Old 02-14-2015, 01:14 PM   #3571
32819toon's Avatar
Originally Posted by DBM View Post
They are from yeah racing. They were ever so slightly tight between the king pin bushings so I had to remove a small amount of material with a file. I use them on both my S1 and R1.
That's great, thanks
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 02-14-2015, 01:26 PM   #3572
DBM
They are blue so are a bit out of place. Lol.
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 02-14-2015, 01:29 PM   #3573
32819toon's Avatar
I've got blue TRF shocks so it already looks odd !
Is that an aluminium chassis ?
32819toon
Old 02-14-2015, 01:45 PM   #3574
DBM
Yup. There are pics of it in posts 3457 and 3465
Old 02-18-2015, 11:41 AM   #3575
CristianTabush's Avatar
I have not seen an R2 thread, so I though I'd post my thoughts here.
Bold statement coming in 3,2...
The R2 is the best value TC I have driven to date...
With basically a box stock R2, only adding some machined 3x1.15 pistons and Yokomo springs I was able to match the pace of my T4 and RSD7 after 2-3 battery packs. This car is legit. Plenty of traction and steering to boot. The only issues are there is still a lot of play in the steering system, which I think can be mitigated with some shimming and some better bearings and the ballcups are still not great (although marginally better.)
I am working on an alloy chassis over the weekend which should help tame down the car a bit on our carpet track (I had a bit of traction rolling when pushed a little hard). I am sold on the car though.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 02-18-2015, 12:07 PM   #3576
Butler02's Avatar
Agreed. The R2 is awesome. Definitely an improvement over the R1. Tons of steering, Lots of grip. I think the ball cups are much better than the originals. The steering rack is the same so there is still the same play in the bearings. Better bearings and shims would help. I find using a very very small amount of glue to hold the bearings into the rack helps quite a bit. I feel like the springs are too short. To get a 5 mm ride height my rear springs are almost all the way down the shock body. Other than those minor issues, the car is incredible. Quality on everything is very good. I don't think you'll find a better car for the money.
There is a thread titled R2 share thread I believe.
Lou's Speedway and Hobbies
Spec-R R1 USGT, R2 Stock TC, S1/R1 hybrid "Mod"
Airtronics MT-4
Butler02 is offline   Reply With Quote
Old 02-18-2015, 01:04 PM   #3577
DBM
I was thinking of getting a VBC D07 to go along with my D06, but maybe I should just get a R2 to go with my R1 and S1. I have quite a lot of spares already.
One thing that worries me a bit on the R2 is how the layshaft mount is screwd to the motor mount rather than being 1 piece. I'd definitely be using thread lock on those two screws and tightening them down good and tight.
Old 02-18-2015, 02:51 PM   #3578
The layshaft has not given me any issues so far. Their mount for xray does have a tendency to strip spurs, but the 2 forward screws for the R2 mount might be making it stronger (one of them is pretty central.) I had a couple of violent traction rolls yesterday and the spur stayed intact, on their XRAY mount, the spur would have stripped. I have yet to put a mod motor in though, that will be the true trial by fire...
Old 02-18-2015, 06:20 PM   #3579
Butler02's Avatar
+1 for the layshaft thing. I've sent my R2 for some pretty serious tumbles and I haven't had any issues with it stripping spurs or coming loose. If it's a concern of you have while building it, a little blue loctite won't hurt anything.
I noticed Spec-R actually sells a version of their motor mount/layshaft for the Xray.
Also, did anyone else notice that they have a new floating steering mount out?! looks sweet. gives us a carbon servo brace with it.
Airtronics MT-4
Old 02-18-2015, 06:43 PM   #3580
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
if your cncing alu chassis, please sell me one as a guinea pig. I was gonna make my own but getting the material was gonna be a huge wh0re in canada... enough to make 5 plates would have cost as much in shipping as the material..
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 02-18-2015, 08:25 PM   #3581
I don't know what to think about the floating steering. The execution is poor. The TC6.2 essentially had a similar design and it made the car drive inconsistent. If it was machined like the VBC it would be better, but carbon is going to shift when you tap boards.
Valk, contact me at the store about the chassis, I am sure I can work something out for you.
Old 02-18-2015, 09:47 PM   #3582
valk's Avatar
I dont actually have an r2 yet and by the time i do, carpet season will be over =( though if the r2 chassis is drilled the same as the s2, im pretty sure everything from my r1 would bolt up. i guess if it came to it i could upgrade my r1 motor mount to r2.
im guessing alu chassis would be more of a carpet thing?
would be too late to try for wcics 7, but if the price was right, i could try to make it to wcics 8 in calgary.
My stuff
My RC
Old 02-19-2015, 11:02 AM   #3583
32819toon's Avatar
DBM - is this the part :-
http://www.rcmart.com/yeah-racing-ff...3-p-32704.html
How much did you have to file off ?
32819toon
Old 02-19-2015, 11:11 AM   #3584
DBM
Edit: those might be different. I'll look up my old orders from tqrc to check the part number. Mine were listed as working for 417 as well.
Edit 2: yup, the p/n of those match the ones I bought from tqrc.
Those are them! I just had to remove the anodizing. Took only a few passes with a fine file. Might have been 0.1mm in total...didnt take long. Dragging the part across 240-320 grit sandpaper/emery cloth on a hard flat surface would do the trick, too.
Old 02-19-2015, 11:23 AM   #3585
valk's Avatar
I'd maybe just file one side and buy some 0.1-0.3 shims to snug it up. At least then you will always reference the same edge. I might have to get some of those myself. I must have 20-30 rear hubs by now lol.
My stuff
My RC
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
