Old 06-07-2013, 06:25 PM   #1531
Send a message via AIM to JimmyMack12
Are there any "setup sheets" or Micorsoft Excel/Adobe Acrobat editable setup sheets available any wheres?
JimmyMack12 is offline   Reply With Quote
Old 06-07-2013, 06:34 PM   #1532
Fuzzi0n's Avatar
Both S1 and R1 can be found on here.
Spec-R S1, Schumacher CAT SX3 S1
Fuzzi0n is offline   Reply With Quote
Old 06-08-2013, 08:19 AM   #1533
Thank you very much! :thumbsup:
Old 06-09-2013, 07:34 AM   #1534
Potoczak's Avatar
Trader Rating: 111 (100%+)
Hey guys need a suggestion for a good starting asphalt setup. The track is medium to high grip technical track. Here is a video of the track.
http://m.youtube.com/watch?v=l6v7nwDASdw&feature=plcp
Thanks for any help given!!
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 06-09-2013, 08:48 AM   #1535
Considering getting one of these.
How would the performance of r1 compare with vbc wildfire?
Thx
E36M3 is offline   Reply With Quote
Old 06-09-2013, 08:48 AM   #1536
Thx
Old 06-09-2013, 09:07 AM   #1537
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Thx
I am sure that with the correct setup, the two cars will be close, just like any other decent touring car.
The Wildfire parts all fit together very well, both composite and machined. Most parts for the Wildfire are also available at A-Main Hobbies.
In the end, you need to drive and set up each car, and both are more than capable of winning.
IIGQ4U is offline   Reply With Quote
Old 06-09-2013, 03:44 PM   #1538
RE: Back to the S1:
Haven't even run the car yet; just finished getting the chassis together. Adjusting the rear end (camber), and *snap*...the right rear ball stud snaps off with the threads deep inside the hub carrier. :/ So, now I need to (already) get a new set of rear hub carriers and ball studs (no extras, and the ball is bigger than what I run on my oval pan car).
Are the ball studs in the S1 kit *that* brittle that I should consider replacing them already, before I even get a chance to run it?
Old 06-09-2013, 03:50 PM   #1539
edhchoe's Avatar
Trader Rating: 41 (100%+)
Stock set up had my rear end loose so I put 1.1 mm rear sway and laid the rear shocks 1 hole and stood up the front shocks one hole. The handling was better but the springs were too hard for me so I put tamiya white med in front and soft in the rear. The car is fast.
RE: Back to the S1:
I didn't break mine but had trouble with the ball stud on the same part on my r1.
edhchoe is offline   Reply With Quote
Old 06-12-2013, 02:42 PM   #1540
Regarding the Spec R S1 again; sorry for all the questions (still kinda new to these touring-car things...)
Is there a way to adjust the diff on this car besides moving the four "locators" and tightening/loosening the two belts?
Is there a diff that will go into the front gearbox of this car (not sure yet if I like the spool)?
Old 06-12-2013, 02:48 PM   #1541
The front and rear diffs are the same. Buy another and put it up front.
You'll need blades for the driveshafts. Spool doesn't use them.
You tune the diff with the weight of the oil in it. I have 500,000 in there now. Prob need 1,000,000. Some use putty.
.crispy is offline   Reply With Quote
Old 06-12-2013, 05:33 PM   #1542
Just to make sure, he's talking about the front diff.
You'll use much, much lighter oil in the rear diff.
-Mike
Old 06-12-2013, 05:36 PM   #1543
Yeah, that would be bad.
I use 80 wt shock oil in my rear diff.
Old 06-13-2013, 08:26 AM   #1544
academygaz's Avatar
I haven't used my S1 that much since I got it before Christmas, but on the occasions that I have ran it, it's winning and handling beautifully. However, spares aren't easy to come by here in the UK, and sometimes, ordering from HK or America isn't viable (incase I need something on Wednesday to arrive to race on Friday for example). I'm currently needing a front belt (stone cut a groove in the backing) and a front spool centre (the plastic has rounded off where the outdrive screw goes in, so it loosens off every run and leaves it 3WD), so what front belts and spools from other cars fit the R1/S1?
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 06-13-2013, 08:31 AM   #1545
Potoczak's Avatar
Xray belts, spools and gear diffs should fit right in.
Pete Potoczak
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 07:26 PM
2012 R.O.A.R Carpet Nationals andrewdoherty Electric On-Road 774 04-04-2012 03:26 PM
JR R1 Pro w/ case for sale... Sorcerer001 R/C Items: For Sale/Trade 7 12-10-2004 11:44 AM
