Old 03-17-2015, 05:53 PM   #3646
I took the suggestions about the steering rack fix and installing the Tamiya ballcups. All I can say is WOW!!! What a difference. No more play in the steering rack and turns very smooth and the ball cups fit nice and tight. Thanks for the help guys. Next I'm thinking of installing some titanium links.
Marc D is offline   Reply With Quote
Old 03-17-2015, 09:09 PM   #3647
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
definitely get some titanium links. absolutely nothing wrong with the 3 racing ones either.
prob gonna order a new set for my r2 and a floating servo rack this week. there are a bunch of parts id love to go ahead and add right out of the box but then the kit becomes $400 lol..
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 03-18-2015, 04:51 AM   #3648
Why "definitely get" titanium links? They don't aid in performance. Weight difference has to be negligible. I'm just curious why you think they're that important?
.crispy is offline   Reply With Quote
Old 03-18-2015, 06:27 AM   #3649
Trader Rating: 28 (100%+)
Some people just like to "upgrade". Anything "stock" is not good enough for some even though these are aluminum. I have not bent any alum turnbuckles yet between racing 4 different cars. They hold up well. Titanium turnbuckles will almost guarantee you a bent alum ball stud if the links don't pop off. You likely wont see anything in a bad crash till you put it on a setup station though.
greenpea76 is offline   Reply With Quote
Old 03-18-2015, 07:14 AM   #3650
valk's Avatar
They are much stronger than aluminum. Less likely to bend/snap and take.less damage from turnbuckle wrenches.
For.me, changing turnbuckles is a huge pita. Ballstuds easy.
My stuff
My RC
Old 03-18-2015, 08:41 AM   #3651
I just finished installing the 3racing titanium turnbuckles. I found one of the stock spec-r turnbuckles bent when installing the Tamiya ballcups. They are 3mm so working on them is simple. I installed them all and put the car up on the wedgie board and everything is lined up perfect. .5 mm on toe out in the front steering. 2mm front camber. 2.5 mm rear camber. 3mm toe in at the rear. Its too bad that spec-r doesn't include this in the kit or as an upgrade. Plus the 3racing turnbuckles weren't expensive as others. A very inexpensive upgrade.
Old 03-19-2015, 03:33 PM   #3652
nudge2325's Avatar
Default What not to Do
This is what you should never do with a Spec R R1 Pro.
I hit a small road marker at full speed and this was the outcome.
Not happy
Do any of the Aussie drivers of these cars have a spare chassis ( doesnt need to be new) that I could buy???
Club Secretary BRCCC. www.wynnumrc.org.au
My Rides:
2015 Yokomo BD7 Black
2015 Yokomo BD7 Black For the kids to drive
Losi XX4 WE
nudge2325 is offline   Reply With Quote
Old 03-19-2015, 03:51 PM   #3653
Not happy
You could probably order one of those new aluminun chassis and see how that works out.
Old 03-19-2015, 03:56 PM   #3654
Here's a picture of the new ball ups and turnbuckles
Old 03-19-2015, 03:58 PM   #3655
Here's the front
Old 03-19-2015, 04:04 PM   #3656
Originally Posted by Marc D View Post
Here's the front
here's the front
Old 03-19-2015, 05:23 PM   #3657
valk's Avatar
meanwhile, in canada
unfortunately... this is also.. in canada.. and has to be finished....
My stuff
My RC
Old 03-20-2015, 03:29 AM   #3658
32819toon's Avatar
What Spur gears do you guys use ? Myself & my son have gone through 4 spur gears this year. I want something tougher than the Spec R ones. They're also quite coarse which produces noise, therefore more resistance which means power loss. My car has noise whereas others are quiet and smoother.
On the subject of turnbuckles, I installed Lunsford titanium ones on our cars and they're great. I don't have to keep checking to see if they're bent.
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 03-20-2015, 08:18 PM   #3659
valk's Avatar
Panaracer for me. i might pick up some of their pinions as well to replace my aging touring car gears. thought xenon ones are tempting due to the metric set screws.
I think kawada spur gears fit too. anything with 4 holes.
My stuff
My RC
Old 03-20-2015, 08:49 PM   #3660
DBM
I've been using kimbrough spurs in my spec-r cars, and panaracer in my vbc. The kimbroughs seem to be softer material. I've never had a problem with the panaracer, but have damaged a kimbrough.
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
