Old 04-07-2014, 04:33 PM   #2851
mrjudd77's Avatar
Mine had the alloy fan mount. Given the choice I would buy it anyway, it just looks good.
On fan mounts, has anyone noticed that the fan mount on the S2 has changed? It looks like it can now mount a larger fan 40mm maybe?
HPI Sprint 2 Flux (second ed.) Porsche 911 GT3 (sold)
Spec-R S-1
Spec-R R-1
http://au.dollarshaveclub.com/ref/index/r/yc8/1wmmuv8/s/tx/cx/1/
mrjudd77 is offline   Reply With Quote
Old 04-07-2014, 04:34 PM   #2852
Plastic parts don't get others to go "oooow, look at all the shiny red aluminum... what kind of car is that?" when other racers look at your car.
.crispy is offline   Reply With Quote
Old 04-07-2014, 05:03 PM   #2853
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
heh... people only go oooh ah if i win.. if i lose, they wonder why i dont have an xray.. or serpent lol.
id say the aluminum mount would be a requirement. ive only used my stock s1 mount a few times but its pretty flimsy. i have fear of it tearing right off in an accident. doesnt secure the fans ive used that great either.
alum belt tension is kinda unnessisary though. I dont even run the plastic one. you should have your cams tight enough that they wont skip. if it feels bindy, make sure all the bulkheads are aligned properly and not pinching any bearings. thus, make sure your top deck is installed and secured properly before adjusting the belt tension.
With brushless i cant imagine belt friction being a significant issue.
My stuff
| Sanwa M12 - Team Associated - Reedy - ProAMPS RC - Novarossi |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/
valk is offline   Reply With Quote
Old 04-07-2014, 06:09 PM   #2854
mrjudd77's Avatar
I see what you mean there valk with the tensioner. The belts should be tight enough to not flop around but loose enough to not cause drag
Spec-R S-1
Spec-R R-1
Old 04-07-2014, 07:24 PM   #2855
valk's Avatar
got my prospecs today.. hoooooly crap im in parts for a while. i actually have to pick and choose what goes into the spares pitbox and what has to stay at home lol. between that lot of stuff and my s1... i got parts lol.
probably prepare one for play this weekend. our last indoor race of the year.
then its outdoors.
My stuff
My RC
Old 04-08-2014, 06:21 AM   #2856
SlowGuySam's Avatar
MrJudd thanks for the sway bar info. Too bad they don't pre package a kit to make it easier I really am going nuts waiting for my S2. Everyday I have to stop myself from buying a random part I think I need before I even get my kit in hand.
SlowGuySam is offline   Reply With Quote
Old 04-08-2014, 06:28 AM   #2857
I have a system for that. I use my "Wish List" on the TQ RC site for that. I put everything I might need there. Then when I break a part or I need new wheels/tires that goes in the "Cart". Then I peruse the Wish List to round out my order to $100.
Old 04-08-2014, 10:26 AM   #2858
valk's Avatar
Ps. Dunno if its mebtion you also need additional rod ebds for swaybars. Good time to get tamiya ones. Use tamiya for all steering links and upper arms, stock for swaybars.
I think the manual specifies how long to make all the rods and you will have to compensate the difference in the tamiya ends.
There is a table to set toes with the inserts but is there a relation table comparing it to trackwidths? Would be nice to leave the steering links alone and adjust toe with inserts only.
My stuff
My RC
Old 04-08-2014, 07:30 PM   #2859
mrjudd77's Avatar
Thanks for the correction Valk.
Crispy. I use the same method on a couple of sites with the wish list. Wish lists are the best invention in RC shopping.
Spec-R S-1
Spec-R R-1
Old 04-09-2014, 05:26 AM   #2860
PEEKracing's Avatar
I've not seen such a table, but I was thinking about making one, though time I have not.
As for adjusting front toe only with inserts I'm not sure that would work, as adding toe-in will swing the wheel end forward, thus pulling on the steering links and removing toe-in. Vice versa for toe out. However, the change may not be so great as to be measurable, I've not done the geometry.
PEEKracing is offline   Reply With Quote
Old 04-09-2014, 08:23 AM   #2861
Butler02's Avatar
The same table for the toe does help with track widths. If you look at it, it shows how the same degree of toe can be found several different ways. Each different combination is going to be a different track width varying by half millimeter increments. Looking at the chart, it looks like for the rear the widest track width combos are on the left and get narrower as you go to the right. Being narrower also allows more toe options.
Lou's Speedway and Hobbies
Spec-R R1 USGT, R2 Stock TC, S1/R1 hybrid "Mod"
Airtronics MT-4
Butler02 is offline   Reply With Quote
Old 04-09-2014, 09:57 AM   #2862
PEEKracing's Avatar
Well there you have it...
Old 04-09-2014, 10:22 AM   #2863
JayL's Avatar
my r1 prospec is narrow with the stock toe block settings. Are you guys running it wider?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 04-09-2014, 11:33 AM   #2864
valk's Avatar
Most of the setups I've seen on petit use the wider toe block settings. I'd say outer for carpet, inner for ashphalt but ill have to get back to you on that. I might run front parallel and just adjust by turnbuckle. Arm sweep also changes wheelbase.
My stuff
My RC
Old 04-09-2014, 02:13 PM   #2865
mrjudd77's Avatar
toe options are a litte beyond my comprehension. anyone able to explain this in plain english and give he benefits?
Spec-R S-1
Spec-R R-1
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13450 04-21-2017 01:38 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
