Old 07-11-2014, 05:12 AM   #3136
mrjudd77's Avatar
Having bunched wires around the receiver could be a problem as well. I will post some pics if I think of it tomorrow
HPI Sprint 2 Flux (second ed.) Porsche 911 GT3 (sold)
Spec-R S-1
Spec-R R-1
http://au.dollarshaveclub.com/ref/index/r/yc8/1wmmuv8/s/tx/cx/1/
mrjudd77 is offline   Reply With Quote
Old 07-13-2014, 04:34 PM   #3137
poeee's Avatar
Another gearing question for my S1. After a rule change making 21.5 boosted obsolete, I've swapped it to blinky. I currently have the FDR at 3.5, but still need to go further. 3 or below even. I have a 48P 69T spur with 37T pinion in there now. Am I able to run a 66T spur and 42T pinion?
Scott Pocock | Geelong Radio Control Car Club www.grccc.org.au
poeee is offline   Reply With Quote
Old 07-13-2014, 11:15 PM   #3138
I ran my 21.5 blinky s1 with a 65t spur and a 45t pinion on the weekend (turnigy trackstar motor with max timing). Fits fine - I just had to set mesh without the pinion on due to not being able to get to the motor screws.
Simon
Team_Krusty is offline   Reply With Quote
Old 07-14-2014, 04:33 PM   #3139
Send a message via AIM to JimmyMack12
Re: S1
I broke one of the front "driveshafts"/dog bones on my S1.
What's a better/stronger replacement?
JimmyMack12 is offline   Reply With Quote
Old 07-14-2014, 05:03 PM   #3140
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
http://www.tqrcracing.com/shop/produ....asp?p_id=8101
ive bent one or two of the old style swingshafts but these djcs seem to be holding up pretty good. i have the older style, shiney metal finish.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 07-15-2014, 11:45 PM   #3141
poeee's Avatar
Simon
Same motor. Should I go straight to FDR 2.75 like you?!?!
Old 07-16-2014, 04:09 AM   #3142
Got a bit hot. Wind back the timing and have a good fan and you should be fine.
Old 07-16-2014, 05:29 PM   #3143
poeee's Avatar
Cheers! I very much appreciate your reply as I wouldn't have bought gear to go that low.
Old 07-17-2014, 08:04 AM   #3144
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
if anyone is interested in a brand new, built with hop-ups S1, shoot me a PM.
I've come to the conclusion that I have WAAAYYY to many cars for the amount of actual racing I do anymore, and well, unfortunately this one needs to go.
S1 with the following:
aluminum steering rack
aluminum floating servo mount
aluminum suspension mounts
sway bars
all aluminum spacers (no plastic ones anywhere on the chassis)
red screws in the bottom of the chassis
like I said, not trying to sell it here - just merely offering it up. shoot me a PM or email and I can give you the rest
thanks
kaybo
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-17-2014, 07:14 PM   #3145
Thanks.
I don't have my manual handy, but, isn't one set of driveshafts 50mm and the other 52mm? Do these come in both sizes?
Old 07-18-2014, 10:07 AM   #3146
k_bojar's Avatar
Originally Posted by JimmyMack12 View Post
Thanks.
the S1/S1 came with 50mm front and rear. the R1 has 52m front and 50mm rear
Old 07-18-2014, 05:02 PM   #3147
valk's Avatar
I took a look at it but my s1/r1 parts are all intermixed. i do have 52s and 50s though. seem to remember the s1 being the same f/r. id be curious to get into a 48 as im running a fairly narrow car.
My stuff
My RC
Old 07-20-2014, 05:11 AM   #3148
Hi Guys,
I've just bought an S1. Will these kawada spurs fit?
http://www.rcmart.com/kawada-s4866t-...r-p-16083.html
Ryan
filippimini is offline   Reply With Quote
Old 07-22-2014, 08:16 PM   #3149
nexxus's Avatar
Trader Rating: 300 (100%+)
Guys need some help here, I have two TC's a Spec R R1Pro and a T4 2014 but only need to keep one, the T4 has a higher resale and I have fewer spares for that but is there going to be a notable difference in performance / driving between the two? I run 13.5 Blinky.
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 07-23-2014, 01:05 AM   #3150
mrjudd77's Avatar
There will be no noticeable difference in speed between the 2 cars in 13.5 blinky. The choice you need to make is which car can you get parts for more reliably? Which car has the lower running costs (broken parts replacement, regular service items, etc)
My choice would be the SpecR (and is) I run a R1 and have an S1 as well and enough parts to make another nearly 2 S1's.
Spec-R S-1
Spec-R R-1
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
