Old 08-06-2013, 05:24 PM   #1771
Originally Posted by JayL View Post
Remember the Saft DOES NOT spin like most touring cars
Not looking to start any argument or anything, but in what touring car does the layshaft spin? I've had a few, and looked a lot of manuals for others, and can't think of a single one where the layshaft spins. They all have the spur gear screwed together with the pulleys, which ride on bearings on a stationary layshaft. But I've only been paying attention for the past few years. Maybe things used to be different?
EDIT: I just realized I'm full of crap, because my xray t4's pulleys are pinned to the layshaft and the while thing rides on bearings.
-Mike
Old 08-06-2013, 06:59 PM   #1772
SamuraiJack's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Caleb_Bush View Post
Hey, are you able to post a picture of what your shimming looks like, Jack?
Check out my album I tried to take a pic of it. You can see the silver shims between the bushing and the red outer washer thing.
SamuraiJack is offline   Reply With Quote
Old 08-06-2013, 07:43 PM   #1773
Fuzzi0n's Avatar
As Jack mentioned, have a look at his picture of it. If you are doing it on the S1, just don't over do it or you can slightly flex the layshaft mounts which can cause it to bind up if you shim/used the larger bushings either side of the spur/pulley assembly.
-Mike
It's the case on quite a few cars, Schumacher have used it, think my old TRF had a setup like that too.
Spec-R S1, Schumacher CAT SX3 S1
Fuzzi0n is offline   Reply With Quote
Old 08-08-2013, 06:04 PM   #1774
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Anyone using these up front? Are they similar to the v2 swing axles?
http://www.tqrcracing.com/shop/produ....asp?p_id=4865
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 08-09-2013, 02:54 AM   #1775
Airwave's Avatar
I've read a lot of discussions about the play in the center shaft... But guys remember play is totally mechanical. You can have about a millimeter of play there, it won't be a problem as the rotative part will be centered by the belts...
Airwave is offline   Reply With Quote
Old 08-09-2013, 08:03 AM   #1776
Cody_ferone's Avatar
Trader Rating: 12 (93%+)
With the stock spur on the s1 running 17.5 blinky on a small- medium carpet track. Straight is about 85ft. What's a good starting point as far as pinion size?
Cody_ferone is offline   Reply With Quote
Old 08-09-2013, 12:26 PM   #1777
VenturaDC's Avatar
The stock spur was way to big for me to get the right gearing for 17.5 blinky
I think I'm at 80/50 in 64p
Old 08-09-2013, 09:14 PM   #1778
spring71's Avatar
Smile
Spec-R R1 Pro Spec kits are in stock.
http://www.tqrcracing.com/shop/produ....asp?p_id=6396
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 08-10-2013, 12:33 PM   #1779
32819toon's Avatar
Hi,
I've started a new blog on the Spec R S1, you can check it out at :-
www.spec-r-racer.
I'll add more information, and set ups as it builds.
32819toon
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 08-11-2013, 07:21 PM   #1780
Send a message via AIM to JimmyMack12
Originally Posted by 32819toon View Post
Hi,
www.spec-r-racer.
32819toon
Link is incomplete and doesn't work. Try this: http://jfgifygufh.blogspot.com/
Can anyone recommend a servo saver in place of the "stock" servo arm in the S1? Using a Futaba S9650. Stock arm is fine for out playin' in the parking lot. Went to race VTA Saturday, and the first hit the car took exploded the gears in my servo.
JimmyMack12 is offline   Reply With Quote
Old 08-12-2013, 03:45 AM   #1781
Potoczak's Avatar
Trader Rating: 109 (100%+)
I use a xray extra stiff servo saver.
http://www.amainhobbies.com/product_...ervo-Saver-Set
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 08-12-2013, 08:30 AM   #1782
Trader Rating: 66 (100%+)
I've searched and searched....but I can't find any gearing help for a 21.5 VTA setup for the R1.
Recommended FDR for a 21.5? Pinion/spur counts?
This is for an asphalt setup.
-Dave
Race: B6D / B6 / T5M w/custom LCG 3 gear
Coming Soon: B64D
Pinebox is offline   Reply With Quote
Old 08-12-2013, 08:40 AM   #1783
SteveM's Avatar
Trader Rating: 133 (100%+)
The last time I ran my S1 in VTA outdoors I used a 90T spur and 52T pinion for an FDR of 3.28. I took the TQ and won the A-main.
SteveM is online now   Reply With Quote
Old 08-12-2013, 08:42 AM   #1784
No idea what you want your FDR to be, but keep in mind you don't want your spur to be too big or you won't be able to fit it all in there.
I settled on a 96 64p spur and I have pinions from 39 to 57 that will fit. That covers me from 4.68 to 3.20 FDR.
.crispy is offline   Reply With Quote
Old 08-12-2013, 11:57 AM   #1785
I wouldn't recommend going straight to an FDR that low. I'd start it up more like 3.6 and then work your way down depending on temperature and on-track performance.
EDIT: I replied to SteveM's post, but I'm actually talking to Pinebox.
-Mike
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13450 04-21-2017 01:38 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
