Old 02-04-2013, 08:33 PM   #901
Josh-n-ya's Avatar
Trader Rating: 71 (100%+)
Originally Posted by big al View Post
5mm/4mm over ride height???
5mm droop in front w/droop guage! 4mm droop in rear w/droop guage! 5mm ride height all around car w/ride height guage. I literally have only been racing sedan for about 3 months. The last time was in November before our outdoor track shut down. When I started out I took my car and my set up tools to a pro driver and asked him to show me how to set up a car. This is the only set up I have tried and it works!
Josh-n-ya is offline   Reply With Quote
Old 02-04-2013, 08:56 PM   #902
corallyman's Avatar
Trader Rating: 97 (100%+)
Originally Posted by Josh-n-ya View Post
Hey, Still running the Xray! Although, Jeff's car a few post up seems tempting. Cant wait to see your R1 in action! Im so undecided, but my wallet has told me no more new toys.
I race with Jeff every race up here in Seattle, and his car is one of the fastest cars at the track and we have multiple big race winning drivers up here. If you are thinking about buying a car then his would be the way to go. You're getting alot of stuff with it too. Somebody should jump on it.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 02-05-2013, 07:15 PM   #903
Caleb_Bush's Avatar
Trader Rating: 27 (100%+)
Default Similar situation on R1
Originally Posted by Xenolance View Post
You'd need +.75mm wheel hexes. Something like these:
http://www.nexusracing.com/product_i...roducts_id=291
Something is causing the front wheels on my R1 to wobble when steering. I am using the stock alumn. hexes.. any ideas?
Caleb_Bush is offline   Reply With Quote
Old 02-05-2013, 08:24 PM   #904
When steering, or when rolling? Just the fronts? Did you try swapping front to back? To check the hexes, make a mark of the high spot on the wheel edge, then rotate the wheel 1/6th on the hex and check again. If the mark is still in the same spot, it's probably the wheel.
On a similar, I just ordered a set of 6 and 7mm hexes off eBay. I need at least 6 to clear the HPI vintage wheels I have.
http://www.ebay.com/itm/Cappu-Hex-wh...item2ec1a4b7ca
And TQ RC is taking care of my missing body post after Spec-R told me to contact them. Kinda cruddy, as it wasn't TQRC's fault it was missing.
Andy
Subaru Brat - Sand Scorcher - Rising Storm - Wild Willy II - 1967 Beetle - F350 High Lift - Stampede - Rustler - XXX-SCT - Micro Baja - XX-CR - SC10RS - B4.1FT - S1
Drive what you want. Bash when you can, race to win , but do it all while having fun.
Jeckler is offline   Reply With Quote
Old 02-06-2013, 02:14 AM   #905
Default suspension mount
Hi guys..
I have a question regarding the suspension mount...
does it change the track wide for example for the rear of the car if i change form 3 dot to 1 dot...
3dot with 3 dot is 3' toe in..same as 1 dot and 1dot also give 3' toe in....but it is make the track wide wider or still the same...
thanks
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 02-06-2013, 03:36 AM   #906
Airwave's Avatar
I've measured the different blocks and re-created two tables with offsets...
Hope this helps...
Default values are in blue...
Airwave is offline   Reply With Quote
Old 02-06-2013, 06:29 AM   #907
32819toon's Avatar
i have 2 set of new unbuilt shocks and 2 sets of oils from S1 kits for sale if anyone is interested.
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 02-06-2013, 06:48 AM   #908
sghx60's Avatar
Got a question. This is my first ever on road car. There is a club were i live that races vintage trans am. They run 25.5 brushless motors in them. My question is what would i run for a pinion and spur gear and what would a good starting setup be.
Xfactory X6/X60/ LOSI TLR22/TLR22T/TLR22SCT
TLR 22SCT Late Model
Factory Team B4/Factory Team T4
Losi Slider Sprint Car
Losi SCTE 4x4
sghx60 is offline   Reply With Quote
Old 02-06-2013, 07:51 AM   #909
Trader Rating: 88 (100%+)
Default Snowbirds
I don't know if anyone noticed but I put my R-1 in the VTA a-main at snowbirds, qualified 9th finished 7th, the car was working great for only it's 2nd VTA race. I wanted to try it in stock as well but ran out of time.
Also during the main I was closing in on a driver running an a700 kind of fun seeing the cheapest car on the track catching the most expensive.
Shane W.
Everything for Sale - out of hobby
tcdrvr2 is offline   Reply With Quote
Old 02-06-2013, 08:00 AM   #910
Trader Rating: 37 (100%+)
96 spur and 45 pinion for 64p
72 spur and 33/34 pinion for 48p
Either of those will get you right close to a 4.0 final drive ratio and should give you some room to gear faster if you need to.
I just ran my S1 chassis in Oshkosh for the first time last weekend, stock setup per the instructions with the exception of a couple wheel spacers up front to keep the wheels from rubbing...couldn't be happier with the results.
Good luck with yours.
Ropes is offline   Reply With Quote
Old 02-06-2013, 08:13 AM   #911
fox88gt's Avatar
Hows it going buddy! Dont mind me for dropping in on this thread. I must say I saw rope's Spec R run last weekend, and I was more impressed by that car than the new Xray T4. Great chassis.
Jeff
"When you no longer go for a gap, you are no longer a racing driver..." Ayrton Senna
"I dont like being overtaken. It's a sign of weakness." Jeremy Clarkson
"Leave me alone....I know what I'm doing." Kimi Raikkonen
I don't always race RC....but when I do....I prefer road course.
fox88gt is offline   Reply With Quote
Old 02-06-2013, 08:18 AM   #912
nrtv20's Avatar
Nice work!
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 02-06-2013, 10:29 AM   #913
Caleb_Bush's Avatar
When steering and just the fronts. Going to try the 6mm and 8mm hexes.
Old 02-06-2013, 11:50 AM   #914
Pe4atnik's Avatar
Rather good news for Spec-R lovers)))
We have just returned from Russian Onroad championship, wich took place near Tumen)))
Me and my s1 chassis took 3d place in Stock 13,5 class...
The car is mostly from the box, I just had to put some spares from yokomo (front bumper), because I was short in spares))
That was not easy, the carpet there has low traction and short hair? (sorry I don't know the word), local guys know the track well, and the borders are made from still. I love my spec-r that's a very durable car!)))
Bears, Vodka, RC Racing
Pe4atnik is offline   Reply With Quote
Old 02-06-2013, 02:42 PM   #915
i see that spec r has released some new options, 2.2mm chassi, 2 new topdecks etc
very interested in trying the new chassi!
http://www.spec-r.com/default/index....cPath=39_74_71
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Schumacher Cougar KF2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13417 Today 12:31 AM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 04:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 12:44 PM
SEO by vBSEO 3.5.0
