Old 07-07-2014, 03:54 PM   #3121
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by rtenzo02 View Post
What's the 3x12mm screw that goes in the inside servo mount for on the S1 chassis, the manual shows it screwed in with 6mm of thread left unscrewed.
it's to help keep the battery on place and off the belt. you'll notice another similarssetup off the motor mount as well
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-07-2014, 03:56 PM   #3122
To keep the battery off the belts and secure it up to the outside brackets.
.crispy is offline   Reply With Quote
Old 07-07-2014, 05:04 PM   #3123
rtenzo02's Avatar
OK thanks , haven't fitted a battery just yet .
rtenzo02 is offline   Reply With Quote
Old 07-07-2014, 06:26 PM   #3124
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
http://www.petitrc.com/reglages/spec...toria20140622/
this is what i ran on sugarwatered ashphalt this last week at speedweekend. only difference was sorex tires instead of muchmores.
I think i adjusted the droop to 5 but ive started checking ORH.
not bad for a car that in total might have cost $550. racing against a fully kitted Xray and Yokomo.
My stuff
| Sanwa M12 - Team Associated - Reedy - ProAMPS RC - Novarossi |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/
valk is offline   Reply With Quote
Old 07-07-2014, 07:33 PM   #3125
mrjudd77's Avatar
Had our regular Friday night racing this week. Was running at the front of the pack and had started lapping slow traffic, when from out of nowhere my car did a right hand turn straight into the fence. The glitch has returned. I am almost at my wits end getting this glitch out. Might have to change radio again, new battery and new speedy again. These are the only things I can think of. Anyone else got suggestions?
HPI Sprint 2 Flux (second ed.) Porsche 911 GT3 (sold)
Spec-R S-1
Spec-R R-1
http://au.dollarshaveclub.com/ref/index/r/yc8/1wmmuv8/s/tx/cx/1/
mrjudd77 is offline   Reply With Quote
Old 07-07-2014, 07:47 PM   #3126
PEEKracing's Avatar
Push every single pin for every single connector in all the way, individually, with a small hex driver. Including each end of your sensor cable. Do it Evey time you go out on the track.
Also if you cut the end of your antenna either on the receiver or the transmitter, did you remember to expose 32.1 mm of the central wire in the coaxial cable? Maybe check that the antennas are both well connected to their circuit boards too... Add a glitch buster.
PEEKracing is offline   Reply With Quote
Old 07-07-2014, 09:34 PM   #3127
shiston's Avatar
What about your servo? Maybe try another one and see
Hang around......we'll talk some more
shiston is offline   Reply With Quote
Old 07-09-2014, 02:26 AM   #3128
mrjudd77's Avatar
servo is brand new and I have tried 3 different brands (bluebird, savox and now trackstar). glitch buster is attached and all connections have been checked.
It feels like a power loss. The antenna is at original length. I might see if I can find another receiver for the Futaba 3pl. Would love to find an orange receiver for it.
Spec-R S-1
Spec-R R-1
Old 07-09-2014, 03:48 AM   #3129
PEEKracing's Avatar
Is your antenna standing vertical? Since you've tried all new electronics the only thing else I can think of is placement or battery connectors.
Old 07-09-2014, 04:31 AM   #3130
bakoo's Avatar
Thought I mentioned it here the other day, but try moving your receiver and antenna a bit further away from the the CF chassis. I had the same problem a while ago, and moved the receiver the same day I swapped out my second Savox servo for a Sanwa - can't tell which of those did the trick, but the combination worked.
bakoo is offline   Reply With Quote
Old 07-10-2014, 05:37 AM   #3131
mrjudd77's Avatar
PEEK antenna does bend in a long radius in a plastic cover to stay under the roof. might try it vertical.
bakoo if this does not work (vertical antenna) than I will try rearranging the electronics.
These are the first things to try as they are a free fix. Then I will go back to replacing things.
As usual I will keep you all updated so that we can find another solution or if it is fixed then it is one more bit for the knowledge bank.
Spec-R S-1
Spec-R R-1
Old 07-10-2014, 09:10 AM   #3132
valk's Avatar
http://youtu.be/8_xsD-dxeRs
My stuff
My RC
Old 07-10-2014, 12:29 PM   #3133
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Originally Posted by valk View Post
Nice parking lot track!
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 07-10-2014, 02:56 PM   #3134
PEEKracing's Avatar
That's the best looking temporary track I've ever seen!
I put my antenna vertically as high as possible in a tube under the body, the top of the tube might be 1mm away from touching, I haven't had any trouble yet. The excess antenna lead I've bunched up next to the receiver.
Old 07-10-2014, 05:25 PM   #3135
valk's Avatar
would just be nice if the weather and fourth of july weekend didn't scare away most of of our regulars =(
we were down on attendance by probably HALF.. but whateves. we hold this race on the same weekend every year and this year had some of the tightest racing EVER. despite the awkward weather.
I think if i had let craig get a bit of a gap, he might have been able to catch up to ryan, and we could have done a three way run at first but.. its the main.. hard to say. was sure exciting though.
For ashphalt, id say my r1 was pretty dialed but could have done with a little more traction.
carpet is where i seemed to struggle with it. but thats a few months away. hopefully we get the new motor mount and CF towers in time for indoor season. I prob wont buy an R2 if thats all there is to change, but a few of the parts for sure.
My stuff
My RC
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13450 04-21-2017 01:38 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
