Old 01-09-2015, 10:27 AM   #3526
rtenzo02's Avatar
Originally Posted by Robbob View Post
Yes - all the same between the two cars.
Thanks for the info and fast reply !
rtenzo02 is offline   Reply With Quote
Old 01-09-2015, 11:14 AM   #3527
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
short answer, yes you can use the s1 seperate mounts with the r1 rear/front mount if you wish, but you will still need the inserts for the rear/front. its advisable to pick up the r1 seperate mounts as well if you are using the rear/front. then you can follow the table to figure out inboard toe as well as adjust trackwidth without wider hex/shims.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 01-09-2015, 10:44 PM   #3528
rtenzo02's Avatar
Yes I have ordered the seperate mounts as well from tqrc, until they arrive what adapters would I use to get 3 toe in ?
Old 01-09-2015, 11:59 PM   #3529
valk's Avatar
I've never tried to.mix the two so couldn't tell you. I'd start with the narrowest inserts, which I belive are one dot facing in. Measure that to see.
My stuff
My RC
Old 01-11-2015, 02:41 PM   #3530
This is freaky. I came here to ask the exact same question that is currently being discussed.
I want to get down to 2 degree in on my S1/S2. So in lieu of ordering the aluminum parts and inserts, I got another idea.
Going to flip the front pivot mounts (on the rear of course) so that the holes are out instead of in. Wonder what my 3.5, 3.0 and 2.5 rears will actually end up giving me?
.crispy is offline   Reply With Quote
Old 01-11-2015, 04:03 PM   #3531
Well, I had to use the 3.5 rear mount to get any appreciable toe in. With the 2.5 on the rear it looked almost straight or maybe .5 in.
I might have 1.5 now.
Old 01-11-2015, 08:40 PM   #3532
valk's Avatar
when you get your proper rear mount, use 1 dot or 2 dot out to get your desired toe out. in stock form the s1/2 is very narrow.
considering I manhandled 4 classes this weekend, tech and stuff i did alright. Qualified directly to the A main in MOD TC behind some of the WCICS best. went on to finish 7th overall. car was pretty good through qualifying and i secured the spot fairly early, but with so many pancars, the traction came up so much i had a hard time driving the car properly as it would traction roll any time i got aggressive.. i might have been the only one to traction roll a chicane lol.
not a bad result for the r1 though.
s2 managed middle of the B qualify and finish though i didnt really work on it too much through the weekend. it too had some problems with grabbing and pitching over when i tried to chuck the nose in heh.
ill run fewer classes next time. on the fence if ill get an r2 or not. im sure the price will keep me in the camp though. I cant be spending $500 on kits.
My stuff
My RC
Old 01-12-2015, 03:44 PM   #3533
So here's the deal on this subject...
Talking about the rear only here. Using my R1 to measure. But trying to make changes to my S1/S2.
Stock on the R1 is the ... inboard on the fronts. I've got .. on the rears. That gives me 2.5 degrees in.
If I try and stay with the plastic mounts on the front of the S, the holes are much more off-center than the aluminum mounts with the ... inboard.
So with plastic mounts on the front (of the rear) and the aluminum mount on the rear EVEN WITH the . in, you'd still be at 2.5 degrees. Because the .5 degree you pick up on the rear, you more than offset up front. Got it?
Executive summary: If you're trying to get something other than 2.5, 3.0 or 3.5 rear toe on the S model, you need aluminum mounts front and rear (on the rear).
Old 01-12-2015, 05:53 PM   #3534
rtenzo02's Avatar
Thanks for clearing that up. Mounts should be here in a couple days and I'll do it right. Tomorrow night I'll practice with 2.5 and see how it handles.
Old 01-12-2015, 07:40 PM   #3535
rtenzo02's Avatar
I just installed the rear R1 mount using the 1 . inserts with the stock plastic S1 rear seperate mounts and I definitely have more rear toe-in then I did using all S1 parts including the 3 mount. Without measuring just eyeing it I can already tell. Maybe using my camber gauge against a wall I can get a more accurate figure.
Old 01-12-2015, 09:39 PM   #3536
rtenzo02's Avatar
Up against a wall I am getting 2.5 toe ! It looks like more than I had with the plastic 3 insert , maybe I should have my eyes checked , lol. Funny thing is the 1. Inserts allow the hinge pins to sit wider apart than the 3.0 S1 mount does when comparing. Flipped the S1 seperate mounts around and I get 3 of toe.
Old 02-02-2015, 11:57 PM   #3537
I'm looking for a servo saver for the S1/S2, any recomendations? I stripped out a ball cup on the tie rod between the servo and bell crank after tagging the wall.
Also, are you guys running the battery with terminal to the rear or to the front?
Sometimes I post just to look at Kraig's avatar
RoyU is offline   Reply With Quote
Old 02-03-2015, 12:07 AM   #3538
valk's Avatar
Tamiya servo saver
My stuff
My RC
Old 02-03-2015, 01:36 AM   #3539
funked1's Avatar
Part #51000
XRAY T4 '17 VTA / Tamiya M07 / Tamiya Euro Semi / Speedworld Raceway
funked1 is offline   Reply With Quote
Old 02-03-2015, 02:50 PM   #3540
Butler02's Avatar
I HIGHLY recommend an x-ray servo saver.
Lou's Speedway and Hobbies
Spec-R R1 USGT, R2 Stock TC, S1/R1 hybrid "Mod"
Airtronics MT-4
Butler02 is offline   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
