Old 11-26-2012, 11:17 AM   #436
trickd122's Avatar
Originally Posted by AdrianM View Post
I find less front droop improves on power steering. It keeps the weight from transferring to the rear.
On power steering has a lot to do with rear suspension setup. You need to get the rear free and rotating so it follows the front on power.
We are prolly saying the same thing by more droop I mean going clockwise on the screw and the number gets bigger on the block/gauges
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 11-26-2012, 12:26 PM   #437
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Just my $.02 on the car. After owning the R1 for a couple of weeks I was able to get the car on the track finally. The main thing I was impressed with was the cars durability. I haven't been to the track in a year and haven't really driven much in a year and a half. So I was hoping this car would be able to handle me being very rusty. It handled some full speed board taps without missing a beat. These types of hits would have definitely broken a c hub/steering arm on the 416x.
I used Jeff Jenkins setup and the car handled well. I will try some DCJs in the future. I did try using a gear diff with putty in front but I didn't like how the car accelerated. I may try it again with 500k but then again I liked how it felt with a spool. The Spec R springs felt good but I will try Tamiya white/blue springs next time out.
The build quality was fine...on par with most cars out there. If you have moderate build skills you should be able to handle shimming and minor sanding. I use PRS spurs and I had to shim the lay shaft with about .4mm of shims. I also used .3mm shims between the steering arms and c hubs to take out the play. Although, I drove it without these shims in and didn't feel the effects. I lightly sand the diff spacers to remove the burrs and free up the diffs. I didn't have any issues with the bearing holders being pinched so I did not shim the upper bulkheads.
I'm looking forward to my next time at the track to see how the car reacts to setup changes!
Has anyone tried XRay steel or aluminum spool cups? I see there are several options out there and I assume they will fit the Spec R spool...
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 11-26-2012, 01:07 PM   #438
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
That's something I'd like to know about the spool cups too as I had that idea also
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 11-26-2012, 01:43 PM   #439
SteveM's Avatar
Trader Rating: 125 (100%+)
Originally Posted by trickd122 View Post
What he said but what I really like is that this car has a 3rd motor mount hole for use with smaller spurs....Really Hudy himself might copy this
The 3rd mounting hole is brilliant. Using 64 pitch gears I have my car set with a 96T spur and 44T pinion for a 4.145 FDR. Should be close for my club's 17.5 blinky class.
SteveM is offline   Reply With Quote
Old 11-26-2012, 01:45 PM   #440
I was looking at getting either one of these:
http://www.tqrcracing.com/shop/produ....asp?p_id=3022
http://www.tqrcracing.com/shop/produ....asp?p_id=3358
Old 11-26-2012, 01:46 PM   #441
+1!
Old 11-26-2012, 02:28 PM   #442
Xenolance's Avatar
Anyone know of a Tamiya P/N that will work for their really good ball cups? I keep getting the wrong ones somehow, the balls are always too small for the cups.. (NO LAUGHING!) I looked on TQ and didn't see a ball cup set for the 417.
David Rose, Houston, TX.
Spec-R R1 / S1, Corally RDX.
"He's a Picasso with an Allen wrench." -Guffinator
Xenolance is offline   Reply With Quote
Old 11-26-2012, 02:57 PM   #443
53601 is what I got I believe, scroll through the parts locator on TQ and search for Tamiya Low Friction Adjuster 5mm
mupchu is offline   Reply With Quote
Old 11-26-2012, 03:00 PM   #444
CristianTabush's Avatar
We'll have some Aluminum spool cups for the R1/ XRAY in about a week. They will allow you to use blades for longer wear. They are based off of our TC6 cups, which last forever.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is online now   Reply With Quote
Old 11-26-2012, 03:28 PM   #445
Trader Rating: 88 (100%+)
I used the same and they work perfectly.
Shane W.
Everything for Sale - out of hobby
tcdrvr2 is offline   Reply With Quote
Old 11-26-2012, 03:56 PM   #446
Xenolance's Avatar
Ahhh!! Both times I ended up with some 6-8 MM units, it didn't say so I just bought them, looking they are identical in both packs so I'll order the ones you linked, hopefully Reflex has em in stock!
Old 11-26-2012, 04:49 PM   #447
Originally Posted by PitNamedGordie View Post
Yeah the 2nd ones you posted are the ones that caught my eye. I'm not a fan of using blades up front.
Luke Hobson
Old 11-28-2012, 07:34 AM   #448
Xenolance's Avatar
Thank the gods tomorrow is race day! Can't wait to put all my new goodies on the car and run it, it's been a hell week so I need the racing! Got all the new Aluminum parts ordered, new say bars, etc, and will be testing my setup and tweaking some more. I need to find some Muchmore 28's in stock somewhere in the US! It's been a bit cold for my 32s I think and last week the evening dew caused the track to turn into a slip-n-slide after about 9PM.
Old 11-28-2012, 05:53 PM   #449
EDWARD2003's Avatar
Asking for a big favor.
Could someone (with digital calipers) take a few measurements of the top deck. I'm thinking of using this top deck on an older model chassis.
These are the measurements i would need. Also, could you take center to center hole measurements.
1. Length of top deck. (Front-most hole to rear-most hole)
2. Distance between the 4 bulkhead mounting holes A) Side to side, front to back.
O O
O O
4. Lastly, the mounting holes for the lay-shaft support.
a) Use the bulkhead hole closest to the lay-shaft support as your point of reference hole.
b) Using this reference hole, measure the distance to the first lay-shaft hole
c) Once again using the reference hole, measure the distance of the second lay-shaft hole.
Thank you so much for your help.
EDWARD2003 is offline   Reply With Quote
Old 11-28-2012, 06:47 PM   #450
Xenolance's Avatar
O O
O O
I'll do it for you tomorrow when I'm at the track. I'm going to go pick my stuff up in the morning.
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13416 12-21-2016 06:45 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 04:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 12:44 PM
SEO by vBSEO 3.5.0
