Old 12-23-2012, 02:21 AM   #631
spencehotbodies's Avatar
Hello
You running 2 on the rear? It's always best to get rid of the rubber from the middle of the tyre.
spencehotbodies is offline   Reply With Quote
Old 12-23-2012, 03:15 AM   #632
HK416's Avatar
Originally Posted by spencehotbodies View Post
Hello
Thanks ! I like the car very much and just ordered the floating servo mount and spur new white axle inserts that eliminate the freeplay. What about the roll centres ? Have you guys fiddle around with it ?
RC FOR FUN, NOT STRESS.
HK416 is offline   Reply With Quote
Old 12-23-2012, 07:40 AM   #633
jeff jenkins's Avatar
Trader Rating: 75 (100%+)
Roll center is something I am going to try again I . Raising the mounts made the.car too edgy before at my track but its worth another shot.
Maclan Racing Products-RC US Imports - Sworkz USA - Bellgate Distributions
jeff jenkins is offline   Reply With Quote
Old 12-23-2012, 10:13 AM   #634
Cool
I have fitted the top pulleys, and that made the drive train very smooth.
Old 12-23-2012, 12:19 PM   #635
trickd122's Avatar
Originally Posted by toast. View Post
Bought my Spec-R today and im excited for my build but trying to get all my pieces together.
Will a Protoform P37 body with holes cut for a xray t3/t4 fit a Spec-R?
Also what wheels/tires are recommended for indoor carpet (TQ Racing)?
I have an X-ray t3 '12 and all my bodies fit the SpecR 100% not even a mm off!!
I borrowed my buddies t2 009 body a Mazda 6 that also fitted 100%
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 12-23-2012, 02:52 PM   #636
toast.'s Avatar
Awesome - thank you!
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SCT410, SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 12-23-2012, 03:16 PM   #637
Cool,
Look forward to hear how the white spur bushes go
SpecRC is offline   Reply With Quote
Old 12-23-2012, 06:31 PM   #638
big al's Avatar
For any of you guys that have some tamiya parts laying around, ta05 front roll bars fit the f/r of the S1. A few degrees of bending is all that is necessary.
big al is offline   Reply With Quote
Old 12-23-2012, 07:25 PM   #639
Originally Posted by artwork View Post
I don't want original...I want good at a reasonable price...you guys (not you specifically) can keep the funny looking high maintenance touring cars that don't make anyone any faster or slower. It makes sense to leverage what is already working, being original is very expensive and usually leads to some impulse buys by some and then flounders in the market after the initial wow factor wears off.
It seems to me like they got a lot right from the outside looking in on this car. Who knows how good it will be, but I think they went the right way which is a lower cost kit with all of the features expected in Luxury touring cars.
Hi all ....im been using this kit currently...before im running Yokomo BD5 wxi and VBC...honestly iam saying from my experiences running this specr r1 is ALSO the best car and stable. simple setup...13.5t running smooth and STABLE. good handling and fast respond on technical. got experience on VBC....but difficult to find a good setup...but for spec r ???? for me no regret...for the plactic part such arm chub and others may say 15% less stronger then YOKOMO part..
EPGUY2011 is offline   Reply With Quote
Old 12-23-2012, 08:35 PM   #640
racer x 1's Avatar
Trader Rating: 27 (100%+)
So im about 70% done with my R1 Build and as I was messing with my CVD's I noticed 3 of my 4 are drilled for the use of a set screw to hold the pin and the 4th is not. as I now took a closer look at that one I noticed that, that cvd has MUCH more slop in the joint than the rest. Disassembled the joint to find that all looks fine just tolerances being off. Can anyone aid me in getting a new 50mm cvd?
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 12-23-2012, 09:19 PM   #641
HK416's Avatar
Hi , I've did a few runs this morning at my local track in Kuala Lumpur. The track condition is bumpy with medium traction. Since the car now has good handling, I've tried to optimize the mid sections of the track . I'm using ORCA MK 2 with Ver. 3 software. and reduce a bit all the settings to suit the 10.5t torqy SP motor and now it works well too in the mid section . The car runs pretty well ! Can't wait to race next month in our ORCA championship. The last round a Spec R driver won in the Blinky 17.5t. I saw the footage and the guy just hold his line till the end, second finisher was fast but did some mistake in field.
Old 12-23-2012, 09:22 PM   #642
HK416's Avatar
Originally Posted by SpecRC View Post
Cool,
Should be in my hands by next week, will let you know soon. Should solve the problem of placing the spacers that take a lot of time !
Old 12-23-2012, 09:48 PM   #643
Contact spec-R directly. You might need to take a photo of it but im sure they would send a new part out to you
Old 12-24-2012, 06:57 AM   #644
trickd122's Avatar
Well let me give this a go. I have found that the higher roll center in the rear works well as well as a Lower rc in the front. Keep in mind this depends on what you want to accomplish. My objectives was tire wear and traction levels. The track was high speed and this helped with the digging feel going into the corner. This car runs very similar to my T3' 12 but a lot easier to adjust loosen the screws and slide under the blocks. The xray was a huge ordeal. I have tested this car in mod and 17.5 blinky. This car is awesome!
Old 12-24-2012, 08:33 AM   #645
toast.'s Avatar
What steering servos are you guys running?
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
