Old 12-02-2012, 11:11 PM   #496
toast.'s Avatar
I'm looking at getting a new car - can somebody tell me how the R1 compares to a T4 or TC6.1?
This car seems like a bargain compared to the others. I am not the best racer so not sure I could get any extra seconds by paying more for a T4 or TC6.1.
Small Tires:TA05 v2, M05-Pro, TT01, RC18's
Big Tires: SSC "Slash" LCG, Mugen MBX6 eco SCT, RB5, RB6
toast. is offline   Reply With Quote
Old 12-03-2012, 01:32 AM   #497
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
Hiya,
Quality wise it's not on par with the T4, but X-ray are a step above most companies when it comes to quality, and this is obviously reflected in the price.
But compared to the TC6.1 the build is just about as good, it actually required less shimming that my AE did to remove any slop.
If you choose one, you won't be disappointed I am sure
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 12-03-2012, 10:02 AM   #498
JayL's Avatar
The new tamiya Aeration shock caps need a new shock body as well
cap #51280
body #9804672
all else is the same. I am going to try these on my S1 when they are avail
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 12-03-2012, 11:27 AM   #499
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
tried some new stuff on sat and feel it is an improvement on my current setup so i will post my updated setup later tonight.
jeff jenkins is offline   Reply With Quote
Old 12-03-2012, 12:16 PM   #500
JayL's Avatar
With the flanged 3x6x2.5 bearing on the layshaft? are we running the flange INSIDE the bulkhead or Outside? Does it replace the flanged plastic pieces that go on each end of the layshaft stock?
Old 12-03-2012, 12:38 PM   #501
They replace the bearings in the pulleys.
Old 12-03-2012, 12:40 PM   #502
Also I got ahold of some team xray ecs shafts and put them in the front .............changed my life!!!!!
Old 12-03-2012, 12:49 PM   #503
Fuzzi0n's Avatar
Those would need to be 5x8x2.5 bearings to do that, not the smaller 3x6x2.5's he mentioned.
@ JayL
Which size bearings do you have - the layshaft doesn't turn and therefore doesn't need bearings to replace the plastic parts at either end. What some of us have done is replaced the two 5x8x2.5 bearings that go in the pulleys with flanged ones of the same dimensions to remove some of the play. I found I didn't need shims at all, some use the kit shims.
Spec-R S1, Schumacher CAT SX3 S1
Fuzzi0n is offline   Reply With Quote
Old 12-03-2012, 12:52 PM   #504
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Is this in place of DCJs or the standard drive shafts?
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 12-03-2012, 02:27 PM   #505
JayL's Avatar
@ JayL
they are 5x8x2.5, now I see where they go.
Old 12-03-2012, 09:38 PM   #506
Airflow's Avatar
S1 question,
Does it have too much flex like the T2R?
Airflow is offline   Reply With Quote
Old 12-03-2012, 09:47 PM   #507
CristianTabush's Avatar
Default Now Available!
RSD066 RSD XRAY/ SPEC R R1 HARD ANODIZED 7075 T6 ALUMINUM SPOOL CUP (1 PC)
These Hard Anodized 7075 T6 Aluminum Spool Cups were designed to be used with Plastic Blades on your XRAY or Spec R Touring Car front Spool. Due to the material these spool cups are nearly as light as plastic spool cups, but are more durable and much stronger.
These spool cups are ideal for stock racing and they also provide increased life of your front blades due to its larger diameter construction.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 12-04-2012, 12:05 AM   #508
my R1 is just about done. It has been a pleasure to assemble well done to spec r
I pay to play, do you ?
ozace is offline   Reply With Quote
Old 12-04-2012, 12:41 PM   #509
is it the same plastic in the s1 as the r1? looking at the price it would be cheaper to buy a s1 kit to get a extra diff, suspension parts etc
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 12-04-2012, 03:43 PM   #510
SteveM's Avatar
Trader Rating: 128 (100%+)
Here are a few pics of my S1 after racing it last Sunday. I was TQ for my club's GT2 class which is 17.5 blinky.
SteveM is online now   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13440 Yesterday 08:58 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
