Old 10-16-2014, 08:23 PM   #3376
DBM
Originally Posted by big al View Post
Are those steering blocks an actual tamiya product? Or aftermarket?
Aftermarket.
These are the ones that I bought:
http://www.tqrcracing.com/shop/produ....asp?p_id=2731
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 10-20-2014, 04:07 PM   #3377
DBM
Originally Posted by Jorge T View Post
???? It is spec-r....
I'm a bit confused. The chassis is from Spec-R but comes in an ID Products bag? Hmmm.
Old 10-20-2014, 05:36 PM   #3378
funked1's Avatar
Just another data point... my S2 diff o-rings swelled up into donuts too. It felt fine when I assembled it initially, but the car had pretty severe understeer, so I tore the diff down to check. It wasn't so much that they were squeezing the outdrive axles, but they were coming out of their grooves and pressing on the 5x14 shims and causing a godawful amount of friction. Someone said TRF 5mm o-rings worked so those are on order...
Also the SPR010-SC screws do work on the HD Diff. As I mentioned before, the phillips head kit screws were falling apart almost instantly.
Streetjam SJF01 / M05 Ver.II R / Spec-R S1 VTA / Speedworld Raceway
funked1 is offline   Reply With Quote
Old 10-20-2014, 10:35 PM   #3379
Thats because its NOT a Spec-R made part. People just assumed :-)
Even on the Spec-R site it states ID Products as the manufacturer.
1101 is offline   Reply With Quote
Old 10-22-2014, 02:34 PM   #3380
DBM
To me, it looked like an aftermarket item since it was listed under "iD products" on the specR site, but Jorge T said that it was a specR part. Unless iD products is a division of specR.
Oh well, it doesn't really matter.
I installed the chassis last night. All of the holes lined up perfectly. No additional shimming/removing of shims was required. A pleasant surprise is that this chassis is ~5mm narrower than the pro spec chassis (not including the servo mount protrusion on the pro spec chassis). The finish isn't as shiny on the new chassis, but that shouldn't affect the performance anyways.
Old 10-22-2014, 06:02 PM   #3381
Infamous 1ER's Avatar
What's the best web site to order parts? Thanks
Infamous 1ER is offline   Reply With Quote
Old 10-22-2014, 06:15 PM   #3382
tqrcracing.com
Goal Achieved....Not Dead Last.
mooby64 is offline   Reply With Quote
Old 10-23-2014, 08:20 AM   #3383
I've had no problem with the screws, but I bought an additional diff for my 2 cars and it cam with hex drive screws.
The O rings were a big issue I just bought the x-ray ones.
Syxxstring is offline   Reply With Quote
Old 10-23-2014, 01:17 PM   #3384
F1Jet's Avatar
Which gear diff did you get? (the S1 gear diff has different internal gears, seals, etc than the S2 gear diff).
Has anybody tried putting the S1 gear diff in the S2? Or vice versa? Were any advantages found? Any comments on which gear diff you thought was superior (in terms of drive ratio or not leaking or something else?
Also, tqrcracing only has internals for the S1 gear diff. Has anybody found a US source for S2 gear diff parts?
F1Jet is offline   Reply With Quote
Old 10-23-2014, 01:26 PM   #3385
F1Jet's Avatar
Default S1 center pulley and metal motor mount
Has anybody found a perfect way to install the center pulley in the S2 metal motor mount so there is no friction when the screws are tightened fully? The pulley shaft is longer than the width of the motor mount and the plastic bushings have flanges on them that can make a lot of drag.
Photos of your installation would be appreciated if you have them.
Old 10-23-2014, 02:00 PM   #3386
Either gear diff will fit either car.
Here's how I resolved the friction problem when the screws are fully tightened.
Wait for it...
I didn't tighten them fully.
For realz...
That and I mix and match the bushings. One white, one black. Or I sand down one bushing.
BTW, the flanges should be on the outside of the mount and will not touch the bearing inside the center pulley.
.crispy is offline   Reply With Quote
Old 10-23-2014, 03:47 PM   #3387
funked1's Avatar
Here's how I did it. I used POM bushings but it works the same with the black kit bushings.
Flanges go on the outside with a couple of 7mm x .3mm shims. You want to be able to tighten the screw all the way without compressing the bushings and bulkheads. Done up this way my spur assembly has only .1mm of axial play and nothing rubs.
Old 10-23-2014, 04:03 PM   #3388
F1Jet's Avatar
THANKS SO MUCH FOR THE FEEDBACK!
Old 10-23-2014, 04:04 PM   #3389
F1Jet's Avatar
Wait for it...
For realz...
THANKS! I WILL PUT A LITTLE THREADLOCK ON ALSO.
Old 10-25-2014, 02:22 PM   #3390
funked1's Avatar
Also, my pic is with a Kimbrough spur gear. If you have a wider spur, you might need to sand the bushings. With a narrow spur you might want shims between the bearings and the bushings.
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
