Old 02-02-2013, 01:13 AM   #886
I think we're on the same page actually. With the 3mm spacers in the back, I couldn't get the toe block to sit flat. Sounds like the same thing you're getting. I swapped out the 3mm spacer for the 2mm, and used two 1mm spacers for each of the rear camber link ball studs instead.
I did the same thing up front, and have some shims if needed.
Andy
Subaru Brat - Sand Scorcher - Rising Storm - Wild Willy II - 1967 Beetle - F350 High Lift - Stampede - Rustler - XXX-SCT - Micro Baja - XX-CR - SC10RS - B4.1FT - S1
Drive what you want. Bash when you can, race to win , but do it all while having fun.
Jeckler is offline   Reply With Quote
Old 02-02-2013, 07:00 AM   #887
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Xenolance View Post
Sad to see ya go to another platform Jeff, where ya going next?
I'm going to be switching to the new serpent .
Serpent project 4x
jeff jenkins is offline   Reply With Quote
Old 02-02-2013, 11:35 AM   #888
I'm building the shocks right now and the supplied bottle of 500 (cst I presume) is only about a 3rd full. I doubt I have enough to fill all four. I have some 35wt, but I'm thinking that will be a little light (I used the 3-hole pistons). Should I get some 40wt to start just to be on the safe side? I don't want to have to take the shocks apart to change pistons. I'll be running outdoors on asphalt set up VTA.
I bought a set of droop plates to keep the screws from digging into the chassis, but am starting to wonder if they're really necessary and if they'll hurt more than help. With them installed and the screws backed out, the arms sit level. Should I bother? I haven't run TC in 20 years and the TA-02 I had didn't even have droop adjustability.
And, does anyone have a spare rear body post? One of mine was missing from the box/bag/tree.
Andy
Old 02-02-2013, 02:13 PM   #889
For outside with 3 hole pistons 35wt would be a good place to stat actually.
Serpent project 4x
Old 02-02-2013, 04:34 PM   #890
Fuzzi0n's Avatar
As for the body post, contact Spec-R and they'll hopefully be able to help out.
35wt would be a good starting point as Jeff said although if you've got 3/4 of the stock shock oil it should be enough if you want to use it, I had quite a bit left but maybe my bottle had more in.
Spec-R S1, Schumacher CAT SX3 S1
Fuzzi0n is offline   Reply With Quote
Old 02-02-2013, 08:42 PM   #891
I sent them an email from the Contact Us link on their site. We'll see what happens.
And I don't have 3/4 of a bottle, I have 1/3 of a bottle. I'll try the 35wt, plus I got a bottle of 40wt today.
Another question....
Does anyone use the stiffeners (tubes) that come with the S1? There's one that goes between the steering rack and top deck and another between top and bottom. I'm guessing that's what they're for since the manual doesn't seem to make any mention of them and they fit in those places.
And a silver can Johnson motor will fit the mount if you take a Dremel to it and grind a little bit out of it, otherwise the front bushing is in the way.
Andy
Old 02-02-2013, 08:51 PM   #892
Fuzzi0n's Avatar
1/3 wouldn't be enough, misread your post there.
I don't use those stiffeners, not sure if anyone else does. That is what they're for though.
Old 02-03-2013, 08:11 PM   #893
reichsmarshal24's Avatar
Hi Guys,
Just finished with my S1 build (my first touring car build). The suspension arms seem to be really binded when screwed to the chassis with the suspension mount adapters. I'll see after a few runs if the plastic loosen up a bit. If not, I'll file some of the spacers and ream the suspension arm holes.
Being a noobie in TC, I built my S1 based on the manual's instructions and noticed that the front and rear ride height are at 7 to 9? How do I lower the ride height and change droop? Do i do it by just lowering the set screw on the suspension or by adding spacers as well?
Thanks!
[F104 V2 Pro][F103 RM][Spec-R S1]
[Sanwa MT4][Simple Green][Mountain Dew][SkyFlakes]
reichsmarshal24 is offline   Reply With Quote
Old 02-03-2013, 10:34 PM   #894
Originally Posted by jeff jenkins View Post
Still up for grabs.
Serpent project 4x
Old 02-03-2013, 10:45 PM   #895
Spec-R referred me back to TQRC, so now I sent them an email.
What's on 2nd, right?
Andy
Old 02-03-2013, 10:58 PM   #896
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Originally Posted by reichsmarshal24 View Post
Hi Guys,
Thanks!
Look up droop and ride height or Set up on U-Tube! It might help you out more visually. Droop is the set screw on arm. Ride height is adjusting shocks. You will need some set up tools if you dont have them yet! I use 5mm droop in front 4mm droop in rear and 5mm ride height all around! Hope that helps
Josh-n-ya is offline   Reply With Quote
Old 02-04-2013, 07:54 PM   #897
big al's Avatar
5mm/4mm over ride height???
big al is offline   Reply With Quote
Old 02-04-2013, 08:00 PM   #898
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
I'm sure he means on a droop gauge.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 02-04-2013, 08:06 PM   #899
team green's Avatar
Hey, Josh did you get a R1? Or you still running a X-Ray? This is Jason by the way I race mini with you at Nor-Cal. I got a R1 for this up coming season. Haven't got to test it out yet though.
I will never go back to brushed motors or NIMH's!!!!
Awesomatix EVO2
Xray XB2 CE
team green is offline   Reply With Quote
Old 02-04-2013, 08:30 PM   #900
Josh-n-ya's Avatar
Hey, Still running the Xray! Although, Jeff's car a few post up seems tempting. Cant wait to see your R1 in action! Im so undecided, but my wallet has told me no more new toys.
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13420 Yesterday 11:34 AM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 04:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 12:44 PM
SEO by vBSEO 3.5.0
