Old 10-08-2014, 09:40 AM   #3361
DBM
I have been looking for that stiffer baseplate for a while now.....I find the pro spec chassis to be very flimsy with all of the reliefs/cutouts that it has. Good to see that they have re-released it. I'll have to see if I can get my hands on one asap.
Edit: looks like Spec-R, RSD, and TQRC don't have any. Doh!
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 10-08-2014, 10:17 PM   #3362
Is this it ?
http://www.spec-r.com/default/index....roducts_id=685
Not a Spec-R, its an aftermarket part. Cheaper though
1101 is offline   Reply With Quote
Old 10-09-2014, 02:10 AM   #3363
Jorge T's Avatar
Originally Posted by 1101 View Post
Is this it ?
???? It is spec-r....
RSD MS
Jorge T is offline   Reply With Quote
Old 10-09-2014, 04:10 AM   #3364
funked1's Avatar
Any suggestions on longer body posts that would fit these cars? I'm trying to run a Tamiya Evo VII WRC body that is a little too tall in the rear for the stock posts.
funked1 is offline   Reply With Quote
Old 10-09-2014, 07:34 AM   #3365
Jorge T's Avatar
spec-r makes these-->>http://www.spec-r.com/default/index....roducts_id=302
RSD MS
Old 10-09-2014, 08:41 AM   #3366
where can i find gears for the diff??
DESOTO RACING,,SERPENT S411 3.0 USGT,,S411 3.0 17.5,,MOTIV,,FRP PAINT WORKS
starrx is offline   Reply With Quote
Old 10-09-2014, 09:14 AM   #3367
http://www.tqrcracing.com/shop/produ....asp?p_id=2178
.crispy is offline   Reply With Quote
Old 10-09-2014, 09:40 AM   #3368
funked1's Avatar
Originally Posted by Jorge T View Post
Thanks, I had been searching for "posts" instead of "holders". These look perfect.
Old 10-13-2014, 04:12 AM   #3369
Hi All,
A while ago I bought a bunch of new and second hand spares. In amongst them I have found a few 52mm drive shafts. This may be a stupid question, but why, when and how would I use them?
Ryan
Ryan
Tamiya M05
Spec-R S1
filippimini is offline   Reply With Quote
Old 10-13-2014, 04:47 AM   #3370
mrjudd77's Avatar
from memory the 52mm shafts should be used in the front with a diff setup. I may be wrong but I am sure someone will be along shortly to correct me.
HPI Sprint 2 Flux (second ed.) Porsche 911 GT3 (sold)
Spec-R S-1
Spec-R R-1
http://au.dollarshaveclub.com/ref/index/r/yc8/1wmmuv8/s/tx/cx/1/
mrjudd77 is offline   Reply With Quote
Old 10-13-2014, 07:52 AM   #3371
I just built two cars and got to run them this weekend. Friday night in a parking lot race and they still needed help. Worked on them through the night and got them okay, the shims under the suspension blocks are a must in my opinion. I would put them in as you build the car not only does it eliminate some of the ride hide adjustment issue the car handles much better too.
Sunday I took them down to TQ to get ready for the IIC because I cant be there for the practice days. Other than droop and some suspension adjustments the cars took little work to get good. We'll see how it goes in amateur and spec gt this weekend.
Overall, Im impressed with the quality of the car and performance, especially at the price. I have the aluminum shock bodies on one and it is a big improvement in shock assembly but the plastic bodies work well too. The other thing I did and , would recommend is using aluminum shims where the kit calls for plastic ones, more reliable and wont get sloppy in a crash.
Syxxstring is offline   Reply With Quote
Old 10-13-2014, 08:29 AM   #3372
DBM
What size roll center shims did you use under the lower suspension holders?
Old 10-16-2014, 07:55 AM   #3373
DBM
I placed an order for the new chassis plate and top deck yesterday. Hopefully I'll have them in time to try them out at Wednesday night practice next week. I'll move the stock pro spec chassis and top deck over to my S1 VTA car, which will make the S1 mostly R1 pro spec (stit still has plastic bulkheads and frp shock towers).
Old 10-16-2014, 11:50 AM   #3374
DBM
I forgot to mention. ...I finally got around to installing the tamiya 417 steering blocks in my S1 VTA car. The fit well, with the only exception being that the bearings are 0.5mm closer together. I used a pair of 0.3mm shim washers to take up the difference.
Old 10-16-2014, 07:32 PM   #3375
big al's Avatar
Are those steering blocks an actual tamiya product? Or aftermarket?
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13450 04-21-2017 01:38 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
