Old 11-16-2012, 08:38 AM   #361
Fuzzi0n's Avatar
@ Xenolance
Interesting how the kits differ, my layshaft needs quite a few shims to get it right whereas the kit you built didn't. My spur doesn't touch the upper deck though. I believe I had the same issue with the steering, part of it can be fully tightened but the other part cant. Don't think I had any play on the posts though - I'll double check in a bit. The suspension pivot balls do feel a bit tight to start with, although I put a decent amount of grease in there and played with them for a bit and they loosened up a lot. Agreed that it's worth looking for some metal ones. I think with some of this kit is really tight from new, few runs it'll sort itself out.
As for the upgrades, my first thought was the hexes when I finished building it - had some bad experiences with plastic ones back in the day so they're on my list. Probably going to get the servo mount and a few other bits and pieces - roll bars are the other one I'd recommend right away.
Spec-R S1, Schumacher CAT SX3 S1
Fuzzi0n is offline   Reply With Quote
Old 11-16-2012, 10:22 AM   #362
Xenolance's Avatar
@Fuzzi0n
The Layshaft issues seem to be exaggerated or mitigated depending on the brand of Spur gear you used. Kimbro spurs are pretty wide and so they fill the gap better. Spec-R / Xenon / 3Racing all seem to be pretty thin and so I have a gap with any of them. The adapter rubbing is also a result of the Kimbro Spur. with a spec-R spur it's got .2mm side play in either direction.
With the Kimbro the rear belt also tends to ride the center hub so you really need the screws tight to keep them from catching the belt.
David Rose, Houston, TX.
Spec-R R1 / S1, Corally RDX.
"He's a Picasso with an Allen wrench." -Guffinator
Xenolance is offline   Reply With Quote
Old 11-17-2012, 05:17 AM   #363
sooo car ordered, couldnt resist it after reading so much good things about it
has anyone tried it with tamiya springs? (i have a set in my box so..)
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 11-17-2012, 09:36 AM   #364
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
I ran on carpet this afternoon, low traction, really tight track. Just your usual local club jobbie.
Started on base kit settings, during the day I changed to longer links inboard all round, increased front inner link shim to 3mm,
Switched to AE silver/green springs. Car was really good considering the traction
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 11-17-2012, 02:06 PM   #365
Darrin70's Avatar
Originally Posted by Xenolance View Post
@Fuzzi0n
I believe a flanged 3x6x2.5 bearing was what someone had mentioned that gets rid of the play from side to side...
HYPERHOBBIES
YOKOMO
SKYRC
SWEEP RACING
SMC
Darrin70 is offline   Reply With Quote
Old 11-18-2012, 08:13 AM   #366
Xenolance's Avatar
It was 5x8x2.5mm flanged bearings from the steering rack that work.
Credit: Spec-R R1 by mos-leung as being the first to notice this.
Old 11-18-2012, 12:32 PM   #367
jeff jenkins's Avatar
Trader Rating: 76 (100%+)
Tried running the 3.5 deg rear toe , not sure if I like it. Just curious what others think about the 3.5 setting if they have tried it.
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 11-18-2012, 04:39 PM   #368
Blog updated after todays EWS race (busiest series in the UK for winter)
Only ran in 21.5 boosted but came 2nd overall on the first "proper" outing with the car
Extremely happy.
I've changed the turnbuckle ends over for Tamiya ones. Had alot of interest from fellow racers about the car today, all positive. Even the negative comments of "it's a copy of xyz" were ok when I used the comeback, "yeah, they've taken all the best bits from each car and are selling it over 150 under the competition "
Definately turned a few heads today.
Luke Hobson
Old 11-18-2012, 05:54 PM   #369
Potoczak's Avatar
Trader Rating: 112 (100%+)
Has anyone tried to use a xray layshaft since the spool and gear diff are direct drop in gears?? I'm not to fond of the photon style.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 11-18-2012, 06:19 PM   #370
You can't use the dray one as its designed to be pulled out from the top and r1 bulkheads are not designed that way.
Old 11-18-2012, 07:46 PM   #371
Trader Rating: 88 (100%+)
Default Built
I got my car built and only had two flaws, both in the steering, one in the form of one of the 1mm shims 3x5x1mm shims for the bellcranks was actually a 3x5x.5mm and the other issue was that one of the pegs that the steering rides on was not threaded. Otherwise the build was good. I haven't had a chance to try it out yet but I'm looking forward too it. This car looks great in person, very impressed.
Shane W.
Everything for Sale - out of hobby
tcdrvr2 is offline   Reply With Quote
Old 11-18-2012, 08:31 PM   #372
Magnet Top's Avatar
Jeff, last night I forgot to mention / ask you, had you considered trying the 4 and 4 "toe" blocks in the rear for 3 degrees of toe. It would effectively widen the rear of the car. I suppose , for mod, it would stabilize the rear and allow even longer camber links. Just something to try, you might find it has less corner speed but is easier to drive. And did you get a chance to raise the roll center ? Just curious....
p.s.
Nice job last night.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 11-19-2012, 06:20 AM   #373
p.s.
Thanks, and no I haven't thought of that but I had thought about trying wider pivot points front and rear together.
Old 11-19-2012, 07:36 AM   #374
Xenolance's Avatar
Extremely happy.
Very nice Luke! Love the Blog update, and your goofy grin too!
I just upgraded to a Trinity D3 17.5 for our Blinky racing here. the old Speedpassion was just not cutting it.
A sneak peak..
I *HOPE* you guys will be seeing this image somewhere else soon!
Old 11-19-2012, 11:04 AM   #375
nice, i hope my car arrives here before the weekend so i can start testing it
will start with jeffs setup
where can i buy the floating servomount?
also what rates are the included springs?
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
