Old 04-03-2014, 07:29 PM   #2806
Darrin70's Avatar
Originally Posted by metalnut View Post
I think it's the design combined with the plastic, not a good combination for sure. I broke mine so often that I literally carried several spares for each race night.
Yeh, would like to see them seperate the rear hub and steering knuckles which are sold together?? I never break a rear hub and have about 5 of them...lol
HYPERHOBBIES
YOKOMO
SKYRC
SWEEP RACING
SMC
Darrin70 is offline   Reply With Quote
Old 04-03-2014, 10:18 PM   #2807
Butler02's Avatar
The number of rear hubs I have is obscene. Darrin the next time you're at Lou's come check out my parts box lol! It's sad how many I've gone through. I put a peice of kydex under my bumper foam and it's helped ALOT!
I thought a saw a picture somewhere of carbon plastic parts for this car. Maybe their Facebook page. I'll look into it more in the morning. I don't want to start rumours on an "I think I saw..."
Lou's Speedway and Hobbies
Spec-R R1 USGT, R2 Stock TC, S1/R1 hybrid "Mod"
Airtronics MT-4
Butler02 is offline   Reply With Quote
Old 04-04-2014, 03:08 AM   #2808
SteveM's Avatar
Trader Rating: 128 (100%+)
I've had two S1 and now have an R1 and I have only ever broken one C-hub ever. I've never broken a suspension arm either. You guys must be more aggressive than me or your tracks are tight and unforgiving.
SteveM is offline   Reply With Quote
Old 04-04-2014, 07:32 AM   #2809
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Thee has to be a way to sace the steerin blocks from failure,, always at the bottom screws. Maybe larger bushings with a urathane insert to give it a tiny bit of give if you crash?
I had like 4 steering bkocks abd broke 3 at one carpet race lol not even really hitting things. Just a swipe into a board sideways.
Might start using t4 blocks as its the only thing I break.
My stuff
Sanwa M12 - Xray T4/16 - Xray Nt1/16 - CRC XTI-WC - ProAMPS - Hobbywing - ReVTECH - ORCA
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com
valk is offline   Reply With Quote
Old 04-04-2014, 11:40 AM   #2810
DBM
Aluminum bits for a 417 fit the front, but the rears need a larger diameter pivot pin to work.
DBM is offline   Reply With Quote
Old 04-04-2014, 12:09 PM   #2811
valk's Avatar
Naaaaah. That's what a 12th scale costs. You csn get an s2 fir $119 though st tqrcracing.
Graphite and aluminum parts are pretty expensive. Even if they are made in china.
My stuff
My RC
Old 04-04-2014, 12:32 PM   #2812
metalnut's Avatar
Trader Rating: 36 (100%+)
Originally Posted by lukebluske View Post
I'm still pretty new to the hobby and I still think $290 for a 1/10 rolling chassis is a heavy price.
Then you obviously still haven't seen one of these: http://www.stormerhobbies.com/cgi-bi...&pn=AWEA700EVO
Or even one of these: http://www3.towerhobbies.com/cgi-bin...&I=LXDXHK&P=ML
Just sayin'
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 04-04-2014, 12:41 PM   #2813
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Just sayin'
or this
http://www.stormerhobbies.com/cgi-bi...s&pn=XRA300020
$290 is awfully cheap compared to some of the chassis out there
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-04-2014, 12:46 PM   #2814
Butler02's Avatar
Use a peice of Kydex under your front bumper. It acts as a sort of deflector when you go Into a wall with the front wheels. Works awesome.
Airtronics MT-4
Old 04-04-2014, 01:02 PM   #2815
PEEKracing's Avatar
Even running races on foot probably cost as much as racing an R1, anything that you put the word racing in front of is going to be expensive. It's because racing brings in passion and competition, and these things cost much money. Probably the most affordable form of auto racing is Match box cars or pine cars.
PEEKracing is offline   Reply With Quote
Old 04-04-2014, 01:03 PM   #2816
DBM
I bought the pro spec as my first car. Compared to the price of the xrays, serpents, tamiyas, yokomos, the r1 is less than half the price. It is a heck of a good car at its price. Parts are cheap, too. Like has been said though. ....if you don't want to spend $240-280 for the r1/pro spec, get the S2 for $120.
Old 04-04-2014, 01:05 PM   #2817
k_bojar's Avatar
not too sure pine cars are too cheap anymore
Old 04-04-2014, 07:02 PM   #2818
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Xray Steering knuckles and a hard Xray bumper stops all this madness with broken steering parts....Like I said before. Or keep doing what you are doing...
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-04-2014, 09:03 PM   #2819
valk's Avatar
do t4 blocks direct fit? t3 ones did and im using them. ill have to look at getting a hard bumper. i also broke a front body post so maybe stronger posts. id actually like to see about fitting vbc body posts as they are threaded for body adjustment.
My stuff
My RC
Old 04-04-2014, 09:52 PM   #2820
Kevin K's Avatar
Yes the T4 steering knuckles are a direct replacement only thing is that you will need to use 1mm of shimming instead of the stock .5mm shim or use 2x .5mm shims to take up any extra space between the knuckle and the castor block. I run my car with a 1mm shim on the top of the knuckle. I have not broken any body post yet but I have also had the hard bumper on after the 2 week with the car when front end parts were just flying off at an alarming rate....X-ray hard bumper and X-ray knuckles = no worries.
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13440 Today 08:58 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
