Old 08-13-2014, 01:02 PM   #3211
In my case, the car would be a back-up car for myself and a race spec chassis for my youngest girl (who is able to do some good laps).
Preparing a car isn't a problem, been racing for about 10+ years and i should be able to setup a car correctly.
The car would not be used that much as my TRF418, cause my youngest girl does not have that much opportunity to drive as i do.
Therefor i'm thinking about buying a race spec chassis, but without spending the same amount of cash as on a TRF418 or others.
Over here everybody is driving a yokomo or an Xray or VBC but not so many people do drive this Spec-R brand.
I've been to races where some pilots drive a R1 or a S1 and they all get good results out of it and that's why i've been keeping an eye on this brand for some years now.
Another reason why i do intend to buy a Spec-R chassis is my youngest girl has Red,Fluo pink and white for body colors and it matches the red parts of the car
addicted2blue is offline   Reply With Quote
Old 08-13-2014, 01:14 PM   #3212
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Every car is different dispite how similar they may seem. I'm sure if you spent some time on the r1 you would get it to do everything your 418 can.
Parts support shouldn't be a problem over there if you don't mind rcmart or specr direct.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 08-13-2014, 05:22 PM   #3213
Trader Rating: 16 (100%+)
Originally Posted by addicted2blue View Post
As i'm thinking about buying a back up car (SpecR S2) for myself and for my little girl to run it with a silvercan motor i do have some questions.
-Is it possible to mount the R1 motormount on the S2 chassis? (this motor mount is usefull when driving a silvercan)
http://www.spec-r.com/default/index....roducts_id=398
-What are the necesary parts that need to be upgraded to get the car to a good standard. (I was thinking about alu steering, suspension mounts, alu servo holder, alu shock body's and gear shaft bushing set)
I would like to use the car for silvercan racing and for using it with speedpassion ESC/motors.
So i'm searching for buying 1 car who is able to have all the above mentioned ESC/motor combo's without spending to much money.
The only parts I feel are mandatory are alum shock bodies, different springs (I'm running RSD X-ray 20mm and they are great) and x rings in the gear diff. Ran the car this way for the first time in a larger regional club race and it can compete just fine. Added metal pivot balls and alum shims, El Cheepo S2 is very decent.
imajerky is offline   Reply With Quote
Old 08-14-2014, 01:03 AM   #3214
mrjudd77's Avatar
I am still running the stock springs and am considering this as my next upgrade. Which springs is everyone using?
HPI Sprint 2 Flux (second ed.) Porsche 911 GT3 (sold)
Spec-R S-1
Spec-R R-1
http://au.dollarshaveclub.com/ref/index/r/yc8/1wmmuv8/s/tx/cx/1/
mrjudd77 is offline   Reply With Quote
Old 08-15-2014, 06:43 AM   #3215
Hey guys I'm interested in the R1 pro spec. How is that car? I will be racing it in USGT class. TQ racing has it for $279.99 so kinda got me interested. Y'all seem to be running the S1 or S2 version which is the lower priced ones correct?
wil
Never give up!
Traxxas Slash 2wd, Spektrum DX4c, Associated B5m
Wil Holmes is offline   Reply With Quote
Old 08-15-2014, 06:57 AM   #3216
rtenzo02's Avatar
Asphalt or carpet ? Most of the research I've done showed tamiya blue and whites being used a lot and hpi silver.
rtenzo02 is offline   Reply With Quote
Old 08-15-2014, 07:00 AM   #3217
wil
I have all three R1 Pro Spec, S1 and S2. With some upgrades (sway bars, etc.) the S models run about the same as the R1. In fact, my true cost of the S2 is more like $200 with the parts I want to run.
Oddly, my R1 is my VTA car and I have to add a ton of weight. The S2 is my USGT car and it is overweight. I should switch them.
The R1 is perfect for USGT.
.crispy is offline   Reply With Quote
Old 08-15-2014, 07:30 AM   #3218
Thanks .crispy, sounds like the pro spec it is
Never give up!
Old 08-15-2014, 04:11 PM   #3219
mrjudd77's Avatar
rtenzo02. I mainly run asphalt. I was thinking about a full set of springs, just so I had options
Spec-R S-1
Spec-R R-1
Old 08-15-2014, 04:48 PM   #3220
Default Kit Springs
Speaking of kit springs, What are they rated at, compared to the 2.5-2.8 carpet spring kit?
Goal Achieved....Not Dead Last.
mooby64 is offline   Reply With Quote
Old 08-15-2014, 08:16 PM   #3221
rtenzo02's Avatar
Tamiya set #53440, not sure I've seen any thing else sold in sets, around $15 which isn't bad considering it comes with 4 sets of springs to chose from.
Old 08-16-2014, 09:49 AM   #3222
32819toon's Avatar
I'm running the S1 with alu bulkheads and suspension mounts, and use Xray springs. Was running gold in rear and silver in front, but have just changed to blue up front to tame the car down a bit, and I ran my best times for ages on Thursday night.
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 08-16-2014, 12:37 PM   #3223
Mitamiya's Avatar
Trader Rating: 14 (100%+)
Now that there is an S2, will they be releasing an R2 soon?
MItamiya
Currently Racing
Offroad - Associated B5M Lite
Onroad - TRF 418 Samix VTA/TRF 419 USGT
Mitamiya is offline   Reply With Quote
Old 08-16-2014, 12:59 PM   #3224
rtenzo02's Avatar
I'm wondering if anyone's ever removed the outer servo mount (stock s1) to achieve the floating servo affect ? The only bad thing I noticed about the idea is the servo mounts only use 1 screw so thinking about ca gluing it to the chassis with the single screw for extra strength to avoid the mount twisting. Any opinions ? Thanks in advance !
Old 08-16-2014, 02:32 PM   #3225
mrjudd77's Avatar
Mitamiya. I emailed Spec-R a little while ago and asked that very question. Their reply was short and sweet. There is an R2 on the way but hey can not confirm a release date as yet. I will contact them again shortly and see if we can get an update as we have just finished our race season and I would like to upgrade to a new car before the start of the next season.
Spec-R S-1
Spec-R R-1
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
