Old 12-01-2013, 09:05 PM   #2116
Suspended
Originally Posted by poeee View Post
Iíve had a problem with the tops of my S1 shocks loosening off. First time I caught it in time, but yesterday it ended a heat for me. Iím happy to upgrade to the metal shock bodies. Are they a direct swap with the plastic S1 bodies?
Yes they are and they are also one of the few things you should upgrade on the S1 as they do pop off at times.
RogerDaShrubber is offline   Reply With Quote
Old 12-01-2013, 09:15 PM   #2117
poeee's Avatar
Cheers. Will get some alloy clamp wheel hexes at the same time, as I've found that with the plastic kit hexes it binds the axle up if you over tighten the wheel nut.
poeee is offline   Reply With Quote
Old 12-02-2013, 03:29 AM   #2118
daveaustin5's Avatar
My S1 kit has arrived and I'm hoping to start building it tonight. I feel like a kid at Christmas! It's been 15 years since I last built a kit.
Any tips?
I've read this which looks like a good starting point. Anything else I need to take particular care of?
daveaustin5 is offline   Reply With Quote
Old 12-02-2013, 08:03 AM   #2119
metalnut's Avatar
Trader Rating: 36 (100%+)
Any tips?
Should be pretty easy. The S1 has pretty hard plastic so go slow and don't force any screws. You'll most likely want to get a few upgrades, such as aluminum shocks, sway bars, floating servo holder, etc. But first run it as is to get a feel for it, and good luck
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 12-02-2013, 08:20 AM   #2120
with the S1 I pre-threaded all screw holes before I put the selected piece on. I used one of the M3 countersunk screws for threading. For some reason they worked better than the cap head screws.
lawton70 is offline   Reply With Quote
Old 12-02-2013, 08:20 AM   #2121
SteveM's Avatar
Trader Rating: 133 (100%+)
Any tips?
The instructions in the link you included are good for starters. They mention shimming parts as needed but they don't include shims in the kit and you'll need to buy a package. 3Racing sell a nice set.
Make sure the suspension arms do not bind. They should move completely free and not have any binding anywhere. Also pay careful attention to the shock mounting locations that are identified with letters. Make sure to use the same mounting hole left to right.
None of the instructions mention droop which is a shame. I've run my S1 and R1 with droop settings of 6 in front and 4 in the rear. I use an aluminum droop gauge similar to the Yeah Racing version, but Associated also sell a nice composite version for cheap.
I lube the CVD joints with Super Lube synthetic multi-purpose grease rather than the Tamiya Anti Wear grease or black grease that comes with some kits. The Super Lube is clear and is less messy and doesn't seem to attract dirt or carpet fuzz as much. Makes maintenance easier when there is less mess.
I found that the Spec-R plastic has a bit more moulding flash than other kits and you will need to carefully remove it. I use medium or fine hones, but a fine nail file might also work.
SteveM is offline   Reply With Quote
Old 12-02-2013, 09:17 AM   #2122
Thanks guys
Old 12-02-2013, 09:30 AM   #2123
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Ill also note the shims included in te kit make things like wheelbase too tight. I got the 3 racing 0.5-2mm shim set and a few tamiya 53585 0.1-0.3mm shim sets. Its anal but you want to shim the arms as close to zero play you can without bind. Ive found the plastic suspension carriers to be a little lopsided though. One of my rear pins has 0.2 more shimming than the other lol. Sometime soon ill get alum mounts as i have in the front.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is online now   Reply With Quote
Old 12-02-2013, 01:44 PM   #2124
32819toon's Avatar
Any tips?
Hi - there's plenty of advice on this thread. Firstly I'd bin the plastic kit shims and put metal ones in. You'll need to buy a lot of shims but they'll come in handy. The steering will need shimming and I've written a bit about this on my blog. With regular running, the car loosens up quite a bit so items such as steering will need re-shimming.
Good luck with the car, I'm sure you'll enjoy it, especially when you compare how little you paid for it against the high end ones.
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 12-03-2013, 09:35 PM   #2125
mrjudd77's Avatar
Quick question guys and girls. What does everyone use to clean their chassis?
HPI Sprint 2 Flux (second ed.) Porsche 911 GT3 (sold)
Spec-R S-1
Spec-R R-1
http://au.dollarshaveclub.com/ref/index/r/yc8/1wmmuv8/s/tx/cx/1/
mrjudd77 is offline   Reply With Quote
Old 12-03-2013, 09:41 PM   #2126
Trader Rating: 1 (67%+)
Send a message via AIM to racer034life
I use wd40....for my chassis's
Access Hobbies,CRC, Detc410, Xray T4 15,
The Ian Ruggles Negative Reinforcement Driving School
racer034life is offline   Reply With Quote
Old 12-04-2013, 01:48 AM   #2127
mrjudd77's Avatar
Thanks. Just wanted to make sure that I wasn't doing any damage to the chassis or other components.
Spec-R S-1
Spec-R R-1
Old 12-04-2013, 08:09 AM   #2128
I use Isopropyl Alcohol (Rubbing Alcohol) to clean parts in general. There are 2 kinds of alcohol termed 'Rubbing Alcohol'. Isopropyl and Ethyl. I find Isopropyl easier on plastics and rubber. I use it to clean old rubber off the lexan bodies and it works perfect. If I clean tires I use the Ethyl as I found it works as a mild traction compound better than Isopropyl.
Old 12-04-2013, 08:16 AM   #2129
BajaSkidmark's Avatar
I have had the same problem with the aluminum hexes if you over tighten the wheel nuts. This is not just a problem with the plastic hexes. FYI
Spec-R R1 (VTA, SpecGT10)
F104
BajaSkidmark is offline   Reply With Quote
Old 12-04-2013, 08:25 AM   #2130
DriveItLikeYSIT's Avatar
Trader Rating: 91 (100%+)
Last week I used a 4600 mah 70c shorty pack in my Spec R on a carpet track. It felt real quick and nimble compared to the stick pack I was using but I had to add about 7 grams of wgt to the rear. Is anyone else using a shorty lipo? Do you feel a difference? What set-up changes did you have to make?
TEAM DRIVER==> BocaBearings|Pro-Line Racing|HWNA|Gens ACE|
EBSL - HW XR8 SCT PRO ESC & HW G2 4300kv motor
EXOTEK 22 SCT 2.0 - HW XR10 PRO ESC & HW Bandit 10.5t
EXOTEK 22T 2.0 - HW XR10 PRO ESC & HW G2 7.5T
DriveItLikeYSIT is offline   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
