Old 01-14-2013, 08:33 AM   #766
jeff jenkins's Avatar
Trader Rating: 75 (100%+)
Originally Posted by k4mp4q View Post
Hi Guys...
I'm finally pull the triger on purchasing this car...
Anyway i'll be using it for this coming TITC Race on february...
I'll be going to play 13.5 open brushless...
So any of you guys have a good setup for the start on this layout...
I would recommend the setup I just posted . If it has too much roll for you just shorten the upper links and you will get some more response.back. It's a very easy to drive setup.
Maclan Racing Products-RC US Imports - Sworkz USA - Bellgate Distributions
jeff jenkins is offline   Reply With Quote
Old 01-14-2013, 08:44 AM   #767
nrtv20's Avatar
Jeff,
I see that over time your setups have seemed to increase the thickness of the rear oil in the gear diff; have you tried running the Spec-R solid rear diff insert? I ask for two reasons, one is I can’t build the rear diff to hold oil at all but I see there is a version 2 gasket I want to try and the other reason is when exiting a corner if I get on the throttle quickly the car wants to keep turning coming out of the corner, going from 500 to 1000 to 5000 has helped but just curious on your thoughts?
Thanks for your help in advanced - Nick
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 01-14-2013, 08:57 AM   #768
32819toon's Avatar
Originally Posted by nrtv20 View Post
Jeff,
I see that over time your setups have seemed to increase the thickness of the rear oil in the gear diff; have you tried running the Spec-R solid rear diff insert? I ask for two reasons, one is I canít build the rear diff to hold oil at all but I see there is a version 2 gasket I want to try and the other reason is when exiting a corner if I get on the throttle quickly the car wants to keep turning coming out of the corner, going from 500 to 1000 to 5000 has helped but just curious on your thoughts?
Also, I've always used grease in diffs, is this an option or should I use the 5000 oil ? I've bought 2 S1 cars, 1 for me and 1 for my son.
Anything I need to look out for when we build the cars ? Do Xray spur gears fit the S1 ? I have quite a few of these.
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 01-14-2013, 10:13 AM   #769
I prefer the consistancy of silicone oil over grease. But I do not want to lock the rear up as then I would have poor steering unless I steer with the throttle. But to stop the leaking take apart your diff and wash it real good with soap and hot water . Then let it dry and cool off. Then where your xrings go heavily coat that are of the cases with associated green slime. Also tighten the case down so it compresses the outer oring seal really good. And you should be good. The car already comes with all the v2 parts.
Old 01-14-2013, 10:34 AM   #770
nrtv20's Avatar
Maybe I'm not tightening the diff case enough, I'd rather use oil as well if I can get it to stay in there!
Old 01-14-2013, 11:05 AM   #771
Fuzzi0n's Avatar
Make sure its tight and make sure you do the screws up evenly. Also I'd really recommend using a lot of Green Slime on the o ring and around the edge of the diff where the two sides meet, you shouldn't have any issues then. Thicker oil might help too, I'd have thought 5000 would take a lot more time to do anything than 1000 would.
I rebuilt my one and found it leaked afterwards, despite not doing it originally, when I rebuilt it again I just used a ton of Green Slime and really made sure I did it up properly, no issues since.
Spec-R S1, Schumacher CAT SX3 S1
Fuzzi0n is offline   Reply With Quote
Old 01-14-2013, 04:29 PM   #772
Default R1 Set-up
hi Gents,
i have just finsihed building my R1 and was wondering if you could give me a set-up to use on an medium grip Asphalt service.
Schumacher Mi4 & Mi3.5.
Hobbywing Stock Xtreme
17.5 Trinity Duo Version 1.
steve_windsor is offline   Reply With Quote
Old 01-14-2013, 07:51 PM   #773
Thanks Jeff...
But your setting is for carpet.... will it be the same with the ashpal setup?
And will you going to titc?
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 01-14-2013, 07:58 PM   #774
Should still work
Old 01-14-2013, 08:07 PM   #775
Airflow's Avatar
Here's my S1 running on Reventon R with Ballistic high RPM 10.5, TRF shocks and Audi R8 shell.
Airflow is offline   Reply With Quote
Old 01-14-2013, 11:25 PM   #776
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
TITC is so much of a different track and event that a conventional set up really won't work....
My absolute best advice would be look at what the Tamiya set ups are like and go from there....
And to the person that asked, no Xray spurs do not fit.
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 01-15-2013, 02:47 AM   #777
Thanks Luke...
What about your asphal base setup.... is that good enough to start on that...
And can you post your aeration shocks ....what is that? what is the different with the oil shock..
Old 01-15-2013, 03:29 AM   #778
Hiya,
I'm not too sure my asphalt set up will be of much use tbh, again it's such a unique race it's a tricky one to advise on.
To be honest I've ditched the aeration dampers now, they just didn't feel like an advantage on track,
but the basic idea is;
Drill a small hole in the shock top
Thread the hole with a small set screw from the hinge pins to the AE tc6 arms.
That screw will be the bleed screw.
Then I epoxy the shock top to the shock cap to be sure it's sealed.
Once that's set, either trim the std shock bladder, or get the correct sized o ring and use that as a seal.
Hope that makes sense to everyone lol
Luke Hobson
Old 01-15-2013, 02:48 PM   #779
Hey guys,
Im building my gear diff and notice about .2mm and .4mm play on the out shafts after shimms are in. Is this ok? Or should i try to get a .2mm extra shim to remove the play.
Is it bad if i run with the play? Cause it could be hard to find the right shim
Also did you guys green slime your diff gasket?
SpecRC is offline   Reply With Quote
Old 01-15-2013, 07:22 PM   #780
Send a message via AIM to Johnnytc3
How durable is this car?
I am about to place and order for a couple S1s to mess around with and from what I am reading, should get the following right away:
1)Tamiya ball cups
2)Aluminum hexes
3)Roll bars
3)Diff gear gasket version 2??
4)5x8x?? Flanged bearing for the lay shaft
What spare parts should I get? It seems like the only thing that are breaking are shock caps from what I read?
Johnnytc3 is offline   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
