Old 07-14-2013, 10:22 AM   #1651
bakoo's Avatar
Originally Posted by .crispy View Post
Let's see a picture of four identical mounts?
I'm sorry, I don't believe that Spec-R has a faulty mold and produced exactly one kit with it.
That's your prerogative, and it's understandable, my initial reaction was the same as yours.
Your unwavering faith in the Spec-R quality control aside (despite posts in this thread pointing out other production faults), there was a more likely scenario that we ruled out before pointing fingers at the mold - were the parts in question actually on the parts tree in the first place? If not, it could simply be the case of an assembly line worker lobbing a couple of wrong parts in the bag. That happens with kits from pricier manufacturers, too.
While his answer can never be verified, he insists the parts in question were in fact stuck to the parts tree, and I chose take his word for it.
In the end it doesn't matter why this particular kit had four identical mounts, leading to asymmetrical toe. Putting the information out there and perhaps preventing people from having the same problem does, hence this warning.
As for your claim that only one kit is having this problem - you know there is the minute possibility that not every single S1 buyer lurks this thread?
Also, if you aren't looking for this exact problem, chances are you won't even notice. You always adjust front toe during setup anyway, largely compensating for errors in the inner toe, and as the rear toe is fixed, you don't spend time checking the symmetry there. In the end you might just wonder why, no matter what you do to the setup, your car never feels right.
In this particular case, it was a more seasoned driver who first noticed that the rear toe was off. It never ceases to amaze me how experienced hobbyists immediately spot problems beginners are oblivious to.
bakoo is offline   Reply With Quote
Old 07-14-2013, 12:33 PM   #1652
big al's Avatar
Try to get a detailed photo of the mounts in question please. The only way offset mount won't work is if the hole for the bushings were all facing the same direction while still attached to the parts tree. Then, they would in fact not fit. If they face each other or face outwards (away from the tree) they should work. Your "mistake" mounts would require a defective mold to have been made. It's possible but not probable.
big al is offline   Reply With Quote
Old 07-14-2013, 12:59 PM   #1653
SamuraiJack's Avatar
Trader Rating: 38 (100%+)
Tightened the belt, first a little, then a lot just to try, and it still rubs at full turn. I notice it grazes the endcaps as well. I think the whole steering linkage just needs to sit higher so I will try to shim below the arms instead. Or may just try the R1 set cuz its fun.
Has anyone else blasted the throttle with wheels fully turned while your S1 was on the stand?
Originally Posted by SamuraiJack View Post
Oh I see what you mean. No, the rubbing happens well within the range of arms.
SamuraiJack is offline   Reply With Quote
Old 07-14-2013, 03:37 PM   #1654
Send a message via AIM to JimmyMack12
I'll take a look at mine tonight while I've got the car apart. My front drive belt is pretty tight (not "loose" at all).
Will let you know the outcome.
JimmyMack12 is offline   Reply With Quote
Old 07-14-2013, 03:45 PM   #1655
bakoo's Avatar
Questions??
If the CAD file/mold was faulty, something we'd need the original tree to prove, all four parts could very well be identical and on the same tree.
I almost regret telling you that my friend's S1 kit had a problem, and sharing an easy way to identify it, because somewhere along the way, for some silly reason, it became more about how the four identical mounts ended up in his kit and if they are indeed identical, than the fact that they did and how you can tell.
I'll pass on your request for a picture of his four identical mounts when he gets back from vacation, but if the sceptics from the spanish inquisition have more questions, direct them at someone else - I'm busy building an m-chassis sized Atomic VM-II kit
Old 07-14-2013, 05:00 PM   #1656
Suspended
Pictures or it did not happen.
RogerDaShrubber is offline   Reply With Quote
Old 07-14-2013, 06:39 PM   #1657
Airflow's Avatar
Hhhmm what I noticed with my S1 was the camber link of the right hand front is actually longer than the left (but achieved equal camber settings, -2). I think there's around 1-2.5mm difference . Every time I cleaned it after a run and checking for wear and tear, I'm always puzzled why is it like that. I will check tonight if my front suspension mounts were not giving me equal toe.
Airflow is offline   Reply With Quote
Old 07-15-2013, 09:09 AM   #1658
Bernard_Jr's Avatar
Send a message via Skype™ to Bernard_Jr
How do you guys measure droop? I've always been an offroad guy and there's a couple ways I'd normally consider but not sure with something that has such limited suspension travel.
Also, is there a good starting point for carpet?
John Bernard Jr.
Tekno RC / Hobbywing NA / JConcepts / NitroPro / Sylveris RC
River Rat Raceway / RC Addiction Products / RIP
http://www.youtube.com/user/Bigman4415?feature=mhum
http://johnbernardjr.wordpress.com
Bernard_Jr is offline   Reply With Quote
Old 07-15-2013, 09:50 AM   #1659
metalnut's Avatar
Trader Rating: 36 (100%+)
There are probably a few ways, but the way I've seen it done and do it myself:
* Set your ride height on the setup board
* Put the chassis up on droop blocks
* Use a droop gauge to measure the distance to a specific point on the arms, usually it' somewhere around the outer pin. Use the same measurement for both front arms, and same for both rear arms
* Set the car down on your setup board again. Make sure your ride height is still as you set it. Then lift the front of the car up with the tip of your hex driver or something similar, until the wheels just barely lift off. Slip the ride height gauge under the the front and see what it measures now. Take the difference of the two ride heights and that is your droop.
* Figure out what setting you need on the droop gauge to get the droop you want. Once you figure that out, you can just use the droop gauge and not have to worry about doing the math after.
Hope that made sense, and hope I'm not doing it completely wrong
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 07-15-2013, 10:15 AM   #1660
Bernard_Jr's Avatar
That does sound a tad bit involved. I relooked at the setup sheet and didn't realize that they are measuring the distance of the arm, at the outer hinge pin, above the chassis. It really never crossed my mind that the suspension might not extend past the chassis. I don't have the car here to look at. Is that right?
So couldn't I just lay the car flat on the chassis and basically eyeball this height with a caliper?
John Bernard Jr.
Old 07-15-2013, 10:17 AM   #1661
Cody_ferone's Avatar
Trader Rating: 12 (93%+)
SV-0220MG Standard High Voltage Servo 0.13/111.1 @7.4
Havnt bought a servo in a while haha. I'm on a budget and this savox struck me. Think that's enough power?
Cody_ferone is offline   Reply With Quote
Old 07-15-2013, 10:23 AM   #1662
SteveM's Avatar
Trader Rating: 139 (100%+)
I prefer the Savox SC-1251MG
SteveM is offline   Reply With Quote
Old 07-15-2013, 10:24 AM   #1663
SteveM's Avatar
See this how-to video.
http://www.youtube.com/watch?v=Ul_AN1STUmU
Old 07-15-2013, 12:42 PM   #1664
Bernard_Jr's Avatar
Originally Posted by SteveM View Post
Thank you. I'll pick up one of those tools.
John Bernard Jr.
Old 07-15-2013, 04:15 PM   #1665
metalnut's Avatar
You can do anything you feel works
But... onroad is all about the setup. I mean, driving too, but setup is a huge portion of it. So, if you are serious, invest in the tools and do the setup in known-to-work ways. Being able to repeat your setup, to the milometer, week after week, is the key to success. At least that's my take on it and what I'm still striving for.
- Ricky Bobby
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
