Old 10-15-2012, 09:08 PM   #151
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
so after realizing that the R1 is a combination of tamiya suspension and xray drivetrian with a hint of top photon. I found out that tamiya 417 aftermarket bumpers are direct fits and the center pulleys can also be replaced with the top racing optional aluminum ones seen here: http://c456141.r41.cf0.rackcdn.com/i...o-pdt011rd.jpg.
also you can already get the spec-r dcj driveshafts for the front as they are there xray version.
you can also run the rsd spring set on these shocks and there bladders i am running the rsd soft bladders and i like them alot .
I would also suggest replacing the stock ballcups with some real tamiya ones as they are a perfect fit with no slop.
another note i removed the wieght from my car as i now have my bmi racing lipo battery and i re-wieghed my car and it is 1385g race ready and the lipo wieghed 318g , reciever 8 g , esc 60g, servo 44.5 g
jeff jenkins is offline   Reply With Quote
Old 10-16-2012, 11:00 AM   #152
Xenolance's Avatar
When you said the RSD springs did you mean the RSD springs for the TC6? Also, the bladders are the 10MM bladders?
Are these the DCJ's you meant? I'm probably gonna purchase them today since I race with Christian every Thursday (using "Race With" loosely here since his RSD is stupid fast).
http://reflexracing.3dcartstores.com...AY_p_1336.html
I'm gonna order the TOP center pulleys, do I need their mounting shaft as well or will the one with my Kit work?
Xenolance is offline   Reply With Quote
Old 10-16-2012, 11:05 AM   #153
CristianTabush's Avatar
Yes, the XRAY DCJ's should be a direct drop in.
Also, FYI, the R1 spare parts have been ordered and on the way. They should go on the website sometime next week is my guess.
I did not order EVERYTHING, but I ordered plenty of the heavy wear items. If by the time all the parts are on the site, you don't find something you would like me to stock, please let me know and I will add it to the next Spec R order.
Thanks!
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 10-16-2012, 11:32 AM   #154
Originally Posted by Xenolance View Post
When you said the RSD springs did you mean the RSD springs for the TC6? Also, the bladders are the 10MM bladders? yes
yes
I'm gonna order the TOP center pulleys, do I need their mounting shaft as well or will the one with my Kit work? i think the kit shaft should work just fine.
answers are in red
Old 10-16-2012, 11:51 AM   #155
Xenolance's Avatar
Sweet! Between you and Christian this has been great! I've been eagerly waiting to build a parts box for the spec-r so I'll keep hammering your site Christian.
Thanks for the update and thank you for the answers Jeff!
Old 10-17-2012, 05:03 PM   #156
spring71's Avatar
Smile
Spec-R R1 kits and spare parts are in stock at TQ RC RACING.
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 10-17-2012, 07:42 PM   #157
my setup is now on petitrc.com http://www.petitrc.com/reglages/spec...eway201210.pdf
Old 10-18-2012, 08:29 AM   #158
Xenolance's Avatar
you know.. I've yet to make a purchase from TQ racing! I always buy from SpeedtechRC or Reflex racing.. Reflex wins out if they have it in stock because I A. know the owner in person, and B. don't have to pay shipping (but do pay tax). Maybe I'll order some items from TQ to spread the love a bit.
Also, thanks for sharing the setup! I'll duplicate it for my first run to give me a good starting point!
Old 10-19-2012, 11:54 PM   #159
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
Ok, so my car turned up finally after sitting in customs for over a week :-/
Built it yesterday, no major concerns at all apart from as jeff mentioned, the layshaft is miles off with regards to shimming, I must have measured about 1.2mm extra endfloat. But that is easily shimmed out, or in my case I think I'm just going to make up some new bushes that the layshaft sits in to take up the slack.
Also the hubs with the top hats feel like they needed a shim in too.. Like you have on the TCX etc between the top hat and the c hub.
I too had to add 0.1mm spacers to the upper bulkheads to avoid pinching.
Basically the car went together very simply, just be sure to have some of the correct sized shims available when you do the build.
All in all a nice piece of kit and I can't wait to give it a run in the next few weeks.
Pictures of unboxing and build in my blog link below
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 10-20-2012, 12:00 AM   #160
Xenolance's Avatar
I'm not seeing what pinch you're talking about? I'm sitting here about to assemble it but I don't have any shims at all so I'm probably going to wait and get it done when I'm at the LHS so I can find shims etc. Can you take a quick picture of where you needed to shim it please?
Thanks for the update regardless! (I only see unboxing on your blog FYI.. did I miss the build pics?)
Old 10-20-2012, 12:15 AM   #161
corallyman's Avatar
Trader Rating: 97 (100%+)
They are talking about putting the shims on top of the front and rear bulkheads before you screw on the upper camber link mounts. The shims prevent the pinching of the diffs and spool bearings that go into the plastic that holds them in place.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 10-20-2012, 08:21 AM   #162
Last night I changed out the kit spur gear for a kimbrough spur gear and the Kimbrough gear is thicker which makes it so the kit shimming on the layshaft ends up being correct. Only thing is the position of the belts on the center pulleys are now not.centered they are slightly rubbing the inner pulley wall. I changed out the.spur because the.kit spur is very load .
Old 10-20-2012, 08:24 AM   #163
Steve
That's correct thanks Steve .
Old 10-20-2012, 02:44 PM   #164
snoopyrc's Avatar
If anybody has part numbers for the shims used on the layshafts or exact sizes if they are 4C parts.
Also I have a Serpent S400 sitting on the shelf. We all know why they sit on the shelf. Ok so what I want to know is after some degree of hearsay that Tamiya suspension fits on the S400,(Yes I know that I am in the R1 thread) and some more hearsay that the spec R1 suspension is like the Tamiya. You see where I am going with this? I want to know if I can use R1 parts, anything, arms, C hubs, Steering knuckles, on the old snake.
If anybody that is excited about this car has an S400 sitting nearby, I would appreciate it if you would take some measurements during your build. Thanks.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 10-20-2012, 03:36 PM   #165
As above re: shimming upper bulkheads, it was a common problem on the tamiya 416.
Also regarding shimming, for wishbones, the kit is a total of 5mm (3+2) but I found to make them fit perfectly and freely with no slop I had 4.3mm (2.3+2) at the front then 2+2.6 in the rear... If that makes sense.
I've not thrown a xenon spur on it yet do I'll see if that takes up the slack as its similar thickness to the kimboro.
Thats the only gripe with the whole kit.
Everything else fit and finish wise is perfect.
Luke Hobson
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13440 03-26-2017 08:58 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
