Old 02-24-2013, 01:02 PM   #1021
I buy direct from specR. Theres no spares or cars in my country
Originally Posted by SteveM View Post
The parts are relatively cheap and that's great, but my LHS won't bring in parts as I'm the only local guy running this brand. Thank goodness for TQ Racing otherwise I'd be stuck.
SpecRC is offline   Reply With Quote
Old 02-24-2013, 01:26 PM   #1022
performula's Avatar
I'd but a second kit just because of shipping... Just my opinion
performula is offline   Reply With Quote
Old 02-24-2013, 02:04 PM   #1023
SteveM's Avatar
Trader Rating: 128 (100%+)
Already have one on the way. :-)
SteveM is offline   Reply With Quote
Old 02-24-2013, 03:57 PM   #1024
GMartinez's Avatar
Trader Rating: 83 (100%+)
Local shop has parts & ships Worldwide
http://www.superiorhobbies.com/store...T+PARTS/SPEC-R
I test drove a local drivers car in a club race
Car has tons of steering was impressed
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup
2014 Hosted Events Roar Paved Electric Nationals, IFMAR ISTC Worlds
2015 Roar Fuel On Road Nationals,U.S.World Nitro Cup Completed
2016 U.S. World Nitro Cup Dec 7th - Dec 11th
GMartinez is online now   Reply With Quote
Old 02-25-2013, 04:34 AM   #1025
Originally Posted by PitNamedGordie View Post
They are meant for the rear as the fronts are 52mm.
The four I got in my S1 kit are all 50mm. Why do you say the fronts are 52mm?
This is a timely topic. I was running mine this weekend and the darn thing broke. Not at the pin area but where the axle part goes from the larger diameter to the small threaded size.
Yeah, I just double checked. All four are 50mm. Of course I put a gear diff in the front and put blades on the shaft but it sits 2/3rds of the way in. But 50mm would fit the outdrive on the spool as well.
.crispy is offline   Reply With Quote
Old 02-25-2013, 05:46 AM   #1026
Default Spec-R Spring Rates?
Are the Spec-R spring color codes the same as X-Ray?
I was looking for some stiffer springs at the race on Sunday and ended up slapping the Whites on the front and I used my AE Silvers on the rear. It worked beautifully.
So I looked up the X-Ray white and it is about the same as the AE Blues which is what I would have put on had I had them.
So if the whites are truly about 17lbs, I think I'll stick with them.
Old 02-25-2013, 06:37 AM   #1027
32819toon's Avatar
hi, my son has broken a driveshaft and a spool outdrive. I've ordered a gear diff for him and some 50mm Sport driveshafts. It is the 50mm ones I need for the gear diff in the front isn't it ?I forgot to order blades though, can Xray 3.5mm ones fit ?
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 02-25-2013, 07:02 AM   #1028
That's what I've got on mine. Of course, that's what broke on me too... With the blades, it fits well inside the outdrive. Not anywhere near the end like if it were supposed to be the 52mm.
I got a pair of blades from a X-ray guy this weekend, they fit.
Then I went back and got the worn-out outdrives that they came from...
Did you get 500,000 wt diff oil for the front?
Old 02-25-2013, 11:36 AM   #1029
32819toon's Avatar
haven't got thick oil - will thick grease do ? Might leave him with my spool in his car. I can't get to race mine, keep taking parts off for his car !!
32819toon
Old 02-25-2013, 11:52 AM   #1030
That's what I did for now. Will swap it out for oil soon.
Old 02-25-2013, 09:56 PM   #1031
spencehotbodies's Avatar
Hello
You need the 52mm for the fronts.
spencehotbodies is offline   Reply With Quote
Old 02-26-2013, 12:26 AM   #1032
Originally Posted by spencehotbodies View Post
Hello
For everyone concerned.
R1 has 52mm at the fronts, 50mm at rear.
S1 has 50mm all around.
Old 02-26-2013, 12:31 AM   #1033
But why does the S1 have 50mm in the front? I thought, the drivetrain from the R1 and S1 is the same?
I ordered the 3Racing 52mm SSK (for Xray T3) for my S1. Hope, the will fit.
Regards,
Chris
Chris85 is offline   Reply With Quote
Old 02-26-2013, 01:44 AM   #1034
Im not sure why that is. I can see from the manuals that the R1 is running more positive camber up front with the tie rods "S1"14.5mm "R1" 15.5mm so thats where the difference is made up I think. The ones you got should fit regardless. You might need to adjust your tie rods to the R1 specs.
Regards,
Chris
Old 02-26-2013, 02:44 AM   #1035
Smile
Installed 3r ssk driveshafts on my r1 yesterday and they fit perfectly
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13440 Yesterday 08:58 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
