Old 05-22-2014, 02:51 PM   #3031
mrjudd77's Avatar
red alloy or Ti screws?
HPI Sprint 2 Flux (second ed.) Porsche 911 GT3 (sold)
Spec-R S-1
Spec-R R-1
http://au.dollarshaveclub.com/ref/index/r/yc8/1wmmuv8/s/tx/cx/1/
mrjudd77 is offline   Reply With Quote
Old 05-22-2014, 05:37 PM   #3032
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by DBM View Post
Where did you get the red screws from?
Not sure where he got his screws from but here is a place where you can order screws from.
http://www.fastener-express.com/metr...ap-screws.aspx
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 05-22-2014, 10:32 PM   #3033
DBM
Thanks for the link!
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 05-26-2014, 06:39 AM   #3034
DBM
As my skill level increases, I find myself enjoying the R1 more and more all of the time. Every week, I get comments on how "smooth" the car drives on the track.
I ran my S1 in VTA/CTA for the first time yesterday, and right or of the box, it was posting lap times right up there with the fast guys. It was also an absolute pleasure to drive. What a great VTA chassis for $120. I imagine the S2 should be even better.
Running two classes was hectic, though, and my girlfriend has expressed interest in trying rc, so I might put the vta car in her hands and free up some of my time to work on the R1 in 17.5 stock touring.
Oh, after a month of installing the avid revolution bearings in my car, I now have a pile of crunchy avid wheel bearings sitting on my bench. The ones in the drivetrain ate still working fine though. I installed murffdog abec 5 bearings yesterday. I'll report back on how well they stand up.
Old 05-26-2014, 07:10 AM   #3035
Trader Rating: 30 (97%+)
I got the hiro Seiko ones from pitbox they hold up really well compared to square de ones or fast ones, almost done, just waiting on wires
zaraz is offline   Reply With Quote
Old 05-26-2014, 10:03 AM   #3036
I had some xray carbon battery supports, they fit with minamal mods, and look like they belong on the car, I will post pictures once the whole car is done, what a fun built, and when everything goes perfectly, even a better built then the x ray t4 14, from what my s2 can do, I hope this will be a step better, but work gets in the way of completion lol.
Old 05-26-2014, 10:07 AM   #3037
SteveM's Avatar
Trader Rating: 133 (100%+)
I'm still using the R1 plastic lipo pack guide with the stock velcro strap. Why is it necessary to change from the kit setup?
SteveM is offline   Reply With Quote
Old 05-26-2014, 10:14 AM   #3038
DBM
I found that my corner weights would change due to tweak when using the velcro strap. Putting the strap on loose enough to not cause tweak resulted in my lipo popping out. I still use the plastic holders, but use a 1mm carbon fiber strap and a pair of standoffs to hold the lipo in now. No more tweak from the strap. I also found that the velcro strap kind of got in the way when working on the car.
Old 05-26-2014, 11:02 AM   #3039
SteveM's Avatar
I found that my corner weights would change due to tweak when using the velcro strap. Putting the strap on loose enough to not cause tweak resulted in my lipo popping out. I still use the plastic holders, but use a 1mm carbon fiber strap and a pair of standoffs to hold the lipo in now. No more tweak from the strap. I also found that the strap mind of got in the way when working on the car.
OK, now I see. I use the Tuning Haus lipo retainers on my Schumacher Mi5 as I hate using battery tape. I run my R1 in club VTA races and haven't had any issues with tweek in this class.
Old 05-26-2014, 01:16 PM   #3040
Hi steve, I like my bling, carbon bumper support, anodized screws, and now carbon battery support, I am going to run usgt with this car, so really the strap is fine, just a cosmetic thing, once I get a chance to put a picture up, you will notic how well they fit, only have to drill one hole which is already marked
Old 05-26-2014, 01:44 PM   #3041
SteveM's Avatar
Post pics when you can please.
Old 05-26-2014, 04:07 PM   #3042
rtenzo02's Avatar
Has anyone experienced problems with the xray plastic caps on the the end of the driveshafts that go in the rear diff out drive cups fitting extremely tight ? One side is smooth and slides in the out drive cup a bit , the other side was extremely tight and would not slide at all even with a good amount of force. I removed the plastic cap and cleaned it up a bit by lightly sanding it , helped a little but still quite a bit tighter than being able to move easily. S1 standard gear diff cups by the way and the 50mm swingshafts.
KLRacing*TamiyaTRF*Orca*Fantom*Savox*
rtenzo02 is offline   Reply With Quote
Old 05-26-2014, 04:55 PM   #3043
Upper deck question...
I broke my R1 Pro Spec's upper deck. Head first into the boards at top speed after clipping the inside corner.
Anyhoo, I noticed that NONE of the upper decks available for sale match mine exactly. Mine is parallel all the way to the front similar to the Type A but it has more holes that would line up with the new style motor mount.
The Type A has no holes in this area.
Which is better, the Type A or the original 2.0mm that tapers in?
.crispy is offline   Reply With Quote
Old 05-26-2014, 05:52 PM   #3044
nudge2325's Avatar
Well I finally bit the bullet and got an R1 ProSpec.
I got it 2nd hand from a local racer and I must say I like the quality of the kit and how smooth the drivetrain is.
I bolted an ancient 13.5t Novak SS motor into it with SP Reventon speedy and Savox servo and DAMN this thing is quick.( Note I haven't raced in about 3 years so maybe thats why it feels so fast.)
Now all I have to do is buy the missing parts for the Sway Bars and get the correct setup and I can finally get back into racing.
I will post pics in a couple of weeks when i get home from work.
Cheers
Nudge
nudge2325 is offline   Reply With Quote
Old 05-26-2014, 07:12 PM   #3045
DBM
How do you like your mi5? I'm intrigued by the design (there are so many thinabout it), and was thinking that it might be a fun car to play with when I become bored of my R1.
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
