Old 09-15-2013, 07:23 AM   #1966
Trader Rating: 57 (100%+)
Are there any hard front bumpers that fit this car?
PROMODVETTE is offline   Reply With Quote
Old 09-15-2013, 07:57 AM   #1967
xray bumper
Rally-game proto Clo-products - Toro 150a - HW 2250kv - Turnigy a-spec - Futaba 3PKS
Tamiya M03S mini cooper - Novak 410M1C - Orion Core 27x1
Kyosho Mini-Z MR03 and MA015
Xray T4-2014 - Hobbywing V3.1 - LRP X20 spec 10.5 - Turnigy ultimate
Xray X12-2014 - Reedy Mach2 6.0
christophed83 is offline   Reply With Quote
Old 09-15-2013, 08:00 AM   #1968
The one from the T3 or T4?
Old 09-15-2013, 11:33 AM   #1969
GP40X's Avatar
Yep
Bill
"I used to be disgusted, now I'm just amused."
Team Qik
CustomWorks Outlaw Sprint Car
Xray T3 2012 USVTA
GP40X is offline   Reply With Quote
Old 09-15-2013, 12:07 PM   #1970
Potoczak's Avatar
Trader Rating: 109 (100%+)
I have a xray t3 hard bumper on mine. Fits perfect.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 09-15-2013, 03:33 PM   #1971
Csaari77's Avatar
Trader Rating: 34 (100%+)
I'm helping a friend build his R1 Pro and I've run into a couple issues I need some help with.
We got the center shaft installed using the aluminum shaft and Teflon bushings and there is a bit of side to side play. Are you guys shimming the play out or leaving it? It's about .1-.3 mm of play.
Also, the steering rack is binding with the carbon stiffener installed. Does it need additional shimming? If so, how much is everyone adding?
Thanks for the help.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 09-15-2013, 07:59 PM   #1972
metalnut's Avatar
Trader Rating: 36 (100%+)
If you're using the kit bushings for the center shaft, most of us just used flanged bearings with Kimbrough spur gears. Search the thread for those and you'll get some dimensions and part numbers. Alternatively, I believe you can use the "alternative" white bushings that Spec-R released some time ago, they're a bit longer than the black bushings and take up the slack (from what I remember reading).
As for the steering rack binding... where exactly is it binding? Do you mean the top deck makes it bind?
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 09-15-2013, 08:00 PM   #1973
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Second day out with the S1 today and couldnt have had more varied conditions from round to round..
the track was setup and sprayed with sugar water the previous day which made for a very dirty, wet and slippery surface this morning. our tires were coming off with a new layer of rubber/sugar crap and made for an interesting first round.
though, the S1, which i basically guessed a setup on my bench weeks before, with the addition of swaybars kicked serious ass in this first round. i set an early TQ, that would stand until the end of the third round.
second round was a total wash as some rain started to fall just before the start of the race. not a lot, but enough to wash out the traction that had been built up the previous round. the car instantly turned into a drift machine and i just couldnt manage it. some other guys got quite a lead on me just managing the drift. at 3 minutes the traction can back and i was able to get the car on line somewhat better but just too much lost time heh. fast 28 laps set in the first round went down to 20-22 laps in the second round.. which is still pretty fast with the drift session.
third round started off really awesome. i started on pole and had a clean start, but got a little loose and feel back. came back to lead but the smallest of taps was enough to pull my servo horn ballstud out and finish my race.. the car was driving SUPER nice though. no changes from the first round but a fresh set of sweep qts32s and it was on rails.
the rain came around and cancelled the main events.
qualified third overall a few seconds from 29 laps so pretty happy overall.
ill compose a setup later on but really all i did was go through the car and shim it properly, mess with shock position, remove top deck screws ect. stiff car still but handled really great.
also very happy with my $64 speed passion power. but ill try my orca TX motor with the reventon stock next race day.
when we move indoors ill do a LOT more testing of this car as ill be able to go every week.
My stuff
Sanwa M12 - Xray T4/16 - Xray Nt1/16 - CRC XTI-WC - ProAMPS - Hobbywing - ReVTECH - ORCA
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com
valk is offline   Reply With Quote
Old 09-15-2013, 08:25 PM   #1974
Csaari77's Avatar
The steering rack was solved by using a .1mm shim between the carbon brace and the bearing. Without the shim the brace was binding the bearing.
The shaft play is there using the white bushings. The play is between the flange of the bushing and the outside of the motor mount.
Old 09-15-2013, 11:12 PM   #1975
metalnut's Avatar
If I'm understanding which play you're talking about, I actually used a shim washer on the outside, right under the screw washer. It's larger diameter to go around the shaft, allowing the screw washer (the cone red one) to properly hold the shaft bushing in place.
- Ricky Bobby
Old 09-16-2013, 10:04 PM   #1976
Installed 2 7mm x.1mm shims on each side over white bushing between flange and motor mount. Play is now gone and spins free.
nikko rhino is offline   Reply With Quote
Old 09-21-2013, 08:20 AM   #1977
Just got the pro version partially assembled and ran into this issue.
The motor/shaft mount pieces and the bulkhead are different heights....why??? But here is the issue, it says to put 1mm spacer on top of the motor/shaft mount to equalize the height. That doesn't do it. Still tweaks the chassis bad when you do this. Anyone else run into this and have a solution?
Old 09-21-2013, 09:36 AM   #1978
the gap is there to let the topdeck flex more free when not using the 4 screws to get more traction, its the same with the new center motormount
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 09-21-2013, 12:11 PM   #1979
How does leaving these screws out work on med/high bite carpet? Without getting some super thin shims or fabricating something the gap that is there is not precise enough to tighten down per the manual.
Old 09-21-2013, 05:50 PM   #1980
I just race on low-med traction carpet so i dont know. First run getting close! Very curious on how the new parts work
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13440 03-26-2017 08:58 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
