Old 12-28-2013, 07:28 AM   #2266
Send a message via AIM to JimmyMack12
My upper deck on my Spec-R S1 split and broke.
Looking at Reflex Racing's parts, they have a "Type A" and a "Type B" upper deck listed for the R1.
Anyone know what the difference is? They're both 2.0mm...
JimmyMack12 is offline   Reply With Quote
Old 12-28-2013, 08:16 AM   #2267
Originally Posted by Italboy View Post
Last question from my side.
Shall I rather take the S1 than the XI Sport?
Parts availability is no problem for both cars.
My thoughts:
  • I looked closely at the design of the 2 cars and they are almost the same.
  • Reading the XI Sport forum people say the same type of reviews, that the car works well out of the box. I would expect performance to be the same between the 2 cars.
  • At RCMart.com, the cars are priced almost the same.
  • Both cars are missing 'typical' hop ups like sway bars, the center servo holder, aluminum hexes, steering rack.
  • The Sakura comes with a set of tires where the spec-r does not. to me this is not much of a benefit
What I like about the Spec-r is the sport version is a low cost version of the top 'Pro spec' version. I could make my S1 car into a pro-spec over time if I wanted. Anything cool released for the pro-spec is an option for me.
The Sakura XI sport is a slightly different version than the Sakura Ultimate. Not every part is interchangable, but a lot are. If a new part comes out for the Ultimate it may not fit. This simplicity and possible upgrade path is what sold me on Spec-R.
lawton70 is offline   Reply With Quote
Old 12-28-2013, 10:23 AM   #2268
Originally Posted by lawton70 View Post
My thoughts:
The Sakura XI sport is a slightly different version then the Sakura Ultimate. Not every part is interchangable, but a lot are. If a new part comes out for the Ultimate it may not fit. This simplicity and possible upgrade path is what sold me on Spec-R.
The difference in design I saw that the Sakura has a narrower chassis layout which will provide more flex. This means that for low traction tracks more flex is needed so that the Sakura has to be considered.
The Team Magic E4JSII has a narrow chassis design too.
Italboy is offline   Reply With Quote
Old 12-28-2013, 10:45 AM   #2269
Agreed, the Sakura XI chassis does have more cut outs as well to give it more flex. This may be the deciding factor for you.
Old 12-28-2013, 12:09 PM   #2270
Just so I have this straight, you guys are LOOKING at the narrower chassis and determining that one has more flex over the other?
Without regard to material or thickness?
That's pretty amazing...
.crispy is offline   Reply With Quote
Old 12-28-2013, 12:14 PM   #2271
edit: double post.
Old 12-28-2013, 12:19 PM   #2272
32819toon's Avatar
Originally Posted by 32819toon View Post
Some good info here. I have one more question. I'm going to upgrade to R1 alu suspension mounts but have noticed that the part number for the pivot balls to mount the pivot pin into the lower arm is different for the R1 and S1 is different but they look the same on the manual. Does anyone know if the there is a difference ?
I emailed Spec R and they got right back to me with the answer. The S1 ones are plastic & the R1 ones are steel.
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 12-28-2013, 12:21 PM   #2273
mrjudd77's Avatar
well put crispy.
Also the availability to upgrade the S1 to any or all of the R1 parts is fantastic. I don't think any other comapny does this.
HPI Sprint 2 Flux (second ed.) Porsche 911 GT3 (sold)
Spec-R S-1
Spec-R R-1
http://au.dollarshaveclub.com/ref/index/r/yc8/1wmmuv8/s/tx/cx/1/
mrjudd77 is offline   Reply With Quote
Old 12-28-2013, 12:22 PM   #2274
mrjudd77's Avatar
well put crispy.
Spec-R S-1
Spec-R R-1
Old 12-28-2013, 12:30 PM   #2275
I thought I have read in this thread that the material of the S1 chassis is harder than other brand. But I'm not sure.
Old 12-28-2013, 01:17 PM   #2276
metalnut's Avatar
Trader Rating: 36 (100%+)
The difference is the width of the decks, one is more flexible than the other. If you're running an S1 chassis, though, you probably won't notice a difference (the chassis is very stiff). You can actually get just the regular R1 deck: http://www.tqrcracing.com/shop/produ....asp?p_id=4811
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 12-29-2013, 08:20 AM   #2277
Default which size lipo ?
Hello,
I'm starting with rc cars and I've ordered an Spec-R S1 but which size lipo's fit into the S1 chassis ?
roy#5 is offline   Reply With Quote
Old 12-29-2013, 08:39 AM   #2278
Originally Posted by roy#5 View Post
Hello,
Not sure what you mean by "which size". They're all pretty much the same size (dimensions).
If you're referring to battery *capacity* (which some people call "battery size"), it would depend on what class you're running (if you're racing). I race my S1 as a VTA car, run a SMC 5000mAh 2-cell LiPo battery, and it fits in the car with no problem.
Old 12-29-2013, 09:39 AM   #2279
I mean the dimensions of the battery, I found the dimensions of your SMC, thanks for answering.
Old 12-29-2013, 10:12 AM   #2280
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Any roar approved 2s hardcase battery will fit.
My stuff
Sanwa M12 - Xray T4/16 - Xray Nt1/16 - CRC XTI-WC - ProAMPS - Hobbywing - ReVTECH - ORCA
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com
valk is offline   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13440 03-26-2017 08:58 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
