Old 09-19-2012, 11:58 AM   #46
racer x 1's Avatar
Trader Rating: 27 (100%+)
Manual please
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 09-19-2012, 11:59 AM   #47
CristianTabush's Avatar
The car is slated to ship to dealers on October 1st from their Hong Kong Office.
We already have a pre-order up for them. From what I have been told the first batch is not very large, so it is best to reserve them at your favorite retailer ASAP.
There is no release of the manual yet, but as soon as they have it, I will try to get it uploaded.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 09-19-2012, 02:27 PM   #48
racer x 1's Avatar
Are you going to carry a full line of parts as well?
Matt Bell
Old 09-19-2012, 02:39 PM   #49
That is the plan right now.
By the end of the month/ early October we should be a full line shop for TC6/TCXX/Spec-R R1 and some 417.
We are also bringing on bodies, speedos, batteries and motors and other miscellaneous TC-related items. Our focus is going to be Touring cars exclusively for now.
Old 09-19-2012, 07:10 PM   #50
B00t13g's Avatar
Glad to see you supporting the car Christian!
B00t13g is offline   Reply With Quote
Old 09-20-2012, 06:24 AM   #51
Xenolance's Avatar
Sa-WEET! I was looking for a modern TC to run and since I race with you Thursday nights I wanna get one of these! I'll be looking for the preorder on your site!
Xenolance is offline   Reply With Quote
Old 09-20-2012, 06:26 AM   #52
GasGod's Avatar
Any Idea when the "sport"version will be released?
lookin for a new VTA ride
altho-the std kit looks good
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 09-20-2012, 08:30 AM   #53
That, I do not have information on yet.
Old 09-21-2012, 12:34 PM   #54
The manual is now online : http://www.spec-r.com/default/pdf/R1...tionManual.pdf
One really cool thing is the suspension mounts. Pivot ball and inserts. Way cool.
Old 09-21-2012, 12:59 PM   #55
MikeXray's Avatar
Trader Rating: 73 (100%+)
Well I found the first part to fix I hate the photon style spur gear holder, but even worse if the layshaft setup, how do they expect you to get those 2 shims on the inside of the bulkhead, and why should you even need them? maybe reverse that sleeve and put the lip on the inside to replace the shims..
I have to say that little tie rod tool makes way too much sense! I want one.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-21-2012, 02:07 PM   #56
It does look pretty badass. The spur gear situation doesn't look too bad. The TC6.1 had shims on the inside if I remember correctly. I'm guessing it probably doesn't matter whether you put the layshaft in from the left or the right. You could always remove the right-side layshaft bulkhead, it's only 2 screws. Then you could put the layshaft in from the motor mount end, and it'd be easier to slip the spacers on.
The shock rebound tool is pretty sweet. I wonder if that is plastic or aluminum.
The gear diff outdrives are ball-bearing supported, which is kinda cool if they don't fill up with leaked silicone oil. It's interesting that it uses both the paper seal and an o-ring as well.
The gear chart goes nowhere near blinky stock ratios... Hopefully there's enough range in the motor to make something work.
I like the xray-style shock mounting.
Set screws on the outer hinge pins will hopefully keep slop at bay.
I wonder what size the holes are in the pistons.
I wonder why it doesn't use the normal C-Rated Spec-R springs?
No floppy body mount things in the front. :/
-Mike
Old 09-21-2012, 02:18 PM   #57
Hey, for 290.00 USD, it literally has unbeatable value. I am hesitant to speak for durability, as it is untested, but it should make for a great asphalt car where barriers are not as tough. This car should get a lot of fresh blood into on-road.
Old 09-21-2012, 02:30 PM   #58
2-Bad's Avatar
Trader Rating: 24 (100%+)
Would be good to see optional parts like alloy center pulleys, alloy servo mount, DCJ shafts, steel spool drive cups, and one peice main pulley (no gluing)... imo
Love the Kit Tool, Fan mount, Steering brace, and Sway Bar mount.
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 09-21-2012, 03:12 PM   #59
I bet all those will be aftermarket options from Spec-R, it's just that at the price point, it is tough to include them.
Old 09-21-2012, 03:27 PM   #60
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
This gear diff is looking better then anything else I have seen so far...it has bearings for the out drives and o-ring + gasket it should not leak. Just looking over the manual it looks like its very well thought out as far as a manual goes. Very interesting.....
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is online now   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
