Old 07-16-2013, 06:23 PM   #1681
Send a message via AIM to JimmyMack12
Until I read this thread, and this particular post:
My VTA setup on my S1 is:
the spacers under all the arm mounts
450cst oil in all shocks
no sways
5 front 6 rear on droop blocks
stock setup for everything else
3.72 FDR Full motor timing
I adjust camber so the tires wear equal/flat
I also run DCJ's in the front, that really allows me to carry corner speed even though they add alittle weight
I also run the alum rear cvd bone option
'68 Camaro
car is wicked fast, most of the other top drivers run tc4 and it keeps up no problem and is more durable
I had *never*, ever heard of shock oils - or any oil, for that matter - being rated in terms of "cst".
Looking at that comparison chart that someone posted, it states that "Only manufacturers using cSt as rating are using a world standard and can be mixed used. Other ratings like W and WT differ from brand from brand as WT or W is not a world standard!"
In all my years working on (real) cars, I had NEVER heard of "cst" or "cps" or whatever ratings for oil. Just wondering when this "world standard" kicked in, that the United States never took notice (at least, *I'd* never heard of this until now).
JimmyMack12 is offline   Reply With Quote
Old 07-16-2013, 08:35 PM   #1682
Suspended
This is because the US has not adopted SI units, because the standards are housed in France and if they US cannot be in control of something, it wants nothing to do with it.
Automotive lubricants use the defacto standard of SAE, which mechanics understand, etc, while people working in a lab or in research will work with and report in SI units, for convenience and standardization.
RogerDaShrubber is offline   Reply With Quote
Old 07-16-2013, 08:59 PM   #1683
metalnut's Avatar
Trader Rating: 36 (100%+)
Tell us how you really feel
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 07-16-2013, 09:29 PM   #1684
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Thanks guys. I am pretty close to stock setup except that I put red ride springs front and silver rears 450 cst stock 3 holes. Also running dcj fronts. I run around 2 rear toe. Anyone else running lesser toe on theirs?
Also how does your setup work without sways? The VTA car is way heavier than a stock sedan so I was wondering I should go up in stiffness in sways or you guys compensate with roll center adjustments?
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 07-17-2013, 10:44 PM   #1685
Default oversteer on throtle
Can you guys help me out how to overcome oversteer after exiting corner...on throtle the car just spin out
My setup is:
Front
100k gear diff oil
35wt shock oil/ silver hpi spring
6 droop
5,5 ride height
chamber 1
toe out 0,5
Rear
7k gear diff
35 wt shock oil/ blue hpi spring
5 droop
6 ride height
chamber 2
toe in 3
thanks
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 07-17-2013, 10:54 PM   #1686
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
My setup is:
Front
100k gear diff oil
6 droop
5,5 ride height
chamber 1
toe out 0,5
Rear
7k gear diff
5 droop
6 ride height
chamber 2
toe in 3
thanks
Check tweak, decrease the rear differential oil, increase front differential viscosity, increase the front ride height, soften the rear spring, add more droop up front...
Honestly, I would check the tweak first and then look to reducing the rear differential fluid viscosity and or increasing the front differential oil weight.
IIGQ4U is offline   Reply With Quote
Old 07-18-2013, 12:37 AM   #1687
metalnut's Avatar
I didn't see anything mentioned about sway bars, but putting in a harder front or a softer rear sway bar should be close to the top of the list too.
- Ricky Bobby
Old 07-18-2013, 06:07 AM   #1688
mate, start with 1k diff oil in the rear. Go from there, cheers!
cheapskate.brok is offline   Reply With Quote
Old 07-18-2013, 07:26 AM   #1689
IIGQ4U's Avatar
Not with the setup he posted. His diff oils look off.
Old 07-18-2013, 09:23 AM   #1690
JayL's Avatar
k4mp4q: rear diff oil waaay too thick, I always run 1k or 2k, CST of course
I don't run sways on vta, I don't like the feel of the sway acting on the inner suspension. It just feels more direct/precise without for me.
I just shim the lower arm mounts up for less roll and all the added lead on the chassis keeps CG low.
I run 2 degree per side rear toe, perfect and fast on the straight
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 07-18-2013, 09:39 AM   #1691
Trader Rating: 27 (100%+)
1k diff oil, depending on the track. I run 500cst in there on a medium technical carpet track.
Front spool will help with the car spinning out. However, what kind of spin out are you talking about? I had a car before that entered corners well, but would 'hook' upon exit. I've also had cars that can't enter corners for crap and spin out when I turn in. WHEN it happens is just as important.
Try laying your rear shocks more inward as well.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 07-18-2013, 10:03 AM   #1692
pete68's Avatar
is there a newer version of the r1 coming out or its just a couple of option
motor mount frame top deck !!!!
Yokomo BD7-15&16/YZ2 HOBBYWING/SMC/FUTABA/XPERT/MRT-PTX
pete68 is offline   Reply With Quote
Old 07-18-2013, 07:59 PM   #1693
big al's Avatar
My setup is:
Front
100k gear diff oil
6 droop
5,5 ride height
chamber 1
toe out 0,5
Rear
7k gear diff
5 droop
6 ride height
chamber 2
toe in 3
thanks
I had a problem similar to this. It ended up being one of the spool cups had loosened and would pop out and lock up that side of the front end, causing a spin out. Good luck!
big al is offline   Reply With Quote
Old 07-19-2013, 02:36 PM   #1694
Cody_ferone's Avatar
Trader Rating: 12 (93%+)
Anyone have trouble with the spur gear assembly on the s1? The 6mm flat head m3's seem way to large. They seem like they will be in the way. Aside from that the holes are way way to small even after I tried opening them up a little bit.
Cody_ferone is offline   Reply With Quote
Old 07-19-2013, 02:50 PM   #1695
think there will be a new spec r car soon, a car with all new parts in the box, plus maybe some more new things...chassi, topdeck, motormount, servomount.
if no new car i will buy the new parts for the winter season for sure!
going to try my car on asphalt for the first time next week, looking forward to see how my heavily modified std chassi will work!
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13440 Yesterday 08:58 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
