Old 03-01-2015, 10:24 PM   #3601
Butler02's Avatar
I also plan on picking up the new top deck with the pillow ball centre support. The new fan mount looks sweet too although it's more bling than anything else.
Lou's Speedway and Hobbies
Spec-R R1 USGT, R2 Stock TC, S1/R1 hybrid "Mod"
Airtronics MT-4
Butler02 is offline   Reply With Quote
Old 03-01-2015, 10:44 PM   #3602
CristianTabush's Avatar
On the steering rack...
I went ahead and did a couple of things. The rack, I used a plastic bag over the bearings and pressed them in, I then trimmed it out with an Xacto. I also used some M3 shims totaling 0.8mm instead of the stock 1.0mm under the bearings. You could also sand down the stock shims.
On the dual arms, I sanded down the posts to make them more snug. Screws usually have a slight shoulder, so I actually sanded them below the bearings slightly. When using the CF brace, I will install a 0.1mm shim to free up the steering. I also glued the bearings in place.
The result is a near Zero slop bellcrank.
I had a customer and close friend run his R2 for the first time this weekend. He improved his times by about 1/2 a second over all his previous cars per lap. The R2 is RC's biggest secret right now. At least on carpet...
I am finally getting to make the aluminum chassis this week. I am really excited to to see the improvements. Last week I ran within 1 second of the track record that I ran with my XRAY with a roll over included. I also bested my fastest lap. This was with a box stock car...
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 03-01-2015, 11:06 PM   #3603
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
excellent news! im excited to get mine! will you have these new servo mounts availalbe cristian? id like to get at least one with my r2 when its available.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 03-02-2015, 12:10 AM   #3604
Originally Posted by .crispy View Post
Anyone installed the new floating steering conversion kit yet?
http://www.tqrcracing.com/shop/produ...asp?p_id=10043
Trying to figure out what it would buy you?
Wont that make the steering less precise? Woulndt you want the steering mech to bolted to the chassis so that it couldnt move about ?
Dont know , just asking.
1101 is offline   Reply With Quote
Old 03-02-2015, 01:12 AM   #3605
Unfortunately, they back ordered them on me. They did not have enough after TITC, on top of the first batch being small due to the Chinese Spring Festival. They will have some more soon though... They are already payed for.
Old 03-02-2015, 07:29 AM   #3606
32819toon's Avatar
Default new aluminium steering blocks
New aluminium steering blocks fitted, and they didn't need anything taking off, a direct fit. Hopefully the end of that problem !
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 03-02-2015, 10:27 AM   #3607
valk's Avatar
Yep. now your gonna be popping chubs.
My stuff
My RC
Old 03-03-2015, 05:24 AM   #3608
32819toon's Avatar
Thing is, they weren't breaking because of crashes. The bottom holes have been wearing / stripping. Probably due to heavy side ways forces during cornering on high grip carpet.
32819toon
Old 03-03-2015, 08:44 AM   #3609
This is caused by tapping boards or using too short of a bottom screw. Have you tried the carbon ones? They are far more durable. Side ways cornering forces would never strip these.
Old 03-03-2015, 10:22 AM   #3610
valk's Avatar
Heh. I broke my.first carbon one in like.. 10 minutes. A bit afraid of them..not even a hard hit 17.5.
My stuff
My RC
Old 03-03-2015, 11:00 AM   #3611
DBM
Toon, you'll notice on your new aluminum steering blocks that there is a bit of a hump on the arm that contacts the c-hub at huge steering angles. If you file that off, your chubs will last much longer. I'm sorry that I forgotto mention that earlier. I haven't broken a chub since milling that bump off of the arms.
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 03-03-2015, 12:52 PM   #3612
Butler02's Avatar
I used to strip the screws in the bottom of he steering knuckle on my r1 too. I never discovered why or how it happened. I haven't had that problem on the r2 at all, and it's been a long time for the r1.
I find the carbon parts are nicer to thread in to, but they are more brittle. I've broken a chub and a front arm so far. I've had to replace them with the standard plastics for now. I like the feel of the hard plastics on track better though.
Airtronics MT-4
Old 03-03-2015, 08:39 PM   #3613
Trader Rating: 28 (100%+)
I have only broken an inner hinge pin by a slight tap on a rail. Has been good so far. The pin didn't even bend, just a clean snap. Replaced with polished hotbodies pins of the same size. I hope my parts hold up for my last points series race.
greenpea76 is offline   Reply With Quote
Old 03-04-2015, 03:30 PM   #3614
valk's Avatar
to be fair, the one hard chub i broke, i kind of deserved to.. i have a bad habbit of aiming RIGHT at the inner of a chicane.. luck was not on my side lol. they definitely have less slop to them and are less prone to tap erosion. ive had my old lower arms widen by like a full mm where they capture the hubs. had to use some ae caster shims to tidy it up as i didnt really wanna change the arm for that.
shoudl have my r2 in a week... if i can stove off the excitement to throw a new kit together the day i get it, i might do a time lapse of building at the track. some people had questions about how to build shocks nicely and consistantly, which i could address. how i shim my cars/untweak them ect.
ill definitely get someone to capture video of the car on track, esp with the little goodie that is being included with mine.
My stuff
My RC
Old 03-04-2015, 05:44 PM   #3615
Butler02's Avatar
Are you going to post the videos to this thread? I wouldn't mind seeing how you shim your cars.
Airtronics MT-4
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
