Old 12-30-2013, 10:40 AM   #2296
Default A-Arm spacer question
I've noticed that when I install the spacers outboard of the a-arms "by the book" with a 1mm to the rear and a 3mm to the front, that the a-arms are bound up and do not swing free. This prevents the sway bars from working optimally as well.
The binding is definitely from the pinching and not from the pins themselves as I've reamed the holes and the arms swing free when I'm just holding the ends of the pins.
Anyone else experience this? What did you do?
You can see below that the arms will stay in the 45 degree angle position and not drop down like they should.
.crispy is offline   Reply With Quote
Old 12-30-2013, 10:52 AM   #2297
big al's Avatar
Sand down the spacers a bit. I had to do it myself. 5 minute fix!
big al is offline   Reply With Quote
Old 12-30-2013, 11:26 AM   #2298
im curious to why your worried about it, the cars suspension will never reach those angles... seems like a outta sight outta mind issue and not a actual functional problem. Just my .02
621clay is offline   Reply With Quote
Old 12-30-2013, 01:05 PM   #2299
32819toon's Avatar
See S1 parts I have for sale
FOR SALE - SPEC-R S1 PARTS
Any questions, just ask.
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 12-30-2013, 03:43 PM   #2300
Can anyone tell me the screw hole spacing on the rear suspension mount. I am looking for a mount w/30mm spacing for a project. Thanks.
Goal Achieved....Not Dead Last.
mooby64 is offline   Reply With Quote
Old 12-30-2013, 07:15 PM   #2301
mrjudd77's Avatar
.crispy.
I had the same on mine. Didn't worry about sanding it as I know it will wear down by itself. I didn't want to remove too much from the spacers and induce any undue slop into the A-Arms
HPI Sprint 2 Flux (second ed.) Porsche 911 GT3 (sold)
Spec-R S-1
Spec-R R-1
http://au.dollarshaveclub.com/ref/index/r/yc8/1wmmuv8/s/tx/cx/1/
mrjudd77 is offline   Reply With Quote
Old 12-30-2013, 07:15 PM   #2302
mrjudd77's Avatar
double post
Spec-R S-1
Spec-R R-1
Old 12-31-2013, 08:55 AM   #2303
Jorge T's Avatar
Originally Posted by mrjudd77 View Post
.crispy.
I replaced the plastic spacers with aluminum spacers. I always run .5mm less than what the manual states and have no slop.
FrontF 3.5mm, FrontR 1mm; RearF 2mm, RearR 2.5mm
RSD Speedway
Jorge T is offline   Reply With Quote
Old 12-31-2013, 09:45 AM   #2304
Thanks, I've got some aluminum spacers on the way.
Old 12-31-2013, 10:41 AM   #2305
celt's Avatar
Wow...did the same thing and it works out perfectly.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 12-31-2013, 10:59 AM   #2306
nrtv20's Avatar
I just picked up the 3racing DJC's are they as good as spec-r brand? They were the only ones I saw in stock.
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 12-31-2013, 11:39 AM   #2307
FWIW, I rebuilt both of my S1s over the weekend. Lots of things needed fixing.
Probably the most odd was the binding/wobble in the left rear wheel. Traced it back to the "Sport" drive shaft on that corner. The shaft was not able to rotate straight as the shaft would never actually straighten out. I found that it had a set screw backing out of the center pin in the connection.
Here's the thing, I checked my other drive shafts and they didn't have this set screw. I checked the manual (it shows you have to build them, which we don't) and it doesn't show any set screw. For some reason, someone in China decided to put a screw in this one and it was backing out.
Old 12-31-2013, 11:44 AM   #2308
Edit: double. I did not hit save twice I swear!
Old 12-31-2013, 04:31 PM   #2309
PEEKracing's Avatar
Center to center it's 27.5mm.
PEEKracing is offline   Reply With Quote
Old 12-31-2013, 06:36 PM   #2310
Thanks for checking...too small for my needs.
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13439 03-03-2017 02:56 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
