Old 09-25-2013, 11:39 AM   #1996
Trader Rating: 58 (100%+)
Originally Posted by RogerDaShrubber View Post
Actually that is a bit unusual, on slow post, generally you will have it in 7 days. I have had one package get lost and that took 3 weeks or there abouts to arrive, but spec-r were great, after i notified them of it being late, they got onto HK post about it and said if you have not got it in 7 days, we will repost it at their expense. It arrived one day before the time limit, date stamped the day they said it was posted, so it was just lost, not tracking number games that some places do, issue the number and send it a week later.
Just got an email from them. They said they had sent me an email because the top deck I ordered wasn't recommended with the center motor mount. I never saw any email, so never responded. After a few day delay they went ahead and shipped it.
The whole thought and intention is awesome. Sucks it wasn't executed.
So now I apparently have a mismatched pile of parts coming. I really wish they would of just had an upgrade kit. Worse case I don't run the center motor mount until I figure out which top deck is required.
MC112b is offline   Reply With Quote
Old 09-25-2013, 04:58 PM   #1997
Suspended
Pretty sure all you have to do is drill one hole in the top deck to make it work with the new motor mount, all it does is have a place for a screw to limit or change the amount of flex in the top deck.
The correct top decks are type A or B Narrow, and in most cases you will probably want to have no screw in there anyways for maximum flex, so dont stress it, it will work.
RogerDaShrubber is offline   Reply With Quote
Old 09-25-2013, 08:02 PM   #1998
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by Mr.juarez View Post
I have had good luck with my associated car, never broke one in two years and I have not touched the wall with my trf417. The tamiya are just fine to me, but I seem to grow white hairs and have chit hit the fan every time I tried to take that stupid plastic snap in outdrive just to clean the damn bearings. Seems like the spec-r is just drop and play. Was mainly concerned how durable the outdrive is and if I was to hit a wall ( dog bone, outdrive, axle) is the carnage since there won't be any give??
I have had nothing bend or break yet while using them on both my previous car 416 and my R1 now no pin wear or anything else. This is all with steel bones I would think that any alum bone would bend right away.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 09-26-2013, 10:49 AM   #1999
Jorge T's Avatar
I've broken hinge-pins and bent rear hub ball studs from hitting the wall. but never broken or bent an axle or aluminum dog bone. Aluminum bones are fine as long its 17.5 or 13.5 blinky .
RSD MS
Jorge T is offline   Reply With Quote
Old 10-04-2013, 07:57 AM   #2000
TheCarbabe's Avatar
Hi!
I bought a S1 a while ago, and finaly found the time to build it. I will not race it, just playing around on a small carpet-track. This is the first 4wd touring "race"car I've built, but I think I did quite well.
I have only one issue so far. I've read all the 130 pages in this thread (maybe missed one or five ) but did not see it adressed.
The rear belt rubs on the spur. Feel like I hav tried everything. Something just seem to be a bit off.
Built by thebook except for some shimming to get rid of some play here and there.
Do you guys have any hints for me?
Nina
TheCarbabe is offline   Reply With Quote
Old 10-04-2013, 08:00 AM   #2001
Shouldn't be possible. You don't have the gear diff flipped around the wrong way do you?
Or did you miss the black plastic spacers inboard of the bearings on the gear diff?
Take a picture and post it here.
.crispy is offline   Reply With Quote
Old 10-04-2013, 08:37 AM   #2002
TheCarbabe's Avatar
Thanks!
On closer inspection both belts creep inward while the car is rolling.
Will take some pics later.
Old 10-04-2013, 08:46 AM   #2003
metalnut's Avatar
Trader Rating: 36 (100%+)
Originally Posted by TheCarbabe View Post
Thanks!
Pictures would definitely help, but I'm not sure how your belts can creep inward. As was asked above, are you sure your diff and spool are flipped the correct way? My belts run perfectly parallel down the center, I really have no idea how you could even get them at an angle unless the diff/spool are flipped.
Anyway, take a picture and we'll help
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 10-04-2013, 09:06 AM   #2004
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Make sure the tensioners are set the same. It can be tricky on this car to get them to sit right when you tighten the upper bulkheads down.
My stuff
| Sanwa - Team Associated - Reedy - ProAMPS RC - Novarossi |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/
valk is offline   Reply With Quote
Old 10-04-2013, 10:12 AM   #2005
TheCarbabe's Avatar
The diffs are the right way. Otherwise it would completely lock up. Or the belt would walk outwards at the diffs.
I was pretty sure that I got the tensioners right, but I was kind of tired Will look into that...
thanks a lot so far!
Old 10-04-2013, 10:23 AM   #2006
valk's Avatar
Alternately, you might need to adjust the shimming on your layshaft or the difs themselves. I never worry about this to be honest. Unless the belts are binding badly on the sides of he pullies or want to jump off. Never had a tc where the belts didnt wander a little.
My stuff
My RC
Old 10-04-2013, 12:59 PM   #2007
TheCarbabe's Avatar
Looks like I'm having issues uploading pics here. Technology these days.
Maybe it's ok and that it is all the miniZ racing that makes me ekstremely vary of slop and drag.
Old 10-05-2013, 02:19 PM   #2008
tried my updated r1 for the first time on carpet today (low traction) car handles really nice with the flexier parts, just needs to find the right flexpoint. also we have gone from 17.5boost to blinky here, as the class now are now rather slow there are more to do with cornerspeeds, the new chassi/topdeck/motormount are a BIG improvement from the old r1 carbon parts! really looking forward to the first racemeeting for the season!
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 10-09-2013, 12:11 AM   #2009
metalnut's Avatar
Alright, I've pretty much had it with the stock plastic outdrives for the front spool. If I want metal outdrives up front, what are my options? Any metal ones fit the stock spool?
I know I can put a gear diff up front and stuff it with putty, but I'm hoping I can still work with this spool. If not, which metal-outdrive spools would fit? I've only seen the Tamiya 417 mentioned once.
- Ricky Bobby
Old 10-09-2013, 12:34 AM   #2010
Kevin K's Avatar
Spec R makes spring steel outdrives....
http://www.tqrcracing.com/shop/produ....asp?p_id=3022
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13450 04-21-2017 01:38 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
