Old 08-24-2013, 12:12 PM   #1846
I have a full size servo, a Spektrum SR300 receiver and my Novak Edge speedo all side to side in mine and it just barely fits. The speedo is real close to the motor.
At some point I'll swap out the servo for the low profile Savox 1251 and swap my Spektrum 3100 receiver into this car and I'll have tons of room.
Honestly the big issue with my new R1 in VTA is finding a place for all the weight.
.crispy is offline   Reply With Quote
Old 08-24-2013, 12:29 PM   #1847
Send a message via AIM to JimmyMack12
Originally Posted by Kevin K View Post
Just looking at your posted setup you should change the oil in your shocks first. 25wt in the front is really light and will lead to massive amounts of steering when the rear is a heavier wt oil if both have the same size and number of hole pistons installed. It really sounds like you want 35wt in the front and 25wt in the rear. Also dont use so much tire compound on the front tires. Maybe cover the whole rear tire and just the inside half of the front. Also you can put the compound on the rear tires first and let it set for an extra 10 minutes before you put any on the front tires then clean them both off at the same time. Also make sure you have the stiffer of the two kit springs on the front shocks and the softer springs on the rear. Good luck!
Thanks. I have the S1; it only came with one set of springs.
What about rear toe? Should I bump it to the 3.5-degree mounts?
You guys talking about moving the camber links on the S1: there's only one place to mount 'em...how do I move 'em up or down?
JimmyMack12 is offline   Reply With Quote
Old 08-24-2013, 12:42 PM   #1848
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Not up to my usual standard but the best i could really do given the room. not sure if ill need a cap or not. orca says 2a bec, so we will see. havent needed a cap since moving to airtronics though..
this is a sunday of new for me. new chassis, new esc, new motor. new tires ive never run before.. lol. should be interesting. my serpent is super forgiving and easy to drive fast. doesn't try to kick its ass out very much in stock but i was trying to take some traction out of it to rotate ect.
thinking ill be chasing traction more with this car by how stiff it is but im very excited to benchmark $100 car against $500 cars. might et a few more spectators interested in the sport.
i mean... cause its really fair to drop ultra high end electronics into a cheapy car and try to sell the class... but.. lol. my reventon stock club setup should be here soon which is the intended platform for this car.
My stuff
Sanwa M12 - Xray T4/16 - Xray Nt1/16 - CRC XTI-WC - ProAMPS - Hobbywing - ReVTECH - ORCA
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com
valk is offline   Reply With Quote
Old 08-24-2013, 12:55 PM   #1849
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
There is only 1 set of springs but they are different rates....softer of the two should be used in the rear.
Thats its a normal amount of rear toe you can maybe run down to 2deg but 3.5 is fine.
You move the camber links by adding or removing spacers under the ball studs.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 08-24-2013, 05:24 PM   #1850
Cody_ferone's Avatar
Trader Rating: 12 (93%+)
First time out with the s1 today. Overall for 129$ I'm pretty satisfied. Other than breaking a servo horn and a ball end nothing else was broken.
I'm running all stock setting that the manual says. Car feels super lazy in the corners, any suggestions?
Cody_ferone is offline   Reply With Quote
Old 08-24-2013, 05:28 PM   #1851
Potoczak's Avatar
Trader Rating: 107 (100%+)
Are there any companies making lowered towers for this car??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 08-24-2013, 11:34 PM   #1852
metalnut's Avatar
Trader Rating: 36 (100%+)
Not that I'm aware of, no.
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 08-25-2013, 07:10 PM   #1853
valk's Avatar
Not a bad first outing with the car. No Broken parts. Qualified third overall and finished second. I would have still finished second to blake no matter what heh.
My driving style loses too much corner speed i think. I like to slow down and keep a tight inside line. Car had tons of turnin and could overrotate super easy. Very lively.
Gonna focus on swaybars and getting a little more flex out of it.
There is also quite a lot of wobble in the steering. Ill have to address that.
My stuff
My RC
Old 08-25-2013, 10:48 PM   #1854
valk's Avatar
What would people suggest as a decent spring set for this car? are the ride springs alright, or would the spec r ones be ok? the spec r set is a much better deal of course.
My stuff
My RC
Old 08-26-2013, 12:17 AM   #1855
Suspended
I have been having this conversation for about an hour with a Pro Driver from my club. A lot of it has to do with the conditions of where you drive. Sets are a bit of a waste of money in a way. You will end up with either a lot of soft or a lot of hard springs you wont use.
Xray springs are great, find the set you need and then get 1 set either side of that, this will cover most situations you will find yourself in, if you only drive at the one track regularly.
RogerDaShrubber is offline   Reply With Quote
Old 08-26-2013, 03:39 AM   #1856
Airwave's Avatar
Ride springs are perfect for touring, really...
Airwave is offline   Reply With Quote
Old 08-26-2013, 11:47 AM   #1857
trying to make the s1 car softer might be hard, i went nuts on my s1 chassi, its still stiff! the glassfibre used is crap.. only thing i can imagine that would make it softer in a good way is to mill it down in thickness
if you want to make the car softer then the new cf chassis will make a big difference, i have the option 2.25mm chassi on my car now, center motormount and new topdeck is on its way now too. new carbon chassis is totally different than the first ones that were released in terms of carbon, flex and feel
will post a pic of my car when i got all new bits installed
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Schumacher Cougar KF2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 08-26-2013, 12:30 PM   #1858
valk's Avatar
I might a do the drillout thing. Ir i could mill the material down ob cnc at work but planning fiberboards tends to create a tweak.
Trying to stay away from carbon fiber. If i go that route i might as well have just paid $279 for an r1.
My stuff
My RC
Old 08-26-2013, 12:34 PM   #1859
mill it down if you have the chance.. my s1 chassi is badly tweaked after all drilling
but i think that its more worth buying carbon parts, after all, they are quite inexpensive from spec r, the s1 glassfibre is way stiffer than the newer usa grade carbon
Old 08-27-2013, 11:02 AM   #1860
I had my first run with the R1. Running 10.5t boosted on mid-low traction
asphalt. The car is very easy to drive. But on my third pack, the gear diff started to make noise, like jumping gear noise and eventually i had stripped a lil of the inner bevel gear. I added 0.1mm shim on four of the small bevel gear (first built was no shim,follow 100% manual) and it only last for another 3 packs.
I have fully replaced a new set of inner gear with 0.1mm shim on four of the small bevel gear. Hope this could solve it.
Anyone have any suggestion or advice? Btw, this is my first brand new built out of the box. Previous car was all used car.
Regards.
jack_lee is offline   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13416 12-21-2016 06:45 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 04:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 12:44 PM
SEO by vBSEO 3.5.0
