Old 01-08-2013, 08:17 AM   #736
BigC123's Avatar
Originally Posted by Josh-n-ya View Post
Has anyone tried the Spec R 10th scale sedan body? What did you think? I have the Spec R mini sedan body and it works good! Just thinking about trying out the 10th scale one.
I Get My bodies from Speed passion USA , they are Mazda Speed 09 clones and they are only $6.75 a piece right now on there web site. Great Deal!!!
I think they have a few left but they will be getting some in soon.
Clayton "BigC" Neal
Caster Racing USA
SpecR R1
XRAY T3R
Speed Passion USA
BigC123 is offline   Reply With Quote
Old 01-08-2013, 07:05 PM   #737
Trader Rating: 24 (100%+)
What would be a good place to start gearing with a 21.5 on a small technical carpet track?
goodhews is offline   Reply With Quote
Old 01-08-2013, 07:57 PM   #738
C&B RC's Avatar
You should always gear to temp. But assuming you are running blinky mod/ non-programmable ESC with a fan, I usually start around 4.2 FDR -temp the motor => OK= add motor timing -temp the motor => OK add 1-2 teeth to pinion - temp the motor. Drag brake and driving style can also affect the running temp .
It's all fun & games til the flying monkeys show up!
C&B RC is offline   Reply With Quote
Old 01-08-2013, 08:49 PM   #739
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Wow! Pretty cheap! Dont know if thats a good thing or not, but worth trying! Maybe good for club racing! Thanks
Josh-n-ya is offline   Reply With Quote
Old 01-09-2013, 05:31 AM   #740
HK416's Avatar
Hi ! I was running 10.5t the other week with my R1 and was doing some fantastic laps. Even some of the A main drivers was amaze however after a few rounds I totally ran out speed and punch, thought was some ESC issue. Checked and the gear diff was totally gone. I open up the diff cups and found the gears totally worned. I've ordered a few packs of the gear set. I find that gears are smaller compare to others eg. Sakura. Is the new pack will be tougher ?
RC FOR FUN, NOT STRESS.
HK416 is offline   Reply With Quote
Old 01-09-2013, 06:02 AM   #741
trickd122's Avatar
I have used them and it's excellent value and to me good quality. I have done back to back testing with the PF speed 6 and have found little difference, but I still prefer the LTCR for most of the tracks that I run on. There are optional wings that are included too.
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 01-09-2013, 06:20 AM   #742
Fuzzi0n's Avatar
Next time you build the diff make sure that the gears mesh correctly, you might have to add a few shims to make sure. Some of us have had to shim it, some haven't, just keep it in mind.
Spec-R S1, Schumacher CAT SX3 S1
Fuzzi0n is offline   Reply With Quote
Old 01-09-2013, 07:10 AM   #743
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
I was running a 4.0 with boost and this happened to me at my last race but I just went to speedtechhobbies.com and ordered the steel gear diff gear set for the 417. Which there geardiff is made by spec r and they should drop right in .
jeff jenkins is offline   Reply With Quote
Old 01-09-2013, 07:27 AM   #744
HK416's Avatar
Yeah ! I was thinking for steel gear diff too !Thx !
Old 01-10-2013, 03:27 AM   #745
SteveM's Avatar
Trader Rating: 127 (100%+)
Originally Posted by SteveM View Post
Has anyone upgraded the shock set on their S1 to the R1 shocks? I'm looking for one red shock cap as one of mine split and I now have one leaky shock. Anyone?
I heard back from Spec-R on the issue of my split shock cap, and they expect me to buy a replacement. As a special favor they will sell me one shock cap for $8 shipped. I was hoping for a free replacement.
SteveM is offline   Reply With Quote
Old 01-10-2013, 07:43 AM   #746
If it were more of an issue I am sure they would have replaced it for free. However I do not believe there has been anyone else, or very few that have had a cap split.
Mikes Hobby Shop--> mikeshobbyshop.com
-Viper-RC Solutions-
Team Tree Top!
Damon_English is offline   Reply With Quote
Old 01-10-2013, 09:37 AM   #747
Fuzzi0n's Avatar
That and they don't know for sure what caused it. In this case it may have just been defective but if they replace it for free, people will start asking for replacement parts that they've broken. If it was split before you built the car I'd expect they would have sent one out for free too, but when you've built the car and run it they cant be 100% sure you didn't damage it. Not saying you did, but you can understand their decision.
Old 01-10-2013, 12:03 PM   #748
spring71's Avatar
Smile
Spec-R Carbon Graphite Bumper Holder is in stock now.
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 01-11-2013, 08:49 AM   #749
handiman's Avatar
Default Shafts and tie rods
Just bought a S1 and n the midst of assembling.
Ran a T3 11' prior.
A couple of questions,
1) Anyone has limited travel or rather stiff (vertically)front and rear arms with e standard 50mm shafts and recommended tie rods lengths? If so, what is the recommended remedy?
2) I seem to have problems securely a shock cap tightly on one of my shocks. Anyone has issues? Recommended or suggested remedy?
3) Read that some of u use additional flange bearings 5x8x2.5..improved fit and performance?
4) Recommended to run with some slop in the front and rear arms or fill the gaps with spacers?
Appreciate your inputs.
Thanks.
handiman is offline   Reply With Quote
Old 01-11-2013, 10:55 AM   #750
Fuzzi0n's Avatar
Ran a T3 11' prior.
Thanks.
1) No, not had any issues with that. Have you checked to see what's causing the issue?
2) Not had that issue, SteveM had one crack, perhaps your one has done the same?
3) Flanged bearings take up the slop in the layshaft, there are also longer bushings available from Spec-R to do the same job, although they can cause issues with thicker spur gears.
4) Run them as tight as you can before it restricts the movement. If you have to have a slight gap to make sure the arms move completely freely then run that - I found the kit spacers were fine at the rear but the front 3mm spacers needed a quick rub on a file/sandpaper to get everything nice and free.
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13439 03-03-2017 02:56 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
