Old 07-03-2016, 12:21 PM   #3886
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
the manual specifies the size of the bearings you need as you assemble. avid also carries bulk bearings in tubes which will prob be the cheapest way to get a large sum of disposable bearings.
really not much effort to consider. dif carrier bearings, axle bearings and layshaft. 3 sizes. 4 if you have DJC shafts in the front.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 08-06-2016, 05:11 PM   #3887
Hi all,
I've been racing my Spec-R R1 in a fairly non-competitive way for about a year. I feel as though my driving is at a point now where I can start to be competitive, but in order to do that I need to reduce the weight. Or at least I think I do.
At the moment it's 100g above the minimum. What's the best way to loose this weight?
I currently use a fair amount of body reinforcement to make the bodies last and I have heaps of stickers on my car. Would this be where to save weight?
I've already removed excess wires.
Is anyone else still racing a spec-r?
filippimini is offline   Reply With Quote
Old 08-07-2016, 10:17 AM   #3888
Trader Rating: 25 (96%+)
In order to lose THAT much weight, I'd start with a smaller capacity battery pack, preferably with in-line bullets and eliminate connectors to save additional weight. I'd also get a lightweight body with only 1 very light coat of paint. Titanium parts would be my last effort to cut more weight if necessary, but that will also be the most expensive route.
I'm still racing mine but parts are so hard to find I'm wondering if the brand is no longer in business???
billdelong is offline   Reply With Quote
Old 08-08-2016, 02:03 AM   #3889
Thanks for the reply.
I've still got lots of parts to keep me going. I've already eliminated all connectors. Body will be next.
What is the weight of your car?
Mine is 1450 with battery and body. I'd like to get as close to 1350 as possible.
Ryan
Old 08-08-2016, 05:24 AM   #3890
I'm running a shorty which is actually a pinch too light so I've added some lead weight in front of the pack to get my car to the min weight limit of 1380g for my local club.
Some brands of electronics weigh less than others, I'm also running an MRT transponder which is a few grams less than MYLaps. I also run titanium screws on all the upper parts of the chassis to help lower the center of gravity.
Old 08-08-2016, 07:15 AM   #3891
specr is in business dont worry.iam a driver for specr you can get everything in the shop.you wil have a other websitw to shop your parts.thats egr racing.hope i help you best regards ruud
Ruudned is offline   Reply With Quote
Old 08-08-2016, 07:29 AM   #3892
not sure you understand the meaning of "everything", but when I can't get the most important parts I need, then that makes it seem like "nothing" is in stock... of all the cars I've owned, my biggest disappointment has been getting a SpecR purely because of poor parts support. The car performs very well, but it's hard to recommend something that can't stock these critical parts that break on occasion:
http://www.egrracing.com/shop/index....oducts_id=5113
http://www.egrracing.com/shop/index....oducts_id=5770
http://www.egrracing.com/shop/index....oducts_id=5091
These parts have been out of stock for nearly a year, that is unacceptable
In the mean time I've been running a mix of Tamiya/Associated parts thanks to someone who showed a compatible mix, but come on SpecR, you can't expect your customers to remain loyal if you expect them to rely on other manufactures for spares, doh!
Old 08-08-2016, 02:10 PM   #3893
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
Tamiya/Associated parts thanks to someone who showed a compatible mix.
You willing to share with us? :-)
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is online now   Reply With Quote
Old 08-08-2016, 04:23 PM   #3894
A few pages back Chris Morrison saved my bacon:
Spec-R R1
Associated plastic hinge pin inserts for the TC3 are compatible with the SpecR... those parts have also been out of stock from EGR for what seems like an eternity
Old 08-08-2016, 11:04 PM   #3895
ASC31679 Tc7 steering block
ASC31680 Tc7 king ping bushing
ASC31678. Tc7 caster blocks
This is my new setup for spec r
Drill out the caster blocks with a 3 mm drill bit and ream out slightly
Use a 1mm spacer to take out play between arm and caster block
Have ran this in mod works great
Chris
Chris_morrison is offline   Reply With Quote
Old 08-09-2016, 02:43 AM   #3896
you can email the guys from specr,they are making new parts so you can ask for it.
Old 08-09-2016, 04:30 AM   #3897
Are they making more kits?
Old 08-09-2016, 06:06 AM   #3898
i think a new touring car is coming next year...so i run the r2 on this moment
Old 08-09-2016, 07:00 AM   #3899
Solara's Avatar
Trader Rating: 16 (100%+)
If this is for R1....car has been discontinued for several years. So parts should not be there for long....
For all the steering parts, I am actually using Xray T4 parts with very little mod and spacers and they fit pretty good.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 08-09-2016, 04:56 PM   #3900
Super Moderator
tmail55's Avatar
a 1mm spacer In front or rear?
Chris
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
