Old 12-17-2012, 04:45 PM   #571
DEE SPEED's Avatar
Default FDR
what is the lowest FDR i can get for R1, now i'm using 84/30 gearing for blinky mode 13.5T motor, more hi-speed wanted
Serpent GT Cobra - Velox V8 Picco Evo - Team Orion - Atomic
T4'14 Xrays - Speedpassion - LRP - Hobbywing -Team Power - OS speed - SanWa - KO Propo - Kyosho - PN racing
DEE SPEED is offline   Reply With Quote
Old 12-17-2012, 07:31 PM   #572
jsinclair's Avatar
I'm currently running a 56t pinion, its a pain to get the pinion on. And the smallest spur I could fit is a 78, I'm sure you could fit a bigger pinion. I'm sure you could get down to a 2 fdr if you wanted.
jsinclair is offline   Reply With Quote
Old 12-17-2012, 09:51 PM   #573
spencehotbodies's Avatar
What weight of oil are you running? What I found with some of my early runs with the r1 is, that the car started to break away about four minutes in. Was running 1000 w, now am running 2000 w and no problem. Hope this helps.
spencehotbodies is offline   Reply With Quote
Old 12-17-2012, 11:16 PM   #574
DEE SPEED's Avatar
just bought 76T spur 48 pitch , not sure maximum pinion would fit
Old 12-18-2012, 01:07 AM   #575
In running 3000cst oil in my diff
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 12-18-2012, 03:49 AM   #576
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
Yeah I'm at 3k on carpet at the moment
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 12-18-2012, 04:26 AM   #577
Trader Rating: 88 (100%+)
I'm running 2000 Losi oil on asphault, could it be thinning during the run?
Shane W.
Everything for Sale - out of hobby
tcdrvr2 is offline   Reply With Quote
Old 12-18-2012, 06:11 AM   #578
jeff jenkins's Avatar
Trader Rating: 76 (100%+)
I am also running 3000wt. I've noticed more stability and forward bite with this oil on carpet.
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 12-18-2012, 06:31 AM   #579
I think the need for "thicker" oils in the diff is due to how free the gear diff runs with the bearings in the diff halves. Meaning that to get a similar feeling from the diff compared to others, we are having to run thicker.
If you compare it to how "tight" my Tc6.1 diff was, where we were running 800cst...
Luke Hobson
Old 12-18-2012, 07:32 AM   #580
Xenolance's Avatar
As an alternate idea.. Did you make sure when assembling the Diff that it was shimmed properly before adding fluid? IE; Build the diff without fluid, giv it several turns and then lock one side and try to spin the other to see if the gears slip? Obviously with composite gears you need to be careful not to strip them by force but also make sure they aren't slipping on their own. I felt mine was too loose so I added an extra shim to both sides of my Diff and it runs smoothly and feels great. I don't recall the exact sizes I used in mine, I think it was one .2mm and one .1mm
David Rose, Houston, TX.
Spec-R R1 / S1, Corally RDX.
"He's a Picasso with an Allen wrench." -Guffinator
Xenolance is offline   Reply With Quote
Old 12-18-2012, 11:40 AM   #581
Hello Luke
I can't seem to find those speedo settings, any chance of Posting them?
Old 12-18-2012, 02:24 PM   #582
Hi spencer. They're posted on the LRP flow thread
Luke Hobson
Old 12-19-2012, 07:41 AM   #583
Fuzzi0n's Avatar
TQ bits turned up, servo mount is really nice, also excited to try the car with roll bars. Just need my ballcups now.
Spec-R S1, Schumacher CAT SX3 S1
Fuzzi0n is offline   Reply With Quote
Old 12-19-2012, 07:48 AM   #584
SteveM's Avatar
Trader Rating: 140 (100%+)
My TQ order with the steering servo mount and a few other parts arrived today. I had my front lower bumper shatter last Sunday before my club races even started. I had to place TQ order #2 and grabbed the alloy motor mount too.
SteveM is offline   Reply With Quote
Old 12-19-2012, 12:44 PM   #585
marshallsbbq's Avatar
Trader Rating: 40 (100%+)
Default My Spec-R R1
Here are detailed photos of my Spec-R R1. Here I give a little insight on the car for people hanging on the fence. Right out of the box the R1 can perform just as good as any other touring car out on the market. When people ask me about this car I tell them it has some of the best attributes of the other cars on the market all wrapped up in one. It's simple design makes set up for it very easy. I don't have to over think with the car to get the results I need. Some of the hop up items I did get for it right away to help the car even more with performance was an additional Gear Diff $32 for the front (since it comes with a Spool and 1 Gear Diff with the kit, the additional Gear Diff helps on settling the car down in technical tracks, when I'm on a faster and more open track I just drop the Spool in), The Spec-R DCJ set $39.99 ( Opposed to paying $80 a set for other cars) helps with front end chattering when making turns, I also decided using Tamiya Low Friction Ball Cups instead of the Spec R ones, the ones that came with the kit kept popping off the ball when making adjustments on the set up board. At $316 out the door it's affordable compared to other kits out there on the market as well as parts and hop up parts are in expensive as well. The can be purchased and at TQ RC Raceway online and he has all the parts fully stocked.
Spec-R R1-imag1768.jpg   Spec-R R1-imag1769.jpg   Spec-R R1-imag1770.jpg   Spec-R R1-imag1771.jpg   Spec-R R1-imag1772.jpg
marshallsbbq is offline   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
