Old 12-27-2012, 07:18 PM   #661
CristianTabush's Avatar
Correct. With the wide axle, there is no need to replace bearings. The car uses 5x10x4 on the inside and outside of the hub. With the Narrow Axle, you replace the inside bearing on the hub carrier with the provided 5x10x3 bearings.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 12-27-2012, 10:10 PM   #662
I see. Interesting for sure! I may have to try it at some point.
Mikes Hobby Shop--> mikeshobbyshop.com
-Viper-RC Solutions-
Team Tree Top!
Damon_English is offline   Reply With Quote
Old 12-27-2012, 11:16 PM   #663
Suspended
very nice thanks for sharing
Brett Wilson
Don't Worry Be Happy..
brett546 is offline   Reply With Quote
Old 12-28-2012, 01:39 PM   #664
SteveM's Avatar
Trader Rating: 133 (100%+)
Received my TQ order #2 today with a new lower front bumper to replace the one that shattered last race. I splurged for Christmas and grabbed the R1 motor mount while I was placing an order and it all went together great.
I'm still using the stock S1 plastic bushings and plastic spacers and I have just a tick of play in the center spool which is perfect. I have the flanged bearings but haven't felt the need to use them. Maybe I did something right, or inadvertently wrong but there is virtually no slop.
I did have to remember to add the 1mm spacers on top of the R1 motor mount.
SteveM is offline   Reply With Quote
Old 12-28-2012, 01:49 PM   #665
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
It all depends on the brand of spur gear that you use
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 12-28-2012, 01:53 PM   #666
SteveM's Avatar
I'm using a RW Racing white spur gear at the moment.
My S1 upgrades so far include the R1 motor mount, optional red alloy steering servo mount, R1 red clamp wheel hexes and a Tamiya HD servo saver.
Old 12-29-2012, 08:03 PM   #667
spring71's Avatar
Smile
SPR-R1H721 Spur Gear Shaft Bushing Long (POM) and Spe-R spring set is available at TQ.
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 12-30-2012, 09:25 AM   #668
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Thumbs up
Was waiting for this post. Are you guys shipping on Monday?
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 12-30-2012, 10:17 AM   #669
spring71's Avatar
Smile
Yes, we do.
Thanks.
TQ RC RACING
Online Shop
tq@tqrcracing.com
Old 12-30-2012, 09:32 PM   #670
BigC123's Avatar
Just recently purchased the R1. It is a great car, easy to drive and durable. I'm glad I made the purchase .
Clayton "BigC" Neal
Caster Racing USA
SpecR R1
XRAY T3R
Speed Passion USA
BigC123 is offline   Reply With Quote
Old 12-30-2012, 09:42 PM   #671
Hi all. I just finished putting together my new S1 that I got for Christmas. I plan on using it for my new Spec/VTA car. It is replacing my old TC3. Anyway my question is what Spur/Pinion combo would you guys recommend. I want to use 64 pitch gears and I need my FDR to be around 3.5. We use Novak 25.5 motors at my club. I did some quick math and a 88 Spur / 48 Pinion would be about right. But it is hard to tell what combo would fit correctly - also what brand of Spur gear do I need? Anyone have some experience with this situation? Thanks in advance for any info!
Ziggo is offline   Reply With Quote
Old 12-30-2012, 11:52 PM   #672
I like the kimbro gears, i'd look at getting something close to 100t for the spur and the appropriate pinion. I am not running VTA but I am around 3.7 with 96t / 49t, you could hit 3.5 with a 52t pinion. I am not sure an 88 / 48 is going to fit to be honest.
mupchu is online now   Reply With Quote
Old 12-31-2012, 01:01 AM   #673
Is it correct that the 52mm driveshaft goes in front and the 50mm driveshaft for the rear? This makes the trackwidth in front longer than the rear. 186mm front, 183 rear. Is it really like that? Thanks.
goodvibes is offline   Reply With Quote
Old 12-31-2012, 06:55 AM   #674
trickd122's Avatar
Contrary to popular belief wider isn't always better (Remember that Pontiac AD). Most TCs are moving to this trend But yes the rears take the 50mm and 52mm fronts. I did this to my T3 and where it does make the car harder to drive it allows for more stability at higher speeds during cornering. My R1 with this setup is great.
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 12-31-2012, 07:56 AM   #675
Trader Rating: 1 (67%+)
Send a message via AIM to racer034life
I may have to buy this car and a few spares to play around with. Are any of you racing this at your local clubs. If so are you racing carpet or out doors? how does the car handle?
racer034life is offline   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13450 04-21-2017 01:38 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
