have some spares..)
Old 03-09-2013, 07:55 PM   #1104
tiago890's Avatar
Hey guys, was at the track and broke another outer pivot pin, any one know why this keeps happening or if has happened to anyone else.
Also I seem to be getting too much body roll going hot into turns which cause car to roll over or lose the rear any one have any suggestions to correct this.
I also put 3000 diff fluid in but it leaked out, seal and rubber is good, and it was tightened down all the way any suggestions.
tiago890 is offline   Reply With Quote
Old 03-10-2013, 06:43 PM   #1105
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Chile - Southamerica
Spec R R1 and S1 cars makes debut on Chilean Nats 2nd Stage.
S1 TQ's on 13.5 Class and R1 TQ's on 8.5 Class.
On finals, S1 win 13.5 class and R1 takes 4th place on 8.5 Class (battery failure).
We are very happy with the cars and are more than excited to evolve with them on setups and performance ... soon pics and vids !
regards,
Pato Concha
EG Hobbies Factory Driver
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 03-10-2013, 08:05 PM   #1106
Pit-racer's Avatar
regards,
Pato Concha
Can't wait for those pics and set-ups. Also what other chassis were in those heats?
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 Red
Pit-racer is offline   Reply With Quote
Old 03-11-2013, 04:50 AM   #1107
performula's Avatar
Is this a copy of any car? I'm thinking a XRay from what I have read...
Old 03-11-2013, 05:21 AM   #1108
Well... Spec-R made a lot of aftermarket parts for XRay... and a lot of XRay and Spec-R parts are interchangeable... so take that for what you will...
.crispy is offline   Reply With Quote
Old 03-11-2013, 05:48 AM   #1109
spencehotbodies's Avatar
The car is a mixture off X-ray-Tamiya.
Destiny RX-10s - Xray X1- Spec-r- nosram -Trinity-Wild turbo fans
West London Race Club
spencehotbodies is offline   Reply With Quote
Old 03-11-2013, 06:06 AM   #1110
performula's Avatar
Of which parts and which cars? I'm thinking of getting a spare Xray because of it.
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
