Old 02-26-2013, 04:40 PM   #1036
Pit-racer's Avatar
My S1 don't have info on how to put these opt. swaybars in or the screws....ugh!
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 02-26-2013, 04:55 PM   #1037
nrtv20's Avatar
Yea I had to reference the R1 manual
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 02-26-2013, 04:56 PM   #1038
Download the R1 manual from:
http://www.petitrc.com/reglages/spec...SpecRR1TC.html
.crispy is offline   Reply With Quote
Old 02-26-2013, 04:57 PM   #1039
SteveM's Avatar
Trader Rating: 139 (100%+)
The S1 kit does include the hardware, just missing the sway bars and a few set screws. I used a set of sway bars from my Sakura Zero S sedan.
SteveM is offline   Reply With Quote
Old 02-26-2013, 04:59 PM   #1040
nrtv20's Avatar
Originally Posted by Chris85 View Post
But why does the S1 have 50mm in the front? I thought, the drivetrain from the R1 and S1 is the same?
I ordered the 3Racing 52mm SSK (for Xray T3) for my S1. Hope, the will fit.
Regards,
Chris
I was under the impression the S1 is 50mm because the suspension pivots supplied have more restrictions in adjustments. The R1 has the nice aluminum pieces with inserts
Old 02-26-2013, 11:23 PM   #1041
Do you have a picture for us?
Are you using the front or rear sway bars from the Sakura Zero S?
Regards,
Chris
P.S. The 3Racing 52mm SSK (Xray T3) came yesterday, and they fit perfectly the S1
Chris85 is offline   Reply With Quote
Old 02-27-2013, 03:21 AM   #1042
SteveM's Avatar
Regards,
Chris
Here are pics of my sway bar installation. I'm using both front and rear sway bars from my Sakura. I did have to trim the ends of the rear sway bar a little.
Old 02-27-2013, 08:19 AM   #1043
academygaz's Avatar
What brands of spur gear fit? Looking for another 84t 48dp gear, preferably in the UK as I need it for Friday.
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 02-27-2013, 08:49 AM   #1044
Airwave's Avatar
Xenon/HB/Yokomo/Panaracer are fitting well.
I think 3racing too...
Airwave is offline   Reply With Quote
Old 02-27-2013, 08:56 AM   #1045
nrtv20's Avatar
I used a kimbrough and it works great. Don’t think it has the large clearance holes for a motor screw but thankfully Spec-R added that 3rd mounting hole.
Old 02-27-2013, 09:17 AM   #1046
SteveM's Avatar
I'm running the RW spurs
Old 02-28-2013, 12:23 AM   #1047
performula's Avatar
This has probably been discussed but I'll post anyway.
Make sure the main belt is a little tight. The belt gets extremely close to the chassis.
I tore my rear diff gasket too, I was delicate with disassembly.
The plastic shims are extremely delicate (spur shaft) - be careful I broke one, I'll wing it.
Watch the metric screw dimensions AND double check again. I thought I saw all "M3x8s" in the shock tower diagram but the screws were actually smaller for the top two holes of each shock tower.
This is for the S1. I really have no complaints just be careful and learn from my mistakes lol.
performula is offline   Reply With Quote
Old 02-28-2013, 04:48 AM   #1048
Pit-racer's Avatar
My S1 is all completed now just waiting for my VTA body to arrive. I built it slowly and tested each part during the build for any sort of binding. Only noise right now is coming from either motor or spur shaft area.
Old 02-28-2013, 08:42 AM   #1049
I noticed on mine that the front belt actually seems to rub the cutout on the chassis. I'm tempted to take a Dremel to it. For now I just have some spare belts.
I used flanged bearing on the spur, so don't have the shims.
I ran into the same problem with the shock tower screws. I just wasn't paying attention.
Andy
Subaru Brat - Sand Scorcher - Rising Storm - Wild Willy II - 1967 Beetle - F350 High Lift - Stampede - Rustler - XXX-SCT - Micro Baja - XX-CR - SC10RS - B4.1FT - S1
Drive what you want. Bash when you can, race to win , but do it all while having fun.
Jeckler is offline   Reply With Quote
Old 02-28-2013, 08:51 AM   #1050
performula's Avatar
I thought about filing the triangular cut out of the chassis. A belt tensioner would help as well. I probably have the bulkhead tensioners set at 2pm. The belt is about .5-1mm away from the cutout. Could definitely be a potential problem.
On page six, if you look, the M3x8 diagram actually looks like M3x6 compared to page five. I'm really not rushing myself I'm just literally blind
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
