Like Tree42Likes
Old 03-01-2014, 10:28 PM   #1336
DesertRat's Avatar
Originally Posted by BadSign View Post
Can anyone tell me the length of the 3219 and 3218 Ride Height shims for the front? I purchased a used xti with no spacers on it, and need to bring the ride height down.
One great thing about the XTI is you don't need any special spacers to adjust ride height. Just take four washers of a known thickness and space the entire front sub-frame up from the chassis! Instant, consistent ride height adjustment without making the car more fragile or needing to unthread big screws from plastic parts over and over.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. Losi 22 4.0, CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 03-02-2014, 04:32 PM   #1337
I am using the small diameter shim that is .047 inches thick.
davidl is offline   Reply With Quote
Old 03-06-2014, 06:39 AM   #1338
jasons56's Avatar
For those "fast guys" at the Nats, where did you end up on center spring?
Looking for those elusive last tenths!
In testing at the Plex club race last night, I went up one spring size and picked up some on power steering. Also discovered I was definitely over geared.
The circle was one of my slower parts of the track, and getting steering there helped.
What other things do you generally try in med/high conditions to get on power steering WITHOUT making the car overly aggressive?
Do any of you care to share a setup sheet from Nats?
Thanks again for your help!
http://www.youtube.com/user/ZenRacing
jasons56 is offline   Reply With Quote
Old 03-06-2014, 08:08 AM   #1339
WIITA's Avatar
Trader Rating: 42 (100%+)
Here's the setup I ran from the nationals. Mitch ran something very similar.
Altered ego chassis/xti rear pod and top plate(short/short)
5* front blocks with 2 shims forward
CRC Blacks cut to 40.3mm 1/2 dope
3.5mm RH
.50 front spring .5mm droop
.5* camber
Red center spring(new one)
30wt oil
2mm pod droop
41.3 rear tire
3.5mm ride height
CRC Graylow rear
Max width
20k in the tubes
.50 sides outboard just touching and tweaked
CRC r8c body
Team CRC / Sanwa / Team scream / Genesis RC / Hobbywing / TQ Wire / Schelle / MIP / RC^2 / TEKNO / BoomRC
WIITA is offline   Reply With Quote
Old 03-07-2014, 02:25 PM   #1340
jasons56's Avatar
Thanks!
Do you typically run the same setups in 13.5 or make changes for the slight speed differences?
3.5mm RH
.5* camber
30wt oil
2mm pod droop
41.3 rear tire
3.5mm ride height
CRC Graylow rear
Max width
20k in the tubes
CRC r8c body
Old 03-08-2014, 04:34 AM   #1341
WIITA's Avatar
Very similar. Most guys run different tires like blue/green rears in 13.5 and magenta fronts in 13.5. But other than that the cars are very similar in setup.
Old 03-08-2014, 10:14 AM   #1342
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Alter ego conversion questions:
Other than the graphite chassis conversion parts, can someone provide the list of additional parts/part numbers needed to convert a stock XTi to an Alter Ego?
Thanks in advance,
John
madjack is offline   Reply With Quote
Old 03-08-2014, 11:09 AM   #1343
DesertRat's Avatar
Thanks in advance,
John
You need the full-length side links, I think the part number is the same as those for the XL and Xi.
Old 03-09-2014, 10:02 AM   #1344
Originally Posted by Slapmaster6000 View Post
Going from 50 springs to 45's is going to have a bigger effect then a normal or tall ball stud on the shock. Going to a 45 spring is going to push more on corner entry. Lowing the back of the shock is going to make the shock feel softer too. Add both of those together and you will get less initial steering. So if that is the effect you are after, that should do it. Bottom line: try it! Don't take anyone's word on what something should do. Prove it to yourself.
Brian, I have now run your setup and I think I fully duplicated it. I finally was able to mount the battery inline with the speed control at the rear by the motor pod. I came up with a way to hold the battery without using the tape, but keeping it away from the servo. That turns out to be more simple than first thought. Just two screws mouned between the servo and the battery. They are 4-40 flatheads, about 3/8 to 1/2 long, with the smallest standard nut on top. The nut fits the curve of the battery case so everything fits down to the chassis.
Used the BSR white (CRC yellow) rear tire and the black front tires. Changed the front doping a little to adjust to conditions. This car is more aggressive than I was able to make the original Xti. I think the shock angle contributed to this. I still had a little push, especially early in the run, that put me behind, but I was able to catch up when the front tire hooked up. You are right that the front tire starts to grip more as the run goes along. I think if I had used grey front that it would have been more consistent. As I play with this down the road, I think it worth my while to lower the rear of the shock and use .45 front springs. As I said in earlier posts, I think there is a difference in the carpets we both run on and this later idea might help in my case.
I also had setup an Altered Ego with the battery transverse. It was really good and very close to this inline setup. This one did use the lowered shock and the .45 springs, so I have some experience with that. We have a lot of 180 corners on our layouts so it will be good to see if the transverse battery or the .45 springs will be the best approach.
Overall, both these car setups are really good and can be the ticket on low to medium bite that are experienced at club racing each week. Your insights and instincts have been proven.
Old 03-09-2014, 10:14 AM   #1345
Thanks in advance,
John
Hi John. A conversion kit was offered and still available on the CRC website. Use p/n 3226 in the search button. It is listed there for $65. Hope that helps.
Old 03-09-2014, 03:06 PM   #1346
tim fry's Avatar
You will need side links too.
tim fry is offline   Reply With Quote
Old 03-09-2014, 06:40 PM   #1347
The correct side links are in the conversion kit.
Old 03-10-2014, 07:51 PM   #1348
ghoppa's Avatar
Trader Rating: 54 (98%+)
3.5mm RH
.5* camber
30wt oil
2mm pod droop
41.3 rear tire
3.5mm ride height
CRC Graylow rear
Max width
20k in the tubes
CRC r8c body
Question Wiita
What does running the Xti rear pod and top plate to a Altered Ego main chassis do?
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 03-10-2014, 09:06 PM   #1349
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Originally Posted by ghoppa View Post
Question Wiita
It gives you a shorter car, 8mm. This transitions on the track to a car that works more like the Gen XL and the Xi did. The car can be ran Long/Short, Short/Short, or Short/Long. Altered Ego is Short/Long, Xti is Long/Short, the AE with the Xti pod is Short/Short. Wiita feels as if the Short/Short car is the best option for on the track performance, it produces a car that is a bit more reactive then the longer cars.
Kevin Van Ert | MFR | CRC Racing | Team Scream Racing | Hobbywing | Xenon USA | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 03-10-2014, 10:28 PM   #1350
slowpoke68's Avatar
Trader Rating: 28 (100%+)
Default alterego conversion
i just built mine and found out that if you want to run the batt in transverse then make sure you get the tweak plate also for the alter ego because this did not come in the conversion for the xti to alterego i red eye mine thanks to john perfect customer service and ran it last weekend at tq also thanks to art for your help in setup.
slowpoke68 is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 567 11-20-2017 04:06 PM
