Old 11-04-2012, 06:57 PM   #256
jeff jenkins's Avatar
Trader Rating: 75 (100%+)
Originally Posted by PitNamedGordie View Post
Trigger pulled
congrats on the purchase. you will be impressed for sure. if you have any questions regarding the car post them or feel free to P.M. me i will be more than happy to help you out.
On another note a few people at my local water hole have also made the plunge so looking forward to seeing more of these at the track.
Maclan Racing Products-RC US Imports - Sworkz USA - Bellgate Distributions
jeff jenkins is offline   Reply With Quote
Old 11-04-2012, 08:59 PM   #257
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Trigger pulled
Nice Steve cant wait to see it when you get out to the track.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is online now   Reply With Quote
Old 11-05-2012, 09:08 AM   #258
Fuzzi0n's Avatar
Manual is up for the S1. Impressed - I asked them about it, they replied and it was up soon after. Nice to see a company that replies to emails quickly.
Seems very similar to the R1, just different materials and missing the roll bars. Suspension seems to be pretty much the same, just missing the inserts, although at the rear you replace the whole lower mount to change the toe.
Fuzzi0n is offline   Reply With Quote
Old 11-05-2012, 09:15 AM   #259
Preordered an S1 from Reflex Racing to check it out.
Looks like a great car for the money.
Reflex Racing, Mini-ZNorway.com
Runerg is offline   Reply With Quote
Old 11-05-2012, 09:40 AM   #260
That s1 is a great bang for.the buck. Might even be worth trying out the chassis plate on the R1 to get more flex till another option is out there.
I wouldn't worry about the suspension blocks as I'm sure they are fixed at the R1 kit setting which is what on running at the moment and haven't felt the need to change it.
Old 11-05-2012, 10:27 AM   #261
Xenolance's Avatar
I've been contemplating the same thing! and for $118 it's HARD to pass up!
David Rose, Houston, TX.
Spec-R R1 / S1, Corally RDX.
"He's a Picasso with an Allen wrench." -Guffinator
Xenolance is offline   Reply With Quote
Old 11-05-2012, 10:57 AM   #262
Manny's Avatar
Thanks for asking them about the manual....I just gave it a quick look. I almost can't believe this is what passes for a "Sport" chassis today. Pretty awesome for 120 bucks. And I was impressed when I picked up a HB Cyclone S a few years back.
Manny is offline   Reply With Quote
Old 11-05-2012, 11:21 AM   #263
Hello all.
Got one of the S1s on preorder. Looks even better than I thought when they released the manual.
But I cannot find the size and pitch of the spur anywhere. As my LHS are only stocking toys these days I need to place an order for wheels body and not least, piniong. Would hate to have to wait yet another week after I get the kit. So any info about the spur would be highly appreciated!
MiniZ racer trying out m-chassis and TC:)
lmlindbo is offline   Reply With Quote
Old 11-05-2012, 11:26 AM   #264
Xenolance's Avatar
Originally Posted by lmlindbo View Post
Hello all.
84T 48P
You have to eyeball the instructions as the actual spur is missing the number lol.
http://www.spec-r.com/default/index....roducts_id=383
Spec-R R1 Spur Gear (48P84T) SPR-R1P314
Old 11-05-2012, 12:23 PM   #265
yea I am probably going to pick one up as well since it is so.cheap.
Old 11-05-2012, 04:11 PM   #266
AdrianM's Avatar
Cool part if you can use a 100T 64p spur.
One piece pulley/spur assembly from RW Racing for the Photon.
I have run RW spurs and pinions for years. The are the toughest most concentric gears on earth.
Adrian Martinez
Old 11-06-2012, 05:04 AM   #267
84T 48P
Thanks a lot!
Old 11-06-2012, 08:46 AM   #268
I pulled the trigger on the S1 couple days ago . . .
for those interested:
Tamiya Sway bars did fit with a little modification.
you need the following:
SPR-R1A102 - 5mm Ball Studs
4670 - 3mm 05 set screw (associated, but any brand will do)
84208 - Tamiya sway bar set
you will also need some end caps to complete the sway bars, I used some shock eyelets I had that were spare.
You will need to bend the sway bars a little so they line up better, and you will need to cut off around 3/4" from the rear bar. Not really all that difficult, if anyone knows anything that is a closer match please post.
I will post some pic's later today.
mupchu is offline   Reply With Quote
Old 11-06-2012, 12:03 PM   #269
JayL's Avatar
Is there a list that shows the part differences between R1 and S1?
I am guessing:
Alum shock bodies
CF chassis
CF top deck
CF shock towers
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 11-06-2012, 12:13 PM   #270
Fuzzi0n's Avatar
I am guessing:
Alum shock bodies
CF chassis
CF top deck
CF shock towers
Best option to be exact would be to go through the manuals and check the part numbers.
As far as I've worked the R1 has everything the S1 has plus these:
Aluminium bulkheads
Aluminium steering crank
Aluminium hexes
Aluminium shock bodies
Aluminium suspension mounts + replaceable plastic inserts
Aluminium turnbuckles + ball studs
CF shock towers
CF top deck
CF chassis
52mm front driveshafts
Front and rear roll bars
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
