Old 06-05-2014, 04:08 PM   #3061
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by Jorge T View Post
Here is my setup for this past Sundays' USGT class TQ and Win at the Texas EOS Rd1
only 3k in the front diff?? seems kind of light?
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 06-05-2014, 05:10 PM   #3062
Jorge T's Avatar
Running spool in front ...put the X there but forgot to erase the oil from the rear diff
RSD MS
Jorge T is offline   Reply With Quote
Old 06-08-2014, 06:15 PM   #3063
rtenzo02's Avatar
Does anyone have experience with BOTH, tamiya low friction dampers (53155) and specr r s1 dampers ? Im missing 1 tamiya damper so I'm debating between buying a set of spec r dampers vs buying a pair of tamiya low friction dampers to complete my set. Which dampers are better, will there even be a noticable difference between the two in a 17.5 class ? I was even gonna try a set of GPM dampers I have but there so odd ball from the mounting hole size to there large diameter springs , I think I'm better off leaving them on my drift car.
KLRacing*TamiyaTRF*Orca*Fantom*Savox*
rtenzo02 is offline   Reply With Quote
Old 06-08-2014, 06:47 PM   #3064
mrjudd77's Avatar
rtenz I would run all tamiya low friction dampers. The spec-r ones are good, but if you already have the tamiya ones then I would just stick to them. Don't even entertain the thought of the GPM ones. They are not adjustable enough and are too heavy. I wouldn't even use them on my drift car
HPI Sprint 2 Flux (second ed.) Porsche 911 GT3 (sold)
Spec-R S-1
Spec-R R-1
http://au.dollarshaveclub.com/ref/index/r/yc8/1wmmuv8/s/tx/cx/1/
mrjudd77 is offline   Reply With Quote
Old 06-08-2014, 09:06 PM   #3065
rtenzo02's Avatar
Lol , yea the gpm's are really stiff and large compared to the low friction dampers, thanks for your response mrjudd
Old 06-10-2014, 03:06 AM   #3066
mrjudd77's Avatar
I know it has been asked before I am being a tad lazy at this point. Does anyone have the part number for the tamiya low friction ball cups? What ball studs would work better with these and anyone found titanium turnbuckles to replace the alloys? I have some in my upper fronts but they are a touch too long.
Spec-R S-1
Spec-R R-1
Old 06-10-2014, 03:18 AM   #3067
SteveM's Avatar
Trader Rating: 128 (100%+)
Tamiya low friction ball cups part #53601. I use the Tamiya ball studs.
SteveM is offline   Reply With Quote
Old 06-10-2014, 04:34 AM   #3068
mrjudd77's Avatar
Thanks Steve. I have been having trouble with the tamiya cups popping off of the standard spec-r ballstuds
Spec-R S-1
Spec-R R-1
Old 06-10-2014, 07:22 AM   #3069
Jorge T's Avatar
Also the 3Racing 4.8mm ball studs work well.
RSD MS
Old 06-10-2014, 11:51 AM   #3070
slakr's Avatar
Trader Rating: 28 (100%+)
What brand spur gear is everyone using on the Spec-R? Ordered the S2 yesterday and looking to put on a 96T 64P spur to run 17.5 blinky. Thanks.
JQ THEeCar Black,THECar White~Mugen MBX7TR Eco~TLR 22 3.0SR,22-4 2.0~XRAY XB2C
AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is online now   Reply With Quote
Old 06-10-2014, 11:54 AM   #3071
k_bojar's Avatar
I have a PRS spur in mine. Tried a 3racing (87t) but it had a lip, think it wasn't big enough, that messed with the pulley attaching
as long as its a flat sided on, and has mounting holes at N/S/E/W, you should be fine
Old 06-10-2014, 11:03 PM   #3072
mrjudd77's Avatar
got a part number there Jorge?
Spec-R S-1
Spec-R R-1
Old 06-11-2014, 12:27 AM   #3073
DBM
I've used both kimbrough and 3racing spurs in my R1 and S1. The 3racing spurs have been more true than the kimbrough ones that I've had, but the kimbrough ones work just fine (I have a 96t kimbrough in my R1 right now)
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 06-12-2014, 08:15 AM   #3074
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
What is the largest kimbrough spur that fits this car? 64p. Gearing for a 4.5t tekin gen 2 around 8.5 fdr
My stuff
Sanwa M12 - Xray T4/16 - Xray Nt1/16 - CRC XTI-WC - ProAMPS - Hobbywing - ReVTECH - ORCA
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com
valk is offline   Reply With Quote
Old 06-12-2014, 09:09 AM   #3075
Jorge T's Avatar
3RAC-BS4809S 9mm or 3RAC-BS4806S 6mm for steel. These have a 1mm longer neck than Tamiya. They also have aluminum ball studs in different colors and lengths.
I'm using a Panaracer 96T 64p spur and they fit perfect. I can use both POM spacers and still have ~0.1mm side to side clearance.
RSD MS
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13440 03-26-2017 08:58 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
