Old 02-06-2013, 03:40 PM   #916
Originally Posted by Airwave View Post
I've measured the different blocks and re-created two tables with offsets...
Hope this helps...
Default values are in blue...
Thanks airwave,
Just 1 more question....lets say I want to make my rear car 3.5 toe in... I'm going to use rr 2 out and rf 3 out... Is that mean the track wide will be wider by 2.2 + 1.4 = 3.6.....
Is that correct?
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 02-06-2013, 05:57 PM   #917
Trader Rating: 88 (100%+)
Default VTA setup
I was asked for my VTA setup from Snowbirds, I'm not sure how to post to petitrc so I've attached it here.
Shane W.
Everything for Sale - out of hobby
tcdrvr2 is offline   Reply With Quote
Old 02-07-2013, 07:35 AM   #918
My S1 came today. But there is one bag missing . The bag with the plastics for the steering crank. Can somebody tell me, if there are more parts in this bag? Or just the 3 plastics?
Ive sent an e-mail to Spec-r, maybe they send me a bag...
greetings,
Chris
Chris85 is offline   Reply With Quote
Old 02-07-2013, 07:59 AM   #919
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Default New Chassis Options
I see Spec R is releasing new optional chassis...
Type A Upper Deck
http://www.spec-r.com/default/index....roducts_id=485
Type B Upper Deck
http://www.spec-r.com/default/index....roducts_id=486
2.2mm Chassis
http://www.spec-r.com/default/index....roducts_id=484
I'm interested in them all...
I wish I could have more track time with my car. But these options will be on my shopping list
Spec-R R1-spr-r1g753_l.jpg   Spec-R R1-spr-r1g754_l_b.jpg   Spec-R R1-spr-r1g752_l.jpg
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 02-07-2013, 03:49 PM   #920
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
why isnt there any castor blocks in different degrees..
Roberto Falcon is offline   Reply With Quote
Old 02-07-2013, 08:04 PM   #921
performula's Avatar
I'm very interested in the S1 to get back into electric and RC. I have read this thread from the front to back.
My question is what budget combo/or pieces should I get for the ESC/BL Motor and what batteries?
performula is offline   Reply With Quote
Old 02-07-2013, 08:35 PM   #922
toast.'s Avatar
What kind of characteristics should the different thickness give?
Type A Upper Deck
Type B Upper Deck
2.2mm Chassis
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 02-07-2013, 10:06 PM   #923
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
Should give you more mechanical grip. If you guys look on the website there are a bunch of other goodies like aluminum bones for the rear driveshafts, alum. Layshaft and a few other things. Also to let everyone know I have moved on to another chassis brand but feel free to pm me with any questions regarding the r1 and setup help.
jeff jenkins is offline   Reply With Quote
Old 02-08-2013, 02:01 AM   #924
has anyone tested another mfg`s casterblock on the r/s1? i would like one that isnt as soft as the std one
havent had a broken part on my car yet, but dont like the soft plastic in the blocks
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 02-08-2013, 05:25 AM   #925
greetings,
Chris
I can't remember what all came in that bag. And as we all know, they don't provide pics with the contents like other companies do.
Spec-R might have you contact the shop you bought it from for a replacement. That's what they did for me.
Andy
Subaru Brat - Sand Scorcher - Rising Storm - Wild Willy II - 1967 Beetle - F350 High Lift - Stampede - Rustler - XXX-SCT - Micro Baja - XX-CR - SC10RS - B4.1FT - S1
Drive what you want. Bash when you can, race to win , but do it all while having fun.
Jeckler is offline   Reply With Quote
Old 02-08-2013, 05:32 AM   #926
sghx60's Avatar
Does anyone know if the sakura zero front oneway spool will fit the R1
Xfactory X6/X60/ LOSI TLR22/TLR22T/TLR22SCT
TLR 22SCT Late Model
Factory Team B4/Factory Team T4
Losi Slider Sprint Car
Losi SCTE 4x4
sghx60 is offline   Reply With Quote
Old 02-08-2013, 06:29 AM   #927
Not sure but I know the Xray multi diff should fit. If you want to fork out the $$$...
http://www.nexusracing.com/product_i...oducts_id=3643
Old 02-08-2013, 07:39 AM   #928
handiman's Avatar
Default Shock caps.
Wrote awhile back with regards to problem with one of my shock caps not being able to fit securely. Wrote to Spec R and they sent me a replacement shock cap that fits snugly and eliminated the problem.
They also sent extra shock ball end which snapped whilst I was assembling.
Thumbs up for good customer service!
Originally Posted by handiman View Post
Just bought a S1 and n the midst of assembling.
Ran a T3 11' prior.
A couple of questions,
1) Anyone has limited travel or rather stiff (vertically)front and rear arms with e standard 50mm shafts and recommended tie rods lengths? If so, what is the recommended remedy?
2) I seem to have problems securely a shock cap tightly on one of my shocks. Anyone has issues? Recommended or suggested remedy?
3) Read that some of u use additional flange bearings 5x8x2.5..improved fit and performance?
4) Recommended to run with some slop in the front and rear arms or fill the gaps with spacers?
Appreciate your inputs.
Thanks.
handiman is offline   Reply With Quote
Old 02-08-2013, 09:23 AM   #929
chef88's Avatar
Trader Rating: 47 (100%+)
Have an issue
Bought the 2 generation drive shafts & broke one of the swing shafts the ones that came with the kit read Spec - R XP and the replacement shaft that I bought now twice.... read spec-r XR.
The XR binds and does not fit the XP work perfectly anyone have this problem?
Thxs
X -Ray X1.TRF 101
Rebel 12, T4 2015.
Maryland Funster/ Beneteau 373.
180 Raceway/ Johns Mobile Raceway/The Track.
chef88 is offline   Reply With Quote
Old 02-08-2013, 09:36 AM   #930
Originally Posted by chef88 View Post
Have an issue
Thxs
I'm not sure what you mean by xp and xr.
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13440 Yesterday 08:58 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
