Old 02-13-2015, 06:04 PM   #3556
Thanks, that's what I was looking for.
Sometimes I post just to look at Kraig's avatar
RoyU is offline   Reply With Quote
Old 02-13-2015, 07:04 PM   #3557
Butler02's Avatar
Yes, 2.9F and 2.7R is correct. When I got my first Spec-R S1, I emailed them and that was what they told me.
Lou's Speedway and Hobbies
Spec-R R1 USGT, R2 Stock TC, S1/R1 hybrid "Mod"
Airtronics MT-4
Butler02 is offline   Reply With Quote
Old 02-13-2015, 08:04 PM   #3558
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Yokomo blue. All you ever need =]
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 02-13-2015, 08:17 PM   #3559
What does that translate to in the Imperial system?
.crispy is offline   Reply With Quote
Old 02-13-2015, 08:26 PM   #3560
valk's Avatar
Google amazing
Search 290g/mm in lbs/in =16.23 lb.
Sear h 270gr/mm
My stuff
My RC
Old 02-13-2015, 09:06 PM   #3561
Google the "Reflex Racing spring chart" and you will find a list of most springs and their rates.
Goal Achieved....Not Dead Last.
mooby64 is offline   Reply With Quote
Old 02-13-2015, 09:09 PM   #3562
big al's Avatar
Boom!
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 02-13-2015, 09:10 PM   #3563
funked1's Avatar
I thought numbers like 2.7, 2.9 were N/mm? In that case, multiply by 5.71 to get lbf/in.
Streetjam SJF01 / M05 Ver.II R / Spec-R S1 VTA / Speedworld Raceway
funked1 is offline   Reply With Quote
Old 02-14-2015, 11:12 AM   #3564
32819toon's Avatar
My son and I are going through quite a few steering blocks with the bottom screw stripping and destroying the block. We both lost one today while racing. Does anyone have a solution for this ?
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 02-14-2015, 11:33 AM   #3565
valk's Avatar
unfortunately, steering blocks are just a common thing to go on touring cars. the xray super stiff wide bumper has helped with this tramendously, but ill still break one every couple race night. just accumulated taps will eventually kil them.
i tried running xray t2/3 style blocks which bolt right in, though you will have to shim them to be center. they broke where the steering arm meets the block. heh. but were stil better.
t4 wont work as you would need the c hub, which uses different pins than t3.
i think dbm had yokomo aluminum blocks in his r1? id rather break it than bend it though.
My stuff
My RC
Old 02-14-2015, 11:54 AM   #3566
32819toon's Avatar
Thanks Valk, I've thought about aluminium ones before but have been warned off them, although most buggy racers use them and they take far more punishment than touring cars. When we've stripped the threads, its been through glancing blows rather than a hard hit, so aluminium may be the answer. Its the cost which puts me off though.
32819toon
Old 02-14-2015, 11:59 AM   #3567
valk's Avatar
just get yeah racing ones for bd5/7. should work great. they not that expensive at like $15 or something. id pm dbm about which ones he has first though. you could also try the hard composite steering blocks, just stay away from the chubs heh.
My stuff
My RC
Old 02-14-2015, 12:06 PM   #3568
DBM
I'm using aluminum bocks for a Tamiya 417. They are sturdy enough to not bend, so no worries about that. The wheel bearings are closer together so will have to put some shims on the axle stub behind the hex
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 02-14-2015, 12:21 PM   #3569
32819toon's Avatar
Hi DBM, what manufacturers blocks are you using ? Are the 417 ones a direct fit or do they need shimming ?
32819toon
Old 02-14-2015, 12:26 PM   #3570
DBM
They are from yeah racing. They were ever so slightly tight between the king pin bushings so I had to remove a small amount of material with a file. I use them on both my S1 and R1.
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
